» Upcoming Events |
Klingspor Wood Workers Show Case - Raleigh, NC -- September 11
Klingspor Extravaganza - Hickory, NC -- October 29 and 30
2011 North Carolina Woodworker Calendar Contest
Entry deadline by August 16th Click for more!!
Welcome New Member Chat! Every Thursday evening at 7:30pm Click here for more!
01-30-2010, 06:16 PM
#1
$2 Lathe Steady Rest
City: Wallace
State: NC
County: Duplin
This is a steady rest that I have about $2 invested in, plus some other materials I had onhand.
I started the goblet in the photo last summer. But I really messed up and turned the stem before I realized I should have hollowed out the cup part first.  So I needed a steady rest to complete it. I found a nice article in Woodturning Design Issue 23 that showed this style of steady rest. I found a used pair of rollerblades in a 2nd hand store for $5. That gave me 8 wheels but only needed 3 to make this.
I finished turning the goblet today and the steady rest worked really nice. Now I might try a bowl steady with some of the other wheels.
__________________
You can't work without tools.
So many tools so little money.
01-30-2010, 06:20 PM
#2
City: Ivan's Corner (Monroe)
State: NC
County: Union
Avg Visit Freq/Week = 6.96 over 180 days
Re: $2 Lathe Steady Rest
Looks super!
Did you dado the arms onto the ring so they wouldn't rotate off the centerline?
__________________
WHAT BOX?
01-30-2010, 06:45 PM
#3
City: Fountain
State: NC
County: Pitt
Avg Visit Freq/Week = 1.28 over 180 days
Daggone splinter i would rather have that than a storebought one, really. Neat to make your own quality tools sometimes. It really is, that is a cool design to say the least.
REally like it, thanks for sharing the edition whereby it may be found.
01-30-2010, 07:29 PM
#4
City: Lincolnton
State: NC
County: Lincoln
Avg Visit Freq/Week = 5.83 over 180 days
That's one way cool rest you got there Dolan. You did a bang up job on that and I'm really glad to see someone making their own tools that work like the "idea  " thought it would.  YOU ROCK!!
01-30-2010, 07:45 PM
#5
City: Wallace
State: NC
County: Duplin
Avg Visit Freq/Week = 3.42 over 180 days
Dennis,
I used a handheld trim router to cut the grooves 5/16" deep for the wheel arms. You want the groove just a "tad" wider than the arm so it will slid but not be sloppy. I got mine just a "smidge" wider than I wanted but they work fine.
__________________
01-30-2010, 09:44 PM
#6
State: NC
County: Union
I couldn't tell it from the pics, but I knew you'd either have to do that, or put a couple dowels in the rings for the slots to ride on. Good execution. I think I remember someone else doing one similar here last year so you haven't reinvented the wheel - but you have re used 3 of 'em!
__________________
WHAT BOX?
01-30-2010, 10:27 PM
#7
City: Charlotte
State: NC
County: Mecklenburg
Avg Visit Freq/Week = 4.74 over 180 days
Great solution to a problem! You did a nice job on that.
__________________
Never take life seriously. Nobody gets out alive anyway !
01-30-2010, 11:08 PM
#8
City: Pittsboro
State: NC
County: Chatham
Avg Visit Freq/Week = 2.57 over 180 days
That is a really nice solution to your problem. Could you give us some measurements? Is the ring made up of 2 pieces of wood screwed together? Thanks.
01-30-2010, 11:19 PM
#9
City: Baskerville
State: VA
County: Mecklenburg
Avg Visit Freq/Week = 6.57 over 180 days
Very nicely done Dolan  you seem to follow the ABC principles that I use for shop fixtures:
A - Always try to utilize what you have lying around the shop.
B - Buy used whenever possible.
C - Cobbled together in the shop as opposed to buying new is always better. .gif)
__________________
" I get knocked down but I get up again" - Chumbawamba
01-31-2010, 01:12 AM
#10
City: Goldsboro
State: NC
County: Wayne
Avg Visit Freq/Week = 3.62 over 180 days
Very Very Nice Dolan,
I need to make one of those, and a donut chuck and a long worth chuck.....
To bad your not a little closer, then we could have your shop on the Crawl. What a Shop you have, what a shop indeed~!
Thanks again for the ducting material.
__________________
-----Matthew-----
Custom Home Audio
If you want to veiw paradise simply look around and veiw it!
01-31-2010, 07:28 PM
#11
City: Wallace
State: NC
County: Duplin
Bob,
The ID of the ring is 14", the OD is 16". The article states this needs to be adjusted for whatever lathe you plan to use it on. I used two pieces of 3/4" plywood screwed together. The arms are app. 7 1/2" and 1 7/8" wide and are spaced 120 degrees apart. They need to be aligned with the center of the circle. The base needs to fit your lathe.
__________________
| Thread Tools |
| Display Modes |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
How to get discount qualified
» Stats |
Members: 4,585
Threads: 30,664
Top Poster: DaveO (15,152)
| Welcome to our newest member, JonathanK |
