» Announcements |
The Woodworking Source Grand Opening
Was a Success!!
» Online Users: 52 |
| 21 members and 31 guests |
ashley_phil
bobby g
Dudelive
gazzer
ghayes02
lhmayberry
maomoonshiner
Matt Schnurbusch
Ozzie-x
ptt49er
RayH
rcorne01
redhawknc1
SteveColes
thrt15nc
tjwitzig
tmerrill
TopKnot
Trent Mason
Woodman2k
| Most users ever online was 180, 04-22-2008 at 12:18 AM. |
04-06-2008, 03:00 PM
#1
City: Macon
State: NC
County: Warren
Avg Visit Freq/Week = 5.04 over 125 days
What makes TS inserts grow????
This has me stumped  !
I have a Delta Contractor Table Saw purchased about 3 years ago. I replaced the standard inset with a Zero clearance insert almost immediately. Now, 3+ years later, I tried to put the original insert back and it's too BIG!
I've checked/cleaned both the insert and the opening in the saw top. I even sanded around the edges of the insert HOPING the red paint had somehow swelled  . Still doesn't fit>
Has anyone ever seen this before? How can a steel/metal insert swell? Should I just scrap it and build another?
Thanks in advance for your sage advice
__________________
Randy
Being "over the hill" is much better than being under it!!!
04-06-2008, 04:27 PM
#2
City: Baskerville
State: VA
County: Mecklenburg
Avg Visit Freq/Week = 6.72 over 125 days
Re: What makes TS inserts grow????
Perhaps a check of table flatness is in order, north to south and east to west. Any table warpage would change the hole size. Just my half penny of thought . If the table is "dished" that would bring insert hole ends closer together.  Picture bending a paper plate, bending it would bring edges closer together.
__________________
" I get knocked down but I get up again" - Chumbawamba
04-06-2008, 06:28 PM
#3
City: Albemarle
State: NC
County: Stanly
Avg Visit Freq/Week = 6.89 over 125 days
Been cuttin' any alumwood on that thing?
__________________
I'm a great believer in LUCK! I find the harder I work, the more I have of it.
Thomas Jefferson
04-06-2008, 06:35 PM
#4
City: Wake Forest
State: NC
County: Wake
Avg Visit Freq/Week = 5.26 over 125 days
Not trying to be a smarta$$ but are you sure that is the original insert? Other than Glenn's suggestion, I am stumped as well.
__________________
Wife changed my perspective. I need want some additional tools. I need want a
multi-spindle line borer - unlikely in 2008
pocket hole machine - unlikely in 2008
Festool sander and vacuum -told I don't need 2 not going to happen
Edge bander - unlikely this decade
oscillating edge sander - unlikely in 2008
floor model chisel or slot mortiser - unlikely in 2008
and a bigger shop - maybe in 2009
04-06-2008, 07:01 PM
#5
City: Macon
State: NC
County: Warren
Glenn, The table is dead flat. I checked with a known straight-edge  .
Reggie, I've cut nothing but "real" wood on the saw...and very little of that  .
Travis, I know it's the original insert. I removed it shortly after purchasing the saw and replaced it with the ZC insert. It has been stored in "NEW" condition in the bottom of the extension wing....
The only reason I tried to put it back in was to cut a 45 deg. angle since the ZC insert is for 90 deg. cuts.
It is a real conundrum....
__________________
Randy
04-06-2008, 07:57 PM
#6
City: Albemarle
State: NC
County: Stanly
Randy, if you figure this one out, please let us know. You've covered all the bases my limited experience can muster. To my knowledge, metal doesn't usually grow or shrink unassisted.
__________________
Thomas Jefferson
04-06-2008, 08:19 PM
#7
Name: Alan Schaffter
City: Washington
State: NC
County: Beaufort
Avg Visit Freq/Week = 6.66 over 125 days
Maybe the insert was bent or stepped on so it is thinner, BUT wider. Did you drop something on the table top causing the throat or the edge of the throat to deflect inward? You trying to put it in backwards or upside down?
04-06-2008, 08:21 PM
#8
City: Wake Forest
State: NC
County: Wake
Is your shop heated? Have you tried it when it is cold and when it is warm out?
__________________
04-06-2008, 08:45 PM
#9
Asst. Webmaster Senior Moderator
City: Clayton
State: NC
County: Johnston
Avg Visit Freq/Week = 7.00 over 125 days
Metal, especially cast iron does move a little in response to temperature changes. That is why you can heat/freeze a fitting to get it apart. I don't know if that is your problem, but it could be
Dave
__________________
  Nothing left to do but smile, smile, smile
--Dr. Seuss
04-06-2008, 09:04 PM
#10
City: Raleigh
State: NC
County: Wake
Avg Visit Freq/Week = 6.05 over 125 days
Are you sure that the table didn't shrink? Maybe a little too much sweat dripped on it during the summer?
__________________
“Women will forgive anything. Otherwise, the race would have died out long ago”
Robert A. Heinlein
04-06-2008, 09:33 PM
#11
City: Goldsboro
State: NC
County: Wayne
Avg Visit Freq/Week = 5.94 over 125 days
If it is an aluminum insert, that may explain it as aluminum expands much more than steel or CI, but it must have been extremely close tolerance for that to happen and the weather is not that warm. I would check for a warped insert or for a shop buddy that needed to swap an insert!!  Just smack it a couple times with the dead-blow. It probably just needs an attitude adjustment.
__________________
My only regret in life is that I did not listen more and talk less
04-07-2008, 09:38 PM
#12
City: Rocky Mount
State: NC
County: Nash
Isn't there a set screw on one end of those Delta inserts...maybe it's hanging up?
I dunno, if the insert is growing I wouldn't wanna put it in, in another few years it'd likely crack the top.
Scrap it and build another. Those stock inserts are okay if rip width and the offcut are WIDE, otherwise they are an exercise in evaluating random projectile motion of wood at high velocities, and occasionally generating very neat sounds as wood is wedged then sucked through the hole/blade.
I replaced my original insert with a Delta ZCI and occasionally fill with epoxy and re-cut to get re-establish zero clearance.
Chuck
04-08-2008, 10:11 AM
#13
City: Macon
State: NC
County: Warren
Thanks for all the suggestions and wise-cracks
I haven't been sweating enough to shrink the table  .
The shop is heated and cooled. No change with temp swings.
If I can figure out how to make a ZCI for 45 degree cuts  , I'll do that.
Thanks again...This site is great!!!
__________________
Randy
04-08-2008, 10:57 AM
#14
City: Rocky Mount
State: NC
County: Nash
Maybe you could touch up the insert with a disk sander/stationary belt sander/grinder. Just mark with a pencil at the bind points. Shouldn't take much and you only use it for bevels anyway. Just a thought.
Yep, I use the stock insert for beveled cuts, too, and they aren't always 45 degrees, huh?
Chuck
04-08-2008, 11:11 AM
#15
City: Holly Springs
State: NC
County: Wake
No comment, just want to be notified when then answer comes up.
| Thread Tools |
| Display Modes |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
