» Upcoming Events | | Fall 2009 Raffle drawing this Friday (11/20): See This Thread For Details |  |
07-11-2009, 07:02 PM
#1 | | How do you hollow a box? Name: Bear City: Crossville State: TN County: Cumberland Join Date: Apr 2009 Age: 66  07-11-2009, 07:02 PM
Hello all, I am in the process of trying to hollow out a box, inside diameter about 2" and 3 1/2" deep. What tools do you use and what procedures? I have tried 6 different gouges plus a tool using the CI0 cutter. They are all scary. The wood is semi-dry cherry. Thanks for any suggestions.
Bear | | Views: 260 |
07-11-2009, 07:23 PM
#2 |
Name: Robert City: Matthews State: NC County: Union Join Date: Feb 2007 Avg Visit Freq/Week = 5.06 over 180 days | Re: How do you hollow a box? I would use a round nosed scraper and if you need/want a squared up bottom, switch to a square nosed scraper toward the end. This method is a lot less "scary" and less chance of flying wood.
Rob |
07-11-2009, 07:28 PM
#3 |
Name: Mike City: Westfield State: NC County: Stokes Join Date: Dec 2005 Age: 52 Avg Visit Freq/Week = 7.00 over 180 days | Re: How do you hollow a box?
__________________ I meant to tell you, Mors Kochanski said "thats a spoon made by an expert" -BR- |
07-11-2009, 09:12 PM
#4 |
Name: Gary City: Dobson State: NC County: Surry Join Date: Jan 2006 Avg Visit Freq/Week = 3.50 over 180 days | Re: How do you hollow a box? I have used a spindle gouge on the last few I have done based on notes at Alan Leland's web site. I do majority with the spindle gouge and then do final shaping with a scraper. I admit the gouge was scary to start with but works well since I have gotten a little more practice. Make sure your tools are sharp. It was amazing how well my last box worked out after a major sharpening session!! .gif)
__________________
Effort and courage are not enough without purpose and direction!! |
07-11-2009, 09:16 PM
#5 |
Name: Jerry City: Salisbury State: NC County: Rowan Join Date: Feb 2006 Avg Visit Freq/Week = 6.69 over 180 days | Re: How do you hollow a box? Originally Posted by Bear Hello all, I am in the process of trying to hollow out a box, inside diameter about 2" and 3 1/2" deep. What tools do you use and what procedures? I have tried 6 different gouges plus a tool using the CI0 cutter. They are all scary. The wood is semi-dry cherry. Thanks for any suggestions.
Bear That size ID---------I would use a forstner bit in a heart beat. Horizontal boring on the lathe. Then clean up the bottom with a scraper.
Jerry
__________________
We make a living by what we get...............We make a life by what we give
07-11-2009, 09:17 PM
#6 | | Moderator
Name: Bob City: Hillsborough State: NC County: Orange Join Date: May 2007 Avg Visit Freq/Week = 7.00 over 180 days | Re: How do you hollow a box? I start with a forstner bit ( I know... that's cheating). Then, I switch to my Oneway Termite tool. I finish with a box scraper for a nice flat bottom and smooth sides.
__________________
To everything... turn, turn, turn!
07-11-2009, 10:20 PM
#7 |
Name: RAS City: Pikeville State: NC County: Wayne Join Date: Dec 2005 Avg Visit Freq/Week = 7.00 over 180 days | Re: How do you hollow a box? Oland tool with a fingernail grind
__________________
Earl "If you want to learn how to build a house, build a house.
Don't ask anybody, just build a house." "Oland tool, better than a bowl gouge, a lot cheaper to make." Darrell Feltmate around the woods |
07-11-2009, 11:50 PM
#8 |
Name: Ken City: Whittier State: NC County: Jackson Join Date: Mar 2009 Avg Visit Freq/Week = 6.61 over 180 days | Re: How do you hollow a box? All great ideas,I have been using the Ci 1 & 2 and I have a special scraper for cutting the recess,But I am still learning boxes.
__________________
May God Bless
07-12-2009, 12:47 PM
#9 |
Name: Bear City: Crossville State: TN County: Cumberland Join Date: Apr 2009 Age: 66 Avg Visit Freq/Week = 6.81 over 180 days | Re: How do you hollow a box? Many thanks to all of you responding with your ideas and suggestions to my dilemma with the box.
Robert: A round nose scrapper is one that I do not have but expect to have tomorrow.
The Ci0 cutter I think would have worked if the ID had been a little larger. I put my cutter on a ½ x ½ square shaft and there was not enough side clearance and I did not want to change it.
Mike: I have an Oland tool that looks just like your picture, although I have not gotten around to making a handle for it yet, still using the ¾” shaft for a handle. The problem I had with it was the lack of side clearance, the box is straight walled. I have not gotten around to making a side cutter one yet.
Gary: After trying most every tool I own, I ended up using a 5/8” fingernail ground gouge.
Jerry: That is what I ended up doing, but not having a scraper, I finished with the fingernail gouge.
Bob: No termites in my shop, and unfortunately, no scraper. I should have a scraper form Doug tomorrow.
Earl: Due to the small ID and depth, 3 ½”, my Oland tool did not work for me, I tried.
Ken: I have a Ci1 and Ci0 that I made and use them a lot, however as stated previously, there was not enough side clearance with them with the ½” square shaft that I used. I thought about milling the bottom and edges somewhat but they work so well for other projects that I am hesitant in changing them.
Due to my inexperience, I believe the relatively small ID in combination with the depth, is what caused me the difficulty. Any way it is done, I learned a lot and hopefully, the next one will be better.
Thanks again to everyone for sharing your thoughts. |
Posting Rules
Members: 3,663
Threads: 25,103
Top Poster: DaveO (14,701) | | Welcome to our newest member, Keith Senderak | |
