North Carolina Woodworker
Discounts on 2010 NCWW Calendar through Nov 30th!!
Javascript DHTML Drop Down Menu Powered by dhtml-menu-builder.com
Go Back   North Carolina Woodworker > Woodworking > Woodturning
» Upcoming Events
Fall 2009 Raffle drawing this Friday (11/20): See This Thread For Details
Closed Thread
Old 05-04-2009, 03:47 PM   #1
Pen Blank Sled
wdkits1's Avatar
City: Midlothian
State: VA
County: Chesterfield
Threads: 42
Show Printable Version Email this Page   Quote this post in a PM to wdkits1
wdkits1 wdkits1 is offline 05-04-2009, 03:47 PM
On occasion I go into a pen turning frenzy where I usually turn between 10 and 20 at a stretch. One of the most annoying aspects of pen turning is whittling down a square blank on the lathe to get it to the proper size. Takes up alot of extra time readjusting the tool rest and having to sharpen the tools more often. I have seen other jigs to pre- round the blanks for sale, but being the cheapskate that I am I decided to make my own pre-turning pen blank jig.
I started by putting a dovetail in a scrap piece of walnut to hold the piece that the handle section and the removable tail section slide in. Next make the corresponding dovetail in the handle section stock so that it slides in the sled slot. I then cut the handle section from the tail section and formed the handle. Cut the tail section to allow a thru hole to be drilled for the pen mandrel. Glue the handle section in place on the sled. Glue small pieces of 80 grit sandpaper at each end of the mandrel thru holes to keep the blank from spinning.
The tail section slides in the dovetail to load a pen blank onto the mandrel and the thumb lever (removable) is used to apply pressure to the pen blank to keep it from spinning during the cut.
I also set the jig up to slide in the miter slot of the bandsaw bed by adding a rail under the sled after I determined how far from the blade the jig needed to be.
Once the blank is loaded onto the jig, pressure is applied to the thumb lever and the cut is made . Then I retract the jig ,release the pressure, spin the blank 90 degrees,make the next cut and so on until the blank has been rounded.
Completed blank ready for turning in less than 1 minute
__________________
wdkits1
www.midlothianwoodworks.com
"why buy it if you can build it"
Old 05-04-2009, 03:54 PM   #2
woodArtz's Avatar
City: Hillsborough
State: NC
County: Orange
Threads: 81
Avg Visit Freq/Week
= 7.00 over 180 days
Re: Pen Blank Sled
Wow, that's cool! You put some serious engineering into that thing, but the time savings are worth it when you're doing a bunch at a time. I may borrow your idea, if you don't mind. Thanks!
__________________
To everything... turn, turn, turn!
Show Printable Version Email this Page   Quote this post in a PM to woodArtz
Old 05-04-2009, 04:24 PM   #3
ptt49er's Avatar
City: Harrisburg
State: NC
County: Cabarrus
Threads: 70
Avg Visit Freq/Week
= 6.53 over 180 days
Re: Pen Blank Sled
That's a nifty jig! I can definitely see the time savings it produces.
__________________
~Phillip
"Okay Hunny, so my hobby is collecting other hobbies. Atleast I'm well rounded!"
Show Printable Version Email this Page   Quote this post in a PM to ptt49er
Old 05-04-2009, 04:29 PM   #4
RandyJ's Avatar
City: Macon
State: NC
County: Warren
Threads: 34
Avg Visit Freq/Week
= 5.44 over 180 days
Re: Pen Blank Sled
Great idea, Mike. I've been pondering this for some time and even tried a V-notched sled. It was ok but really only allowed 4 cuts before becoming unstable.
Thanks for sharing your idea!
__________________
Randy
Any compromise between the truth and a lie can ONLY be something less than the truth.
Show Printable Version Email this Page   Quote this post in a PM to RandyJ
Old 05-04-2009, 05:07 PM   #5
Senior Moderator
Events Director
ScottM's Avatar
City: Cary
State: NC
County: Wake
Threads: 257
Avg Visit Freq/Week
= 6.49 over 180 days
Re: Pen Blank Sled
I need to save this for future use. Seriously you should write/draw this idea up ans submit it for publication. It is a sure winner.
__________________
Making Saw Dust With a Scroll Saw
Show Printable Version Email this Page   Quote this post in a PM to ScottM
Old 05-04-2009, 06:39 PM   #6
MikeL's Avatar
City: Raleigh
State: NC
County: Wake
Threads: 49
Avg Visit Freq/Week
= 5.72 over 180 days
Re: Pen Blank Sled
This is a wonderful idea! How is the thumb lever attached?
You should submit this to all of the magazines. It has to be worthy of a Tip of the Month. Thank you for sharing your project with us.
Show Printable Version Email this Page   Quote this post in a PM to MikeL
Old 05-04-2009, 07:04 PM   #7
wdkits1's Avatar
City: Midlothian
State: VA
Threads: 42
Avg Visit Freq/Week
= 4.20 over 180 days
Re: Pen Blank Sled
The thumb lever is attached with a pin that drops into a hole that is drilled into the sled. This makes it very simple to remove the lever to load and unload the blank.
__________________
wdkits1
Old 05-04-2009, 07:29 PM   #8
MikeL's Avatar
City: Raleigh
State: NC
County: Wake
Threads: 49
Avg Visit Freq/Week
Re: Pen Blank Sled
Excellent! So you could bore several holes in line for multiple lever positions and, in conjuntion with the sliding dovetail for the tail piece, have the ability to work with different length blanks (pens, bracelet helpers, etc). I think what I just said makes sense.
Old 05-04-2009, 08:04 PM   #9
wdkits1's Avatar
City: Midlothian
State: VA
Threads: 42
Avg Visit Freq/Week
Re: Pen Blank Sled
That's right Mike-- I usually just do slimline pens so I only use one position for the lever but it could easily be modified for other uses. Iv'e made several variations of the jig to do tapered table legs, chair spindles even drum sticks. It really saves time if you go to the lathe with a semi-round blank to start with.
__________________
wdkits1
Old 05-04-2009, 08:08 PM   #10
MikeL's Avatar
City: Raleigh
State: NC
County: Wake
Threads: 49
Avg Visit Freq/Week
Re: Pen Blank Sled
I am sold on it already. Thanks again!
Closed Thread
blank , pen , sled
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Pen blank glue-ups nblong Woodturning 4 01-29-2009 11:05 PM
Trimming Pen Blank ?? Splinter Woodturning 5 02-17-2008 08:57 PM
WIP blank Eaglesc Woodturning 3 12-24-2007 07:22 PM
Pen Blank Holes JRD Woodturning 6 11-08-2006 12:22 AM
My bowl blank gsdoby Woodturning 8 09-08-2006 07:30 AM
Order your 2010 Calendar!
Carolina Lumber Sourcing
» Stats
Members: 3,663
Threads: 25,104
Top Poster: DaveO (14,701)
Welcome to our newest member, Keith Senderak
» Today's Birthdays
Dick Barnes (74)
Powered by vBadvanced CMPS v3.2.0
Powered by vBulletin® Version 3.8.2
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.3.0
Template-Modifications by TMS
Content Copyright © 2005 - 2009 North Carolina Woodworker, Inc.
