Sometimes the easiest way to get an answer is to "Ask the Expert" !
So . . . Is sent an email to David and got this response:
Hi Peter,
Thanks for your interest in my work. How did you find out about it?
I don't mind sharing my techniques, as long as you are not reproducing my designs. Here's how I carve: For my large forms, I rough out the basic form with power tools - bandsaw and an angle grinder with chainsaw tooth carving wheel, or kutzall carving wheel. Depending on the piece, I also use larger sculpting gouges to carve out the rough form, and in some cases a rasp, rifflers, a surform or microplane rasp for the general shape. Once I have the form clearly defined, I then go over the surface and apply the hand carved surface treatment with a smaller carving gouge (the size of whatever texture I'm going for - in some cases it's a small / finer texture, in other cases it can be a coarser, chunkier texture). I just carve it one chip at a time, starting at the top of the grain and working in the right direction so that it tears out the least. If I'm carving the texture on a flat surface where the grain tears out in either direction, sometimes for each chip of the texture I have to carve in half way with the gouge, and then carve in from the other direction the other half. I mostly use a mallet to do that texture, but sometimes if I want a more uniform and controlled texture (without the lines from each blow of the mallet), I will do each chip by hand, pushing the gouge without the mallet. That is much more time consuming though, and tiring on the hands if it's a large piece. The key is to have a really sharp carving gouge, and resharpen periodically while working. Even with a sharp gouge, the texture may come out a little rough and fuzzy in some woods, so I then clean it up with a little light hand sanding, being careful not to flatten the high spots too much.
Beyond that there's not a whole lot to it. It just takes a little practice and some trial and error. I'm not sure if that helps at all, but hopefully it will.
Good luck with your work.
Cheers,
David Hurwitz
David Hurwitz Originals
Unique, handcrafted woodwork and design
23 Randolph Ave.
Randolph, Vermont 05060
phone: 802-728-9399
www.davidhurwitzoriginals.com
Member:
The Furniture Society
Vice President, Guild of Vermont Furniture Makers
Vermont Wood Manufacturers Association
pete
