North Carolina Woodworker
Discounts on 2010 NCWW Calendar through Nov 30th!!
Javascript DHTML Drop Down Menu Powered by dhtml-menu-builder.com
Go Back   North Carolina Woodworker > Woodworking > Woodturning
» Upcoming Events
Fall 2009 Raffle drawing this Friday (11/20): See This Thread For Details
Closed Thread
Old 09-16-2009, 07:49 PM   #1
HF Lathe Problem.
Robert Arrowood's Avatar
City: Mount Holly
State: NC
County: Gaston
Threads: 111
Show Printable Version Email this Page   Quote this post in a PM to Robert Arrowood
Robert Arrowood Robert Arrowood is offline 09-16-2009, 07:49 PM
As I stated in another thread I've got a small problem.Mounted up a nice piece of Mahogany wanted to make a chip&dip dish.After some turning and alot of tare out.I got to looking to find the problem.Well what I found was when they welded the threaded insert in the face plate.They got it crooked.Gess I gotta take the time to give them a call.
Old 09-16-2009, 09:44 PM   #2
City: Cary
State: NC
County: Wake
Threads: 17
Avg Visit Freq/Week
= 2.92 over 180 days
Re: HF Lathe Problem.
Hi Robert,
Having just bought a 34706 myself I am really curious about the symptoms you were seeing and what procedure you used to find out that the spindle was out of whack. You mentioned tear out. Was everything that you mounted bouncing around like my stuff where if you lay your tool on top of the piece it bounces up and down instead of staying still like it should? I have been blaming myself for not mounting correctly but now I am wondering. There is still a large chance that I am causing the problem as it usually turns up after I true up the piece creating the tenon and then mount it in the chuck. I would think that however it is measured it would come down to the spindle being absolutely, or at least really, really close, to parallel with the bed. I am thinking I could use two squares but I am real curious as to how you found your problem.
Thanks very much,
Jim Lee
Show Printable Version Email this Page   Quote this post in a PM to sasjzl
Old 09-16-2009, 10:29 PM   #3
City: Mount Holly
State: NC
County: Gaston
Threads: 111
Avg Visit Freq/Week
= 6.65 over 180 days
The problem with mine is in the face plate.Check and see if the shaft "NUT SIDE" is welded straight.It don't take much on the part too make it look like a mile on the piece.The tear out was more on the inside of the bowl.I took a pencil and laid it on the tool rest and moved in slowly until it would just touch.That give me the "high" side of the piece.Hope that help's.
Old 09-16-2009, 10:34 PM   #4
jimwill48's Avatar
City: Mooresville
State: NC
County: Iredell
Threads: 86
Avg Visit Freq/Week
= 6.03 over 180 days
Tear Out is usually caused by a dull tool. I turn off center alot and that in it self has never resulted in tear out. I get it when the tool is dull and I take to heavy of cut.Even with a sharp tool you can still get tear out sometimes just due to the wood. To correct you can try shear cutting or scraping and taking lighter cuts...
__________________
Credidi me felem vidisse!
Show Printable Version Email this Page   Quote this post in a PM to jimwill48
Old 09-17-2009, 12:42 AM   #5
steelwheel1999's Avatar
City: Spruce Pine
State: NC
County: Mitchell
Threads: 102
Avg Visit Freq/Week
= 5.56 over 180 days
I have a spare if needed 1" 8tpi
__________________
Scrap Its wood You havent figured out what to do with yet!!!
Show Printable Version Email this Page   Quote this post in a PM to steelwheel1999
Old 09-17-2009, 11:04 PM   #6
City: Cary
State: NC
County: Wake
Threads: 17
Avg Visit Freq/Week
Jim wrote:
"Even with a sharp tool you can still get tear out sometimes just due to the wood. To correct you can try shear cutting or scraping and taking lighter cuts..."
My turning experience is very short but I have never been able to get rid of tear out with a sharper tool. I saw a video of a very experienced turner who saw some tear out and proceeded to try to get rid of it by cutting more. It dawned on me that tear out could be caused by the differences in the density of wood. Like when you are swimming in a lake and you feel a cold, or warm, stream of water. I have done the sharpening and scraping and putting finish on to harden the grain and sanded it in reverse but have noticed that sometimes there is nothing you can do to get rid of it. Which makes me think that it is 'in' the wood as opposed to all the factors above that we can control to some degree. My question for the more experienced turner is if it is possible to get rid of really ugly tear out that is never going to get sanded out by just taking off more wood? I have had some pieces that had such bad tear out they were not worth finishing. This has happened on both white oak and maple.
Thanks,
Jim Lee
Old 09-17-2009, 11:23 PM   #7
City: Mount Holly
State: NC
County: Gaston
Threads: 111
Avg Visit Freq/Week
Jim I haven't been turning that long myself.But what I have found"read" is that you can brake the fibers deep into the wood with a dull tool.If that happens some times you can't get it out.
Old 09-18-2009, 10:05 AM   #8
jimwill48's Avatar
City: Mooresville
State: NC
County: Iredell
Threads: 86
Avg Visit Freq/Week
That's correct, if you still have enough material thickness you can try to cut/scrape/sand out the tear-out. Sometimes you can't and will just have to live with the tear-out or abandon the piece.
One thing you can do since tear-out usually happens in the end-grain section of the bowl you can treat that area with either CA or what I use is plain old yellow or white glue diluted about 50/50 with water to stiffen the fibers so they are less apt to be pulled out. Another thing you can do with lite tear-out is to go to the 60 or 80 grit gouge and power-sand.
Again I'll stress "sharp" tools, don't be afraid to sharpen often. But sometimes their is nothing you can do, it just is.
James
__________________
Closed Thread
lathe , problem
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
[Problem-Other] Problem adding sawyer to list Mike Wilkins Help Desk 6 05-20-2008 10:46 AM
[Problem-Gallery] [Problem-Gallery] Minor problem entering Detail in photo's. KC7CN Help Desk 3 11-19-2007 01:34 AM
[Problem-Gallery] Problem viewing cskipper Help Desk 3 10-28-2007 09:47 PM
Order your 2010 Calendar!
Carolina Lumber Sourcing
» Stats
Members: 3,663
Threads: 25,104
Top Poster: DaveO (14,701)
Welcome to our newest member, Keith Senderak
» Today's Birthdays
Dick Barnes (74)
Powered by vBadvanced CMPS v3.2.0
Powered by vBulletin® Version 3.8.2
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.3.0
Template-Modifications by TMS
Content Copyright © 2005 - 2009 North Carolina Woodworker, Inc.
