» Upcoming Events | | Fall 2009 Raffle drawing this Friday (11/20): See This Thread For Details |  |
10-06-2009, 01:29 PM
#1 | | Bandsaw mess after cutting green wood Name: Keith City: Hayesville State: NC County: Clay Join Date: Sep 2009  10-06-2009, 01:29 PM
I have been cutting a Maple tree now for three weeks and finally got around to cleaning my Rikon bandsaw up. What a mess compared to dry wood. The table was easy with mineral spirits and paste wax but the rubber tires and blade was another story. I use it to cut the blanks as round as possible as I have a light shopsmith that does like out of round wood.
1. Do most people have a separate blade for cutting wet wood. I also build furniture and need to get a project out soon so this started the cleanup.
2. I just scraped the tires to remove the build up but didn't know if anyone uses anything on the tires.
3. Ball bearing rollers also had a build up.
4. I uses a 1" 3 tpi blade also which seems to work well. I learned on another blade not to cut round logs.
Thanks again. | | Views: 287 |
10-06-2009, 02:09 PM
#2 |
Name: Mark City: Concord State: NC County: Cabarrus Join Date: Nov 2005 Age: 54 Avg Visit Freq/Week = 6.96 over 180 days | Re: Bandsaw mess after cutting green wood Keith,
Not sure if your Rikon has a brass tire brush, but that in combination with a dust collector connected directly to the lower wheel housing (bypassing the top connection) does a good job on the green wood I've sawed. I have had a mess with some Bradford Pear when I didn't run the dust collector and the wet sawdust completely packed the lower wheel housing. Took mineral spirits and a 3M scrub pad to get the gunk off the tire. Learned my lesson on that one.
__________________
"It'll last a lifetime if you die when you're supposed to." Arval Woody, Spruce Pine, NC
10-06-2009, 05:04 PM
#3 |
Name: Matthew City: Goldsboro State: NC County: Wayne Join Date: Feb 2008 Age: 28 Avg Visit Freq/Week = 3.38 over 180 days | Re: Bandsaw mess after cutting green wood Hey Keith,
I agree with Mark, Use a DC as this will suck most of the sawdust out. The wire brush sounds like a good idea, I have the horse hair brushes, and they do alright.
I also use this blade http://www.highlandwoodworking.com/w...dsawblade.aspx and it seems to work really well.
__________________ -----Matthew----- Custom Home Audio If you want to veiw paradise simply look around and veiw it! |
10-06-2009, 05:14 PM
#4 |
Name: Ray City: Raleigh State: NC County: Wake Join Date: Dec 2007 Age: 71 Avg Visit Freq/Week = 6.65 over 180 days | Re: Bandsaw mess after cutting green wood I don't know what it meant, but I saw a blade at Klingspor's labeled "for GREEN WOOD." Maybe the set or pitch of the teeth???  |
10-06-2009, 06:31 PM
#5 | | Secretary
Name: Scott Smith City: New Hill State: NC County: Chatham Join Date: Mar 2007 Avg Visit Freq/Week = 6.53 over 180 days | Re: Bandsaw mess after cutting green wood Green wood typically cuts easier than dried wood, thus you can use a more aggressive blade / band on it. |
10-06-2009, 07:58 PM
#6 |
Name: Bob Vaughan City: Roanoke State: VA County: Roanoke Join Date: Sep 2009 Avg Visit Freq/Week = 4.44 over 63 days | Re: Bandsaw mess after cutting green wood |
10-06-2009, 08:04 PM
#7 |
Name: Ken City: Whittier State: NC County: Jackson Join Date: Mar 2009 Avg Visit Freq/Week = 6.61 over 180 days | Re: Bandsaw mess after cutting green wood When I am cutting a lot of REAL wet wood,I spray the blade with W-D 40,helps keep the rust down and the wood don't seem to stick as bad. I also use a 3/8 X 3TPI a 3/8 blade cuts better on rounding blanks,as it doen't put as much strain on the mach.
__________________
May God Bless
10-06-2009, 08:54 PM
#8 |
Name: Keith City: Hayesville State: NC County: Clay Join Date: Sep 2009 Avg Visit Freq/Week = 6.53 over 60 days | Re: Bandsaw mess after cutting green wood I have the horse hair brush on my Rikon. The dust collector sounds like it may be part of my problem. I'm not always good about using it every time I cut on the bandsaw. I ordered a smaller 3/8 green wood blade with the raker tooth. The wd40 is a good idea I'll have to try it. Thanks for all the suggestions. |
Posting Rules
Members: 3,664
Threads: 25,110
Top Poster: DaveO (14,702) | | Welcome to our newest member, Jose San Vicente | |
