WARNING:
If you have strong opinions about using only the proper equipment, you might want to go on to the next thread.
Even Earl might find it a little dark in here...
I started a thread in the carvng forum about getting my tuning pegs shaped close to final form:
http://www.ncwoodworker.net/forums/s...589#post141589
One suggestion was to consider turning them and I even had a nice old lathe offered to me. I will probably take Mike up on that offer, but it will be a while before I can get up his way. In the meantime, I decided to improvise...
That's a pear wood peg blank (see the other thread for a picture of a similar instrument; the pegs are huge). I carved a little divot in the center of the blank so it stays on my fancy dead center (the ground pin of a 3 prong was the handiest round pin I could find already mounted in something I could clamp). My cutting tool is a Microplane rotary rasp. that worked out really well. It's hard to tell in the photo, but the surface is textured with tiny facets. It looks carved. With both drills on, I use the Microplane on the surface that is running away from me and didn't need a tool rest. This is a short term solution, but it is working pretty well. I got all 3 shaped close enough that I can carve and/or use a peg shaper to get them the rest of the way.
