North Carolina Woodworker
Discounts on 2010 NCWW Calendar through Nov 30th!!
Javascript DHTML Drop Down Menu Powered by dhtml-menu-builder.com
Go Back   North Carolina Woodworker > Tools, Equipment, and Techniques > Power Tools and Their Use
» Upcoming Events
Fall 2009 Raffle drawing this Friday (11/20): See This Thread For Details
Closed Thread
LinkBack (42) Thread Tools Display Modes
Old 05-23-2006, 12:52 AM   #1
Unisaw mobile base and table improvement w/many *PICS*
Name: Alan Schaffter
City: Washington
State: NC
County: Beaufort
Threads: 262
Show Printable Version Email this Page   Quote this post in a PM to Alan in Little Washington
Alan in Little Washington Alan in Little Washington is offline 05-23-2006, 12:52 AM
Awhile ago I posted some before pics and pics of my Unisaw stripped of its tables, fence rail, and mobile base. Here is the before pic showing the old melamine table and stock Delta mobile base with step caster and rails blocking the opening under the saw:
Here are the after pics:
The first thing I did was to make my own mobile base under the saw cabinet- casters mounted in rectangular steel tube and some leveling feet made from elevator bolts and a piece of angle mounted to the saw's sub-base.
Here is the new right extension table support and mobile base frame clamped up. Heavy steel angle was used for the horizontal table support rails to limit flexing. The leg assembly is made from square steel tubing. The rails are bolted to the Unisaw cast iron table with bolts in the existing holes. Notice the step caster at the bottom of the leg assembly (instead of under the middle of the table like in the original Delta base).
Here is the frame bolted together. I decided to have the support leg assembly (a little rusty in this pic) welded- it cost me only $20 - I don't have a welder.
Here is the leg assembly cleaned up and primed. It was messy but not too difficult to remove the scale and rust with a 3M abrasive wheel mounted in a hand drill.
The primed, painted (except the back rail- I ran out of paint), and reassembled extension table frame.
I got a newer style front Unifence rail (on Ebay?) to replace my battered old rail and installed it in this pic. It installs more easily than the older style rail since it has a bolt head slot in the back of the extrusion so you do not need to drill holes to bolt it to the table.
A Delta-style step caster (from Rockler) is mounted on the leg assembly lower cross bar.
A quarter view. The elevator bolts which level the legs are visible in this pic.
Web frame for new extension table. Unlike my assembly table which had an MDF web, I used oak for this web. I made the top from 1/2" MDF (no bottom skin) and covered it with laminate.
Here is the web for the 36" X 81" outfeed table. My new assembly table really helped out here.
I covered the extension and outfeed tables with laminate and painted the oak edging and legs black.
Another view.
This view shows that I can now put a rolling cabinet (another project) under the extension table since there are no mobile base rails nor step caster in the way.
I also added a knee-kick kill switch to stop the saw. The kick bar is covered with pipe foam insulation and wrapped with some yellow tape. A microswitch is mounted behind the left arm and wired in series with the stop button in the saw's low voltage relay control circuit- a light tap is all that is needed to shut off the saw, yet it doesn't trip unless actually pushed- works great!
I also added a drop down extension to the outfeed table behind the blade area. It is hinged to the main outfeed table and supported by a single leg attached with a spring hinge so it will fold easily. Also visible is my under-floor dust collection and the tablesaw and jointer connections.
Table up:
Table down:
Old 05-23-2006, 02:03 AM   #2
Wilmingtonian's Avatar
City: Wilmington
State: NC
County: New Hanover
Threads: 15
Avg Visit Freq/Week
= 1.67 over 180 days
Re: Unisaw mobile base and table improvement w/many *PICS*
OUTSTANDING job my friend!! I think that qualifies you for a YOU SUCK!
__________________
Show Printable Version Email this Page   Quote this post in a PM to Wilmingtonian
Old 05-23-2006, 08:18 AM   #3
Ray Martin's Avatar
City: Raleigh
State: NC
County: Wake
Threads: 98
Avg Visit Freq/Week
= 0.04 over 180 days
Alan,
When I start rebuilding things in the shop, I sure do want to invite you over for a couple of beers and some brainstorming... you've got some terrific work going on there.
Ray
__________________
I cut that board twice and it's STILL too short.
Show Printable Version Email this Page   Quote this post in a PM to Ray Martin
Old 05-23-2006, 09:41 AM   #4
woodguy1975's Avatar
City: Hickory
State: NC
County: Burke
Threads: 133
Avg Visit Freq/Week
= 4.39 over 180 days
Looks great Alan. I like the change to the HTC base. Looks like a good saw to use.
Thanks,
__________________
Keeping the Hokie Spirit Alive!! Remember 4/16/2007
First known case of the dreaded "Woodguy Disease" and is highly contagious. Stay away.... stay away! Warning! Not liable for excessive tool buying, drooling, or the sudden urge to spend large amounts of money.
www.jsrwoodworking.com
Show Printable Version Email this Page   Quote this post in a PM to woodguy1975
Old 05-23-2006, 09:50 AM   #5
Administrator
DaveO's Avatar
City: Clayton
State: NC
County: Johnston
Threads: 692
Avg Visit Freq/Week
= 7.00 over 180 days
WOW, that's all I got to say
Dave(very very impressed)
__________________
Nothing left to do but smile, smile, smile
--Dr. Seuss
Show Printable Version Email this Page   Quote this post in a PM to DaveO
Old 05-23-2006, 11:18 AM   #6
Treasurer
City: Wake Forest
State: NC
County: Wake
Threads: 184
Avg Visit Freq/Week
= 6.53 over 180 days
That looks great! You are a definite metalsmith.
Show Printable Version Email this Page   Quote this post in a PM to Travis Porter
Old 05-23-2006, 02:32 PM   #7
sapwood's Avatar
City: Durham
State: NC
County: Durham
Threads: 216
Avg Visit Freq/Week
= 6.46 over 180 days
Zounds Alan!
That setup is larger than my shop and stouter too
I love the DC pipe that disappears under the flap in the floor. Gotta be magic
Sapwood (penciling in Alan on the "Shops to See" list)
__________________
I ain't never had too much fun!
Show Printable Version Email this Page   Quote this post in a PM to sapwood
Old 05-23-2006, 03:52 PM   #8
Monty's Avatar
City: Hickory
State: NC
County: Catawba
Threads: 232
Avg Visit Freq/Week
= 2.02 over 180 days
Nice looking setup! That looks like the way a mobile base should be set up! With all that room dedicated for your saw, I'm sort of surprised that you went to so much trouble to keep the saw mobile -- I'd just be happy to have that much space! How often do you expect to have to move it? Also, how is that outfeed table attached? It will have to be removed to move the saw, right?
Between this project and that snazzy assembly table you posted before, you definitely win the "Engineer" award for the forum!!! Can't wait to see how you spice up the workbench project.
__________________
My fledgeling woodworking web site: ShootingBoard.net
Show Printable Version Email this Page   Quote this post in a PM to Monty
Old 05-23-2006, 06:47 PM   #9
City: Washington
State: NC
County: Beaufort
Threads: 262
Avg Visit Freq/Week
= 6.69 over 180 days
Thanks.
Don't know how often I'll want to move it, but I figured I might as well keep everything mobile- I'm still not sure that my tool layout is optimal. Mobility also allows me to clean underneath it- maybe . To move the saw with outfeed attached, would require that someone lift on the outfeed side of the table, or remove it- a quick 2 min. job (4 bolts).
I just hope my bench comes out as nice as yours. You inspired me. FYI, until I decide to spring for some hard maple, my bench trestle and top will be made from oak. I still have a couple of hundred board feet left from the red/white oak trees cut down when they cleared my lot two years ago.
Old 05-23-2006, 06:57 PM   #10
Executive Vice-President
Libraries Administrator
McRabbet's Avatar
City: Hendersonville
State: NC
County: Henderson
Threads: 155
Avg Visit Freq/Week
= 6.88 over 180 days
Excellent job -- I may duplicate certain features on my "widebody" Grizzly 10" cabinet saw -- I have a Shop Fox Mobile Base and an Extension unit (see link) that has a bar stabilizing the outer end of the extension wing -- I want that floor space for a saw utilities cabinet (on casters) and the bar has to go! I just need to attach the extension legs to the castered angle iron and take the bar out (I just need to be cautious when moving the saw to avoid damage to the extension table and its legs). And I like your extended shutoff switch -- great safety feature and easy to implement.
__________________
Rob Payne
Truths: There is no such thing as a 25 hour day, so why do I keep trying to cram so much into every day so it seems that way!
Show Printable Version Email this Page   Quote this post in a PM to McRabbet
Old 05-23-2006, 09:06 PM   #11
Monty's Avatar
City: Hickory
State: NC
County: Catawba
Threads: 232
Avg Visit Freq/Week
Cool... oak will be very nice for a workbench like that. It's what Woodguy's trestle bases are made of.
__________________
Old 05-23-2006, 09:19 PM   #12
Treasurer
City: Wake Forest
State: NC
County: Wake
Threads: 184
Avg Visit Freq/Week
Alan, your shop must be huge. Just looking through the pics you have posted, you have a lot of space, a whole lot of space. I initially thought it was on a slab, but I see electrical and dust collection going through the floor.
What gives? You convert the house to a shop? You a pro or planning on going pro?
Old 05-23-2006, 09:21 PM   #13
City: Washington
State: NC
County: Beaufort
Threads: 262
Avg Visit Freq/Week
I think one (like I have) or two diagonal braces between the legs and extension table rails should stabilize the legs enough so that you can remove the cross bar. It looks like you may have to attach the leg wheel assembly to the legs since it looks like it just sits on it. I want a cabinet to hold blades, inserts, miter gage, tenoning jig, etc.
Old 05-23-2006, 09:31 PM   #14
City: Washington
State: NC
County: Beaufort
Threads: 262
Avg Visit Freq/Week
I'd like to say it's just the wide angle lens, but I have a decent sized shop (could always be bigger- like can't have enough clamps) - a tad over 21' X 38' . When we built our house I wanted a good shop for a change (old one was 10' X 12') but didn't want a separate building in the back
yard, so decided enlarge the garage to 3 bays and go up, puting my shop above.
Sorry, forgot to down-size pic.
Old 05-23-2006, 10:25 PM   #15
City: Rocky Mount
State: NC
County: Nash
Threads: 115
Avg Visit Freq/Week
= 6.03 over 180 days
Alan, if you make some inserts to fill the miter slots and blade insert area you could easily play ping-pong on that table surface!
I like the finished look a lot and you did a great job on the pictorial documentary...the photos are great.
I have the "before" model in my shop. Your idea inspired me until I went to the shop with a tape measure and reality set in...still, I look for the day when I can upsize to a bigger shop and I really appreciate you sharing your ideas.
And of course, I look forward to the next project!!
Oh, BTW, great job!!
Chuck
Show Printable Version Email this Page   Quote this post in a PM to cpowell
Closed Thread
base , improvement , mobile , pics , table , unisaw , w or many
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
LinkBacks (?)
LinkBack to this Thread: http://www.ncwoodworker.net/forums/f31/unisaw-mobile-base-table-improvement-w-many-pics-3227/
Posted By For Type Date
WoodNet Forums: Show me you folding outfeed tables This thread Refback 11-03-2008 10:04 PM
WoodNet Forums: Show me your cabinet saw storage/outfeed additions please. This thread Refback 10-28-2008 03:40 PM
WoodNet Forums: Show me your cabinet saw storage/outfeed additions please. This thread Refback 10-08-2008 12:22 AM
WoodNet Forums: Show me your cabinet saw storage/outfeed additions please. This thread Refback 10-07-2008 10:14 PM
WoodNet Forums: Show me your cabinet saw storage/outfeed additions please. This thread Refback 10-07-2008 12:12 PM
WoodNet Forums: Show me your cabinet saw storage/outfeed additions please. This thread Refback 10-07-2008 02:06 AM
WoodNet Forums: Show me your cabinet saw storage/outfeed additions please. This thread Refback 10-06-2008 02:12 PM
WoodNet Forums: Show me your cabinet saw storage/outfeed additions please. This thread Refback 10-06-2008 12:48 AM
WoodNet Forums: Show me your cabinet saw storage/outfeed additions please. This thread Refback 10-05-2008 08:35 PM
WoodNet Forums: Re: Show me your cabinet saw storage/outfeed additions please. This thread Refback 10-05-2008 08:12 PM
WoodNet Forums: Show me your cabinet saw storage/outfeed additions please. This thread Refback 10-05-2008 12:13 PM
WoodNet Forums: Show me your cabinet saw storage/outfeed additions please. This thread Refback 10-05-2008 11:36 AM
WoodNet Forums: Show me your cabinet saw storage/outfeed additions please. This thread Refback 10-05-2008 11:26 AM
WoodNet Forums: Show me your cabinet saw storage/outfeed additions please. This thread Refback 10-05-2008 10:51 AM
WoodNet Forums: Show me your cabinet saw storage/outfeed additions please. This thread Refback 10-05-2008 12:10 AM
WoodNet Forums: Re: Show me you folding outfeed tables This thread Refback 09-17-2008 01:23 PM
WoodNet Forums: Show me you folding outfeed tables This thread Refback 09-17-2008 01:09 PM
WoodNet Forums: Show me you folding outfeed tables This thread Refback 09-15-2008 05:12 PM
WoodNet Forums: Mobile base for a cabinet saw with 50 fence. This thread Refback 09-12-2008 01:31 AM
WoodNet Forums: Mobile base for a cabinet saw with 50 fence. This thread Refback 09-11-2008 12:16 AM
WoodNet Forums: Mobile base for a cabinet saw with 50 fence. This thread Refback 09-09-2008 11:38 PM
WoodNet Forums: Mobile base for a cabinet saw with 50 fence. This thread Refback 09-09-2008 09:44 PM
WoodNet Forums: Show me you folding outfeed tables This thread Refback 09-09-2008 08:58 AM
WoodNet Forums: Show me you folding outfeed tables This thread Refback 09-09-2008 01:15 AM
WoodNet Forums: Mobile base for a cabinet saw with 50 fence. This thread Refback 09-08-2008 10:31 PM
WoodNet Forums: Re: Mobile base for a cabinet saw with 50 fence. This thread Refback 09-08-2008 04:19 PM
WoodNet Forums: Mobile base for a cabinet saw with 50 fence. This thread Refback 09-08-2008 04:15 PM
WoodNet Forums: Mobile base for a cabinet saw with 50 fence. This thread Refback 09-08-2008 04:05 PM
WoodNet Forums: Show me you folding outfeed tables This thread Refback 09-08-2008 02:57 PM
WoodNet Forums: Show me you folding outfeed tables This thread Refback 09-08-2008 01:02 AM
WoodNet Forums: Show me you folding outfeed tables This thread Refback 09-07-2008 06:39 PM
WoodNet Forums: Show me you folding outfeed tables This thread Refback 09-07-2008 11:31 AM
WoodNet Forums: Show me you folding outfeed tables This thread Refback 09-07-2008 08:34 AM
WoodNet Forums: Show me you folding outfeed tables This thread Refback 09-06-2008 07:16 PM
WoodNet Forums: Show me you folding outfeed tables This thread Refback 09-06-2008 02:15 PM
WoodNet Forums: Show me you folding outfeed tables This thread Refback 09-06-2008 12:03 PM
WoodNet Forums: Show me you folding outfeed tables This thread Refback 09-06-2008 08:54 AM
WoodNet Forums: Show me you folding outfeed tables This thread Refback 09-06-2008 02:14 AM
WoodNet Forums: Show me you folding outfeed tables This thread Refback 09-06-2008 12:13 AM
WoodNet Forums: Show me you folding outfeed tables This thread Refback 09-05-2008 10:50 PM
WoodNet Forums: Mobile Bases This thread Refback 08-05-2008 11:58 PM
extenstion table on a TS - Sawmill Creek This thread Refback 06-30-2008 01:07 AM
Similar Threads
Unisaw upgrade underway w/*PICS* Alan in Little Washington General Woodworking 5 09-26-2007 01:26 PM
Outfeed table base mshel General Woodworking 18 05-10-2006 12:13 PM
Workstation turned Router Table Wilmingtonian General Woodworking 8 05-08-2006 09:18 PM
Table saw mobile base chris99z71 General Woodworking 7 11-04-2005 12:14 PM
Order your 2010 Calendar!
Carolina Lumber Sourcing
» Stats
Members: 3,663
Threads: 25,101
Top Poster: DaveO (14,701)
Welcome to our newest member, Keith Senderak
» Today's Birthdays
FLEE (61)
MikeF (41)
Powered by vBadvanced CMPS v3.2.0
Powered by vBulletin® Version 3.8.2
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.3.0
Template-Modifications by TMS
Content Copyright © 2005 - 2009 North Carolina Woodworker, Inc.
