North Carolina Woodworker
Oh, Oh, Changes in Progress
Go Back   North Carolina Woodworker > Tools, Equipment, and Techniques > Power Tools and Their Use
Notices
» Announcements
The Woodworking Source Grand Opening
Was a Success!!
Featured Photos
by cranbrook2
24524 photos
10034 comments
by cranbrook2
24524 photos
10034 comments
by tmerrill
24524 photos
10034 comments
by Hook
446 photos
5 comments
» Online Users: 26
7 members and 19 guests
FredP , golfdad , jerrye , NC Scroller , Partman , rcorne01 , Splint Eastwood
Most users ever online was 180, 04-22-2008 at 12:18 AM.
Closed Thread
Old 12-02-2007, 09:02 PM   #1
This Space for rent
City: Raleigh
State: NC
County: Wake
Threads: 10
Avg Visit Freq/Week
= 3.30 over 125 days
Tablesaw Question ...
My workshop consists of a one car garage, so space is at a premium. My questions is, how close should my table saw get to the garage door. It's a Delta combination saw with a cast iron top. I'm worried that if I put the saw too closely to the door the top might start to rust. I'd really like to put it closely to the garage door so i can build an extension table, but I can't do that unless I move the saw closer to the door. If this isn't an optimal placement, is there a moisture resistant cover I can put over the saw when i'm not using it to prevent rust?
Show Printable Version Email this Page   Quote this post in a PM to Boilermaker
Old 12-02-2007, 09:15 PM   #2
Asst. Webmaster
Senior Moderator
DaveO's Avatar
City: Clayton
State: NC
County: Johnston
Threads: 563
Avg Visit Freq/Week
= 7.00 over 125 days
Re: Tablesaw Question ...
Scott, I moved your thread to the Power Tools forum as it is most appropriate there.
I don't really think that the ambient humidity of your garage shop is going to vary that much from the front to the back. So I don't think you should have much concern about greater rust potential being closer to the door. My shop is also a garage that has three walls below grade. In the summer I will run a dehumidifier to help dry the air, and I keep a good coating of paste wax on my cast iron surfaces, and I haven't had any problem with rust.
Dave
__________________
Nothing left to do but smile, smile, smile
--Dr. Seuss
Show Printable Version Email this Page   Quote this post in a PM to DaveO
Old 12-02-2007, 09:17 PM   #3
Bas is offline Bas
Asst. Webmaster
Bas's Avatar
City: Cary
State: NC
County: Wake
Threads: 115
Avg Visit Freq/Week
= 6.94 over 125 days
I don't think it matters a lot how close or how far the saw is from the garage door. Humidity tends to spread. If it is going to rust close to the door, it will rust away from the door. Ventilation helps with keeping the moisture down. Also, weatherstripping along the bottom of the garage door will help keep things sealed against rainwater (think flash flood).
Not sure if there is even such as thing as a moisture resistant cover. Either it resists water, in which case moisture will end up on your saw, or it will absorb it - which protects the saw, until the cover gets saturated.
The best protection is something like Boeshield on all the unpainted surfaces, topped off with a couple of coats of paste wax. There are other products as well, they all seem to work.
Bas.
Show Printable Version Email this Page   Quote this post in a PM to Bas
Old 12-02-2007, 09:20 PM   #4
This Space for rent
Makinsawdust's Avatar
City: Matthews
State: NC
County: Union
Threads: 10
Avg Visit Freq/Week
= 5.49 over 125 days
Scott,
Putting it close to the door probably wouldn't be a problem if you keep the door closed. Keep the top waxed with paste wax or topcote. The main thing is use the saw! It's hard for rust to form if you use it alot.
Show Printable Version Email this Page   Quote this post in a PM to Makinsawdust
Old 12-02-2007, 09:22 PM   #5
This Space for rent
Gofor's Avatar
City: Goldsboro
State: NC
County: Wayne
Threads: 47
Avg Visit Freq/Week
= 5.94 over 125 days
Mine (full cast iron top and extensions) sits about 1 to 3 foot from my garage door. I originally had it covered with a plastic sheet, but condensation seemed to form under it and caused problems even with a wax coat, not to mention my sweat in the summer. I switched to an old blanket, and that actually helped. Then I tried wiping the top with penetrol (paint flow additive available at Lowes), waxing it after the penetrol dried, and have had no further problems. I reapply the penetrol to the center section around the blade when I notice it starting to wear off (looks like a very thin film of clear lacquer). Been using it now for about a year and am happy with the results.
Have heard Boshield T9 also works well but have not tried it on a table saw. I used it a lot on boat electronics (including the outboard motor) when I lived on the Gulf coast, and was happy with the corrosion prevention.
Hope this helps
__________________
My only regret in life is that I did not listen more and talk less
Show Printable Version Email this Page   Quote this post in a PM to Gofor
Old 12-02-2007, 09:29 PM   #6
This Space for rent
BumoutBob's Avatar
City: Hendersonville
State: NC
County: Henderson
Threads: 16
Avg Visit Freq/Week
= 0.67 over 125 days
The cast iron will rust fast if it is clean. The wax coating is a good way to go. I have a 6" jointer outside under the sunroom. I keep a tarp over it. A little rust showed up in the summer but an oil type rust preventer took care of that. A small tarp that just fit over the cast iron might keep your mind at ease. Wax would be my first choice because the oil/grease types stains the wood.
Show Printable Version Email this Page   Quote this post in a PM to BumoutBob
Old 12-02-2007, 10:38 PM   #7
This Space for rent
nelsone's Avatar
City: Charlotte
State: NC
County: Mecklenburg
Threads: 130
Avg Visit Freq/Week
= 6.89 over 125 days
My band saw lives right next to the garage door and I haven't had rust problems. Put some paste wax on it and you"ll be fine, plus you get the bonus of wood sliding easier over the surface!
Show Printable Version Email this Page   Quote this post in a PM to nelsone
Old 12-03-2007, 06:32 AM   #8
This Space for rent
lottathought's Avatar
City: Garner
State: NC
County: Wake
Threads: 42
Avg Visit Freq/Week
= 2.74 over 125 days
I also have my tablesaw in the garage.
My cast iron top still looks almost new after about a year.
I put a good coat of Bosheild T9 and then I reguarly put a coat of carnuba wax for wood.
Show Printable Version Email this Page   Quote this post in a PM to lottathought
Closed Thread
question , tablesaw
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Similar Threads
Jet Tablesaw Robert Arrowood Found for Sale/Hot Deals 0 11-24-2007 08:22 AM
Tablesaw MarkW Power Tools and Their Use 14 12-17-2006 10:26 PM
tablesaw safety question lwhughes149 General Woodworking 9 10-04-2006 10:47 AM
» Log in
You last visited: at
Log Out
User Name:
Password:
Not a member yet?
Register Now!
Search Rockler.com's Extensive Woodworking Catalog
Search from over
9000 products!
Highland Woodworking Link
» Stats
Members: 2,076
Threads: 16,133
2nd Top Poster: jeff... (6,256)
Welcome to our newest member, Tom
» Today's Birthdays
None
Powered by vBulletin® Version 3.7.0
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Content Copyright © 2005 - 2008 North Carolina Woodworker, Inc.
