WOW,thanks form all the kind words,as I really appreciate it.
Phillip I went thru the bottom,(not on purpose)
.gif)
So I just turned it around and mounted it with the cole jaws,then cleaned out the hole,then turned the ft and glued it it,then dressed it up.I do a lot of those an NONE are planned
As for the highlight rings,I remount it using my Nova chuck,then I turn up the speed as fast as I dare and mount my revolving faceplate on the tail stock so it won't fly apart and run it up against the inside bottom,using a pad so as not to scratch the inside.Then I just use a thin parting tool to cut the groove,then take a piece of piano wire and hold it in the groove untill it starts smokin.
If you try this,DON'T wrap the wire around your fingers
I have the ends taped up,so that if it does catch and pull out of my hands,I still have all parts an no cuts.
Hope this helps someone if they want to try it.
