North Carolina Woodworker
Javascript DHTML Drop Down Menu Powered by dhtml-menu-builder.com
Go Back   North Carolina Woodworker > Woodworking > Woodturning
» Upcoming Events
Klingspor Wood Workers Show Case - Raleigh, NC -- September 11
Klingspor Extravaganza - Hickory, NC -- October 29 and 30
2011 North Carolina Woodworker Calendar Contest
Entry deadline by August 16th
Click for more!!
Welcome New Member Chat! Every Thursday evening at 7:30pm Click here for more!
Closed Thread
Thread Tools Display Modes
Old 02-08-2010, 10:08 PM   #1
Nova chuck references/howtos/tutorials?
johnpipe108's Avatar
City: Santa Rosa
State: CA
County: Sonoma
Threads: 90
Show Printable Version Email this Page   Quote this post in a PM to johnpipe108
johnpipe108 johnpipe108 is offline 02-08-2010, 10:08 PM
I have recently returned to my English Northumbrian bagpipes project, about a year and a half after making the smallest drone:
Today I went out to Woodcraft and purchased a Nova Precision Midi woodturning chuck, and I've never worked with this type chuck before. As may be seen in the photo above, I'm turning small, cylinder-bored parts. I will be cutting the blanks in the background for the mid-size two-part drone (the smaller and larger drones are the 4 pieces in the foreground), and a common stock for the three drones; the bulky piece of cocobolo is for the stock, and it will be hollowed out inside as is commonly done for this class of bagpipe.
I will need to end-bore the drone blanks on the lathe, either in the square or after turning to cylinder. Once bored, turning is virtually the same as pen-turning. I will also be doing the same with a 1-inch square x 7-inch piece of African Blackwood for the pipe chanter.
I would be looking for info on the best way (ways?) of chucking the pieces for end-boring, either square or round, and if needed will support the outer end with my home-made center rest. The drone blanks will be 3/4-inch square x 5-inches long.
The Nova chuck comes with two sets of jaws, the smaller (25mm minimum diameter)has an internal radius of about 0.200-inch, and the larger (50mm) being about 0.850-inch internal radius. The larger would be used to grip the 1-3/8-inch OD on the stock for hollowing after turning to form (cylindrical at the ferrule, with a slight outward taper to the other end), which hopefully will be reasonably straightforward, so the main questions would seem to be on holding the drone and chanter pieces.
Any tips or references on useage of such chucks for my purposes will be appreciated.
Thank you, John
__________________
Johnpipe108,
Your friendly neighborhood Kshatriya-Brahmin and general household fixit-guy.
Who sees all beings in the Self, and the Self in all beings, hates none -- Isha Upanishad
Old 02-08-2010, 10:39 PM   #2
nelsone's Avatar
City: Charlotte
State: NC
County: Mecklenburg
Threads: 168
Avg Visit Freq/Week
= 4.74 over 180 days
Re: Nova chuck references/howtos/tutorials?
I would probably turn the blank first. When I have done that for pens or spice mills I have the jaws on each of the flats with the corners between the jaws. A jacobs chuck on the tailstock and run it in.
You may get some better answers than mine, but that's what I do for that type of turning.
I'd love to see progress pics on your pipes!
__________________
Never take life seriously. Nobody gets out alive anyway !
Show Printable Version Email this Page   Quote this post in a PM to nelsone
Old 02-08-2010, 11:14 PM   #3
City: Santa Rosa
State: CA
County: Sonoma
Threads: 90
Avg Visit Freq/Week
= 1.91 over 180 days
I'm a little unclear about your reply; do you mean you have turned the blank to a cylinder, except for the ends, leaving them square for the chuck, before boring?
I will not be able to use my jacobs chuck in the tailstock for the shorter blanks as it has been damaged and has excessive runout , and I will not be able to afford a new one for a few month after parting with 110 presidents today! I will feed the drills, held in a hand-chuck, into the rotating stock (this is the common practice in end-drilling bagpipe blanks)
Thanks, John
__________________
Johnpipe108,
Old 02-09-2010, 07:20 AM   #4
nelsone's Avatar
City: Charlotte
State: NC
County: Mecklenburg
Threads: 168
Avg Visit Freq/Week
Sorry for not being clear. When I have done pens or mills I drill the hole before turning the cylinder. Square blank in the chuck. The reason is if you are off just a bit with the square blank, you still have room to keep everythign centered.
__________________
Closed Thread New posts
chuck , nova
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Good Chuck?? Barracuda2 T/N Plated Special Edition Lathe Key Chuck System mbeach Woodturning 7 11-24-2009 01:11 PM
nova chuck 99.00 wayne Found for Sale/Hot Deals 2 07-27-2009 06:30 AM
PSI Cole Jaws On Nova G3 Chuck Ken Massingale Woodturning 2 06-05-2009 10:29 PM
Which chuck for Nova DVR XP SteveColes Woodturning 15 04-11-2007 11:42 PM
Kreg Ad
How to get discount qualified
Lee Valley ad
Mountain Sawyers Ad
The Woodworking Source Ad
» Stats
Members: 4,585
Threads: 30,664
Top Poster: DaveO (15,152)
Welcome to our newest member, JonathanK
» Today's Birthdays
legmaker (58)
Powered by vBadvanced CMPS v3.2.2
Powered by vBulletin® Version 3.8.5
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.3.2
Template-Modifications by TMS
Content Copyright © 2005 - 2009 North Carolina Woodworker, Inc.
