North Carolina Woodworker
Oh, Oh, Changes in Progress
Go Back   North Carolina Woodworker > Tools, Equipment, and Techniques > Power Tools and Their Use
Notices
» Announcements
The Woodworking Source Grand Opening
Was a Success!!
Featured Photos
by LeeNC
24524 photos
10034 comments
by skysharks
167 photos
52 comments
by ChrisC
24524 photos
10034 comments
by Larry Rose
489 photos
12 comments
» Online Users: 41
16 members and 25 guests
AlexL , dave "dhi" , DRBrifle , FredP , Joe Scharle , McRabbet , Mike Davis , mshel , RayH , redhawknc1 , rsitzejr , rywilson , skysharks , TedAS , Threejs , TracyP
Most users ever online was 180, 04-22-2008 at 12:18 AM.
Closed Thread
Old 02-05-2007, 12:11 AM   #1
MikeH's Avatar
City: Indian Trail
State: NC
County: Union
Threads: 132
Avg Visit Freq/Week
= 6.78 over 125 days
Question Table saw fence rail question
I've had my used Craftsman table saw (Model# 113-298720) for several months and have only just started using it. When I bought the saw it didn't have a fence. I bought the OEM fence as I didin't have the budget for a "real"fence. I noticed last night the the fence rail (not sure if this is the correct term) is not perpendicular to the table. It is closer to the edge of the table clasest to the blade and widens out the further you get from the blade. I hope this makes sense.
What is the best way to align the rail so the fence will sit parallel and square to the blade?
__________________
__________________________________________
Take the attitude of a student, never be too big to ask questions, never know too much to learn something new. Og Mandino
Show Printable Version Email this Page   Quote this post in a PM to MikeH
Old 02-05-2007, 08:32 AM   #2
This Space for rent
chris99z71's Avatar
City: Garner
State: NC
County: Wake
Threads: 162
Avg Visit Freq/Week
= 2.63 over 125 days
Re: Table saw fence rail question
Well, you can't move the blade. The fence is attached to the front rail and the front rail is attached to the table top. You need to loosen the table top from the base and first align the miter slots in the table so that they're parallel to the blade. Then align the fence with the miter slots. There have been several threads describing how to measure to see if everything is perfectly parallel.
This is a pretty good one that also has some other links:
http://www.ncwoodworker.net/forums/s...highlight=slot
Granted, it's not specific to your saw, but once you identify the mounting points for the table to the base, it's relatively straight forward.
Most of us here have had to do the tablesaw alignment dance at one point or another, so if you have questions - ask away!
Good luck!
__________________
"If you can't learn to do something well, learn to enjoy doing it poorly."
----9-11-01----343----Never Forget----
Show Printable Version Email this Page   Quote this post in a PM to chris99z71
Old 02-05-2007, 08:52 AM   #3
This Space for rent
Joe Scharle's Avatar
City: Holly Springs
State: NC
County: Wake
Threads: 120
Avg Visit Freq/Week
= 7.00 over 125 days
Loosen #6 and align to miter slot is what it looks like to me.
Show Printable Version Email this Page   Quote this post in a PM to Joe Scharle
Old 02-05-2007, 08:55 AM   #4
This Space for rent
chris99z71's Avatar
City: Garner
State: NC
County: Wake
Threads: 162
Avg Visit Freq/Week
True, but if your blade isn't parallel to the miter slot, you're still going to be off.
__________________
Old 02-05-2007, 09:05 AM   #5
Deceased
City: Camden
State: SC
County: Kershaw
Threads: 94
Avg Visit Freq/Week
= 0.00 over 125 days
First off I have never seen a saw with a cast top where the miter slots could be aligned with the blade.
They may exist but I have never seen one.
Since this is a belt driven saw it may be possible to realign the trunions that hold the blade but they are usually pretty accurately set.
I would look a the construction of the fence itself.
I have had inexpensive fences that were adjustable.At one time an accepted practice was to have the fence "run out" a bit at the far end to avoid kick back.
Without seeing your fence it is difficult to determine if it is adjustable.
Look for a bolt in the housing.
Show Printable Version Email this Page   Quote this post in a PM to Eaglesc
Old 02-05-2007, 09:18 AM   #6
This Space for rent
chris99z71's Avatar
City: Garner
State: NC
County: Wake
Threads: 162
Avg Visit Freq/Week
So do you mean that you've tried and it's difficult, or there is physically no way to do it?
__________________
Old 02-05-2007, 09:21 AM   #7
This Space for rent
pcooper's Avatar
City: Maiden
State: NC
County: Catawba
Threads: 12
Avg Visit Freq/Week
= 6.61 over 125 days
I have one of those saws, and the only alignment I could do was loosen the trunyon and move the blade to align with the miter slot.I used a dial indicator mounted in the miter slot to get that adjusted properly. Now the fence is another problem, and my fence now sits in the attic of my shop where it belongs since it never would properly align with the blade. You should have about the thickness of a piece of paper taper from front to rear of the fence to keep from burning the wood after you cut it, but that is all, my fence would taper almost 1/8" and I never could get it right. I tried shims on the angle iron part that the fence attaches to, and also moving the fence and the holding area where they bolt together, but still can't get any real accuracy out of it. I saved my money and got an incra system and solved the problem. I have since looked at more craftsman saws in the stores and they still have the same problem from what I can see. Granted the ones in the stores are slapped together and are not really working models until fiine tuned, but they should be better than they are out of the box IMHO. There are lots of good fences systems on the market, but I personally like the incra system best for the money. Any upgrade will make the old fence look like "barbed wire". You may have to 'make' your fence adjustable to get the accuracy you seek.
__________________
Today a pile of wood, tomorrow a pile of sawdust......
Show Printable Version Email this Page   Quote this post in a PM to pcooper
Old 02-05-2007, 09:29 AM   #8
This Space for rent
walnutjerry's Avatar
City: Salisbury
State: NC
County: Rowan
Threads: 102
Avg Visit Freq/Week
= 6.83 over 125 days
Mike--------I had the same problem with my Sears table saw. After 30 years of measuring front and back of blade to fence to set the fence parallel, I solved the problem. I bought a Vega fence and installed it.
Jerry
__________________
We make a living by what we get...............We make a life by what we give
Show Printable Version Email this Page   Quote this post in a PM to walnutjerry
Old 02-05-2007, 09:42 AM   #9
Deceased
City: Camden
State: SC
County: Kershaw
Threads: 94
Avg Visit Freq/Week
I aplogize, I miss read the original post.
The first thing to do is to make sure the rail itself is straight.If it isn't everything else is a bandaid and aggrivation.
It is not uncommon to shim the rail at the attatchment points. Everysaw that I have ever put together needed to be tweaked.
Any part of your fence that is beyond the front teeth doesn't matter, the wood has already been cut when it gets there.Look at saws made in Europe.The fence does not extend beyond the blade, that part is not necesary.
As long as the fence does not cause the wood to pince the blade causing a "kick back" situation you are O.K.
That being said parallel is better.
Old 02-05-2007, 10:56 AM   #10
MikeH's Avatar
City: Indian Trail
State: NC
County: Union
Threads: 132
Avg Visit Freq/Week
Thanks for everyone's input. I need to get a dial indicator and spend some time tweaking. I'll let you know how it turns out.
__________________
Old 02-05-2007, 11:55 AM   #11
This Space for rent
Tarhead's Avatar
City: Concord
State: NC
County: Cabarrus
Threads: 168
Avg Visit Freq/Week
= 6.89 over 125 days
Mike,
If you can wait until Sunday you can borrow my dial indicator/mag base.
As far as the fence....on my former Sears and Roebuck tablesaw I used a combination square and set it to the width of the stock I needed. Then set the square against the infeed side of the blade and slid the fence tight to the other end of the square. Repeat on the outfeed side side of the blade and recheck the infeed. Lock the fence (which moves the fence ) and recheck the measurements, unlock the fence adjust, re-lock the fence, check, unlock fence adjust, place ad on craigslist: charlotte classifieds for jobs, apartments, personals, for sale, services, community, and events, sell the saw, buy a Unisaw and a Biessemeyer fence, end of problem. Sorry...I never was very happy with the old style fence but I was able to get it close enough using a square.
Show Printable Version Email this Page   Quote this post in a PM to Tarhead
Old 02-05-2007, 11:59 AM   #12
MikeH's Avatar
City: Indian Trail
State: NC
County: Union
Threads: 132
Avg Visit Freq/Week
Originally Posted by Tarhead View Post
Mike,
Mark you're too funny. I can wait until Sunday. I can always get creative in how I set the fence.
__________________
Old 02-05-2007, 09:47 PM   #13
This Space for rent
Gofor's Avatar
City: Goldsboro
State: NC
County: Wayne
Threads: 47
Avg Visit Freq/Week
= 5.94 over 125 days
On my old Craftsman (which I no longer have), I had to shim the front rail (used washers along with the supplied spacers) to get it straight as well as parallel to the back rail. I believe there is an adjustment for the fence underneath (one or two small bolts) that allow you to align it with the blade once you get the rail straight. That said, the fence was a POC because it would not lock solid and was easy to clamp down at an angle. I always pushed in the front "t" to get it as square as possible and then still measured to the blade at front and back. A wooden mallet works well for the final tweaking.
__________________
My only regret in life is that I did not listen more and talk less
Show Printable Version Email this Page   Quote this post in a PM to Gofor
Old 02-05-2007, 09:54 PM   #14
MikeH's Avatar
City: Indian Trail
State: NC
County: Union
Threads: 132
Avg Visit Freq/Week
Thanks Go. I've found the fence to be a POC also. I like Tarhead's suggestion about listing on CL.
__________________
Old 02-05-2007, 09:54 PM   #15
This Space for rent
Gofor's Avatar
City: Goldsboro
State: NC
County: Wayne
Threads: 47
Avg Visit Freq/Week
On my old Craftsman (which I no longer have), I had to shim the front rail part # 18 (used washers along with the supplied spacers) to get it straight as well as parallel to the back rail. I believe there is an adjustment for the fence underneath (one or two small bolts) that allow you to align it with the blade once you get the rail straight. Check the length of the spacer rod (part #16) to make sure it is of the same length as the distance between the front and back rail at the table end. If the original owner put washers inside the rails against the shoulders of it, it could be pressing the outside of the rails apart.
That said, the fence would not lock solid and was easy to clamp down at an angle. I always pushed in the front "t" to get it as square as possible and then still measured to the blade at front and back. A wooden mallet works well for the final tweaking.
__________________
Closed Thread
fence , question , rail , table
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Similar Threads
