» Upcoming Events | | Fall 2009 Raffle drawing this Friday (11/20): See This Thread For Details |  |
11-06-2009, 07:27 AM
#1 | | Tailstock Quill Binding! Name: Tim City: Charlotte State: NC County: Mecklenburg Join Date: May 2009  11-06-2009, 07:27 AM
Okay, so I had some free time last night (which is rare for me lately!) and I wanted to try turning a travel coffee mug:
Anyway, I got as far as boring out a starter hole on the inside when I noticed that my tailstock was binding badly while I was trying to bore the hole with a fostner bit mounted in a jacobs chuck. I had to use both hands and all my strength to get the hole bored and then to retract the bit. It seemed to get worse as I went. Worried that the threads were damaged or gunked up I decided to pull the tailstock apart. The threads looked fine and with the quill out of the tailstock casting I was able to easily thread the quill the entire length of the threaded rod. When I tried to put the quill back into the tailstock casting I discovered my problem. It just doesn't want to go into the tailstock even with lithium grease lubricant! What could be causing the binding? The lathe is in my basement where the temperature is in the mid 60's. Could the casting be contracting more than the quill when cold? I am kinda stumped and am looking for suggestions on how to fix this.
__________________
_________________________________________________
- Tim A busy man is a happy man.
- Herb Tuttle
| | Views: 137 |
11-06-2009, 07:47 AM
#2 |
Name: Jack City: Cullowhee State: NC County: Jackson Join Date: May 2008 Avg Visit Freq/Week = 5.79 over 180 days | Re: Tailstock Quill Binding! Sounds like you need to take the quill out of the tailstock and clean the threads and check them out as well. If the threads are still ok some of your grease on them will insure that they stay that way. To take the quill out their is a small screw infront of the knob that tightens it down you need to loosen and it should screw off the screw inside the tailstock and slide out.
Good Luck,
Jack |
11-06-2009, 07:52 AM
#3 |
Name: Tim City: Charlotte State: NC County: Mecklenburg Join Date: May 2009 Avg Visit Freq/Week = 5.76 over 180 days | Re: Tailstock Quill Binding! Originally Posted by flyrod444 Sounds like you need to take the quill out of the tailstock and clean the threads and check them out as well. If the threads are still ok some of your grease on them will insure that they stay that way. To take the quill out their is a small screw infront of the knob that tightens it down you need to loosen and it should screw off the screw inside the tailstock and slide out.
Good Luck,
Jack Jack, I got that far with it. The threads are fine, but the quill just doesn't want to slide freely in the tailstock casting. Seems like the quill is "swollen" or the tailstock casting has "shrunk". I don't want to affect the alignment by messing with it too much, so I am looking for ideas on how to "fix" the problem.
__________________
- Herb Tuttle
11-06-2009, 08:24 AM
#4 | | Moderator
Name: Bob City: Hillsborough State: NC County: Orange Join Date: May 2007 Avg Visit Freq/Week = 7.00 over 180 days | Re: Tailstock Quill Binding! Ok, let me see if I understand you correctly. Are you saying that the tailstock ram is binding as you attempt to run it in or out? If that is the case and the threads seem ok, I wonder if the ram twisted on the set screw. If this happened while you were drilling, that may be the case. Back out the set screw and check it for damage. Also, disassemble the tailstock and look at the outside of the ram and the inside of the casting in the area of the set screw. If I'm way off base... never mind  .
__________________
To everything... turn, turn, turn!
11-06-2009, 08:36 AM
#5 |
Name: Tim City: Charlotte State: NC County: Mecklenburg Join Date: May 2009 Avg Visit Freq/Week = 5.76 over 180 days | Re: Tailstock Quill Binding! Originally Posted by woodArtz Ok, let me see if I understand you correctly. Are you saying that the tailstock ram is binding as you attempt to run it in or out? If that is the case and the threads seem ok, I wonder if the ram twisted on the set screw. If this happened while you were drilling, that may be the case. Back out the set screw and check it for damage. Also, disassemble the tailstock and look at the outside of the ram and the inside of the casting in the area of the set screw. If I'm way off base... never mind  . You're not off base, but I checked that too. The set screw is completely removed and I checked inside to see if there was any protrusion from the set screw hole - nothing that I could see/feel. Now I did notice that there were sharp edges on the set screw channel cut in the quill/ram. I may try filing these down smooth to see if it helps.
__________________
- Herb Tuttle
11-06-2009, 09:55 PM
#6 |
Name: Tim City: Charlotte State: NC County: Mecklenburg Join Date: May 2009 Avg Visit Freq/Week = 5.76 over 180 days | Re: Tailstock Quill Binding! Solved! After filing off the "burr" around the channel in the quill, it moved much more smooth in the tailstock. It appears as though the rotational force on the quill pushing on the locking screw as I was advancing the quill caused a burr to form on the lip of the channel. Lesson learned.
__________________
- Herb Tuttle
11-06-2009, 10:14 PM
#7 |
Name: Dennis City: Ivan's Corner (Monroe) State: NC County: Union Join Date: Jan 2007 Avg Visit Freq/Week = 6.69 over 180 days | Re: Tailstock Quill Binding! Most wood lathe tailstocks aren't made to transfer the axial loading from boring a large hole. You might check your setscrew & see if you are able to file a flat on it or file off the threads where it rides in the slot. There should be some type of jib or adjustment mechanism there to let it ride on instead of the raw edge of a screw thread.
__________________
WHAT BOX?
11-06-2009, 10:41 PM
#8 | | Moderator
Name: Bob City: Hillsborough State: NC County: Orange Join Date: May 2007 Avg Visit Freq/Week = 7.00 over 180 days | Re: Tailstock Quill Binding! Glad you got it!
__________________
Posting Rules
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | |
Similar Threads | | Thread | Thread Starter | Forum | Replies | Last Post | | Lathe tailstock chuck? | Alan in Little Washington | Power Tools and Their Use | 7 | 02-11-2009 02:24 PM | | binding tablesaw | dtomasch | Power Tools and Their Use | 3 | 08-01-2006 04:24 PM | | » Stats |
Members: 3,662
Threads: 25,097
Top Poster: DaveO (14,701) | | Welcome to our newest member, quaffin1 | |
