North Carolina Woodworker
Discounts on 2010 NCWW Calendar through Nov 30th!!
Javascript DHTML Drop Down Menu Powered by dhtml-menu-builder.com
Go Back   North Carolina Woodworker > Woodworking > Scrollsaw Work
» Upcoming Events
Fall 2009 Raffle drawing this Friday (11/20): See This Thread For Details
Closed Thread
Old 07-25-2009, 02:09 PM   #1
delta scroll saw
City: Winterville
State: NC
County: Pitt
Threads: 7
Show Printable Version Email this Page   Quote this post in a PM to grumpy
grumpy grumpy is offline 07-25-2009, 02:09 PM
Bear with me a minute. Have Delta stopped making scroll saws in preference to the dewalt line. ??? Now, I have several saws including some good ones but the cheaper delta 16" that may not be a gem but I have enjoyed using it.. It is blowing a fuse the second I turn it on after replacement. Has anyone had success getting one fixed at Delta or should I just forget it. sometimes repairs cost as much as a new machine. Any suggestions as to the problem. Harry
Old 07-25-2009, 02:41 PM   #2
cskipper's Avatar
City: Forest City
State: NC
County: Rutherford
Threads: 443
Avg Visit Freq/Week
= 2.45 over 180 days
Re: delta scroll saw
Wish I could help, I never had similar problems with my Delta.
__________________
Cathy Skipper
Show Printable Version Email this Page   Quote this post in a PM to cskipper
Old 07-25-2009, 03:17 PM   #3
Gregory Paolini's Avatar
City: Waynesville
State: NC
County: Haywood
Threads: 3
Avg Visit Freq/Week
= 2.24 over 169 days
I typically fix the broken stuff myself - And I don't know too much about what's happening with Delta or their parent/sister companies, but here's what I do know:
Usually when a machine blows a fuse that quickly, it's representitive of a direct or dead short in the system - It could be as simple as a loose wire on a motor or switch. Having a simple delta variable speed 16" saw myself, I know it's not the smoothest saw in the world, and I wouldn't doubt it if years of vibration caused somthing to come loose.
It may be worth unplugging the saw and taking some things apart - Even if you're not an electrical expert, you should be able to spot an arching wire, or a loose connection. Arcing wires look like somebody struck a match, and will be associated with black carbon build up. Wire terminals should be tight, and lighlty tugging on wires should not cause them to come off.
If you're not comfortable, don't do it - Electricty can and has injured and killed people - I'm just telling you what I would do.
Hope this helps
__________________
Gregory Paolini
www.GregoryPaolini.com
Custom Furniture, Cabinetry, and Woodworking Instruction
Show Printable Version Email this Page   Quote this post in a PM to Gregory Paolini
Old 07-25-2009, 04:13 PM   #4
City: Winterville
State: NC
County: Pitt
Threads: 7
Avg Visit Freq/Week
= 1.17 over 180 days
Gregory, wow your some technician. I decided I'd follow your instructions and took the beast out on the picnic table and the first take apart was the dust collector that now is gone for good. I discovered quickly the arm was what seemed like frozen so I struggled with the dust collector and discovered when it finally came loose it had been wedged somehow with the lower arm and I was smart enough to realize it blew the fuse immediately and upon replacing the fuse voila it works fine. Thanks so very much for your encouragement. Harry
Old 07-25-2009, 09:02 PM   #5
LeftyTom's Avatar
City: Yadkinville
State: NC
County: Yadkin
Threads: 209
Avg Visit Freq/Week
= 5.99 over 180 days
Harry, with all the know-how North Carolina Woodworker members have, if it cannot be fixed, it ain't broke.
Good on ya, Greg, for piping in with a helpful hint.
__________________
The thing that holds up all my woodworking is simply getting started.
Show Printable Version Email this Page   Quote this post in a PM to LeftyTom
Old 07-25-2009, 10:24 PM   #6
Senior Moderator
Events Director
ScottM's Avatar
City: Cary
State: NC
County: Wake
Threads: 257
Avg Visit Freq/Week
= 6.53 over 180 days
Wow...great advise and a quick fix. Score another one for North Carolina Woodworker.
__________________
Making Saw Dust With a Scroll Saw
Show Printable Version Email this Page   Quote this post in a PM to ScottM
Old 07-26-2009, 01:30 PM   #7
City: Waynesville
State: NC
County: Haywood
Threads: 3
Avg Visit Freq/Week
Glad I could help - A seized motor would definatley cause a dead short. I bet 90% of the "broken" tools out there are simple fixes like that.
As luck would have it, the switch on my Delta Planer just fractured - Cheap plastic in the switch... Ordered a new one from a place in Utah for 20bucks - I don't seem to have any luck with the new Delta website..
__________________
Gregory Paolini
Old 07-26-2009, 04:16 PM   #8
LeftyTom's Avatar
City: Yadkinville
State: NC
County: Yadkin
Threads: 209
Avg Visit Freq/Week
Too late, but I got a 12 1/2" planer that may work as a switch donor.
__________________
Old 07-27-2009, 11:09 AM   #9
City: Davidson
State: NC
County: Cabarrus
Threads: 58
Avg Visit Freq/Week
= 6.14 over 180 days
Ha yeah beat me to it but I was going to tell you that it was most likely the motor got bound up and it loaded the fuse and poped it. I have a similar Delta Saw and after having a finger in the wrong place at the wrong time poped a fuse on it when the motor started to load up... Basically the blade got stuck in the piece pulled it up and my finger went under on the downstroke and bound the works up and faster than I could hit the switch it poped the fuse and released probably saved my finger.. Glad you got it fixed.
__________________
Kevin
Davidson, NC
Show Printable Version Email this Page   Quote this post in a PM to rcflyer23
Closed Thread
delta , scroll
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Delta Scroll Saw? rcflyer23 Power Tools and Their Use 22 11-07-2008 12:37 PM
Delta/Milwalkee Scroll Saw ashley_phil Power Tools and Their Use 6 06-26-2006 02:04 PM
Order your 2010 Calendar!
Carolina Lumber Sourcing
» Stats
Members: 3,663
Threads: 25,102
Top Poster: DaveO (14,701)
Welcome to our newest member, Keith Senderak
» Today's Birthdays
Dick Barnes (74)
Powered by vBadvanced CMPS v3.2.0
Powered by vBulletin® Version 3.8.2
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.3.0
Template-Modifications by TMS
Content Copyright © 2005 - 2009 North Carolina Woodworker, Inc.
