North Carolina Woodworker
Last Chance to buy Calendars @ 16.50
Go Back   North Carolina Woodworker > Tools, Equipment, and Techniques > Power Tools and Their Use
Notices
» Announcements
October 11 - Fall Gathering in Asheville
October 24 & 25 - Klingspor Extravaganza - Hickory, NC
» Online Users: 56
9 members and 47 guests
Alan in Little Washington , bitbight , BobcatBob , Canuck , erasmussen , P Crews , redhawknc1 , roweathers , TedAS
Most users ever online was 180, 04-21-2008 at 11:18 PM.
Featured Photos
by John_LA
22741 photos
10002 comments
by cranbrook2
22741 photos
10002 comments
by cranbrook2
22741 photos
10002 comments
by bluewing92
22741 photos
10002 comments
Closed Thread
Old 01-04-2008, 12:03 AM   #1
City: Durham
State: NC
County: Durham
Threads: 3
Avg Visit Freq/Week
= 0.00 over 95 days
shimming jointer cutterhead
Hi All,
I purchased a used Grizzly 8" jointer -- 3 knives, levers instead of handwheels, colored green top to bottom.
It looks like I need to shim the cutterhead on the side closest to the fence about 0.025"
I was looking at the Grizzly site for replacing standard cutterheads with indexable spiral cutterheads and read this in an online manual pdf:
"Note: Use the shims from your old cutterhead if available. If not available, newspaper is approximately 0.003" thick and will work for shimming (we don't recommend shimming more than 0.004" on either side, as this may affect how the bearing block seats in the casting)."
So, here are my questions:
1.) Am I foolish to try and shim the existing cutterhead slightly more than 5-times the recommended maximum for replacement indexable spiral cutterheads?
2.) If you have shimmed your cutterhead, how big do you cut the shims, how many do you use, and where do you place them? I was going to use two thumbnail sized ones on each side of the bearing block stud.
3.) What shim material would you use? I read on the old woodworking machines forum that someone used feeler gauges and simply broke them off. The feeler gauge that is sized for the gap that I'm addressing seems too thick to bend to the curved shape of the casting that holds the cutter.
Thanks all for your help!
Gil
Show Printable Version Email this Page   Quote this post in a PM to gilliu
Old 01-04-2008, 07:04 AM   #2
Tarhead's Avatar
City: Concord
State: NC
County: Cabarrus
Threads: 155
Avg Visit Freq/Week
= 6.93 over 95 days
Re: shimming jointer cutterhead
Gil,
Welcome to the group!
I would not shim the cutterhead first. Much better to shim the outfeed table first for gross adjustment. If you haven't already, call a helper and pull off the outfeed table, clean up and lube the base and table ways. Remove the cutterhead and pull out the knives, clean up the mounting surfaces, surface of the cutterhead, blade mounting area and reinstall the cutterhead minus the knives. Reinstall the outfeed table. Check the relationship between the outfeed table and the body of the cutterhead again. Shim the side that needs it at the top and bottom of the way with ~2"LX1"W shims. Aluminum soda can shims are ~.005" thick and they don't compress easily. Once you're close then fine tune the cutterhead mount. Don't know about newspaper???? Old feeler gauges are probably your best bet for the really fine shims. After you're good, reinstall the knives and adjust the outfeed table again.
Show Printable Version Email this Page   Quote this post in a PM to Tarhead
Old 01-04-2008, 09:00 AM   #3
City: Clayton
State: NC
County: Johnston
Threads: 122
Avg Visit Freq/Week
= 6.48 over 95 days
Gil,
You should be able to find shim stock at Fastenal, there is one on Hillsborough St. in Durham. For exact location check out their website.
www.fastenal.com
Jimmy
__________________
Jimmy
"There are no strangers here, only friends that haven't met"
I only buy what I need now, not what I want..... except for lumber !
Remember: Support your local Sawyers and Kiln Operators.
Show Printable Version Email this Page   Quote this post in a PM to JimmyC
Old 01-04-2008, 10:30 PM   #4
City: Apex
State: NC
County: Wake
Threads: 219
Avg Visit Freq/Week
= 5.97 over 95 days
First, have you set the knives, using the out feed table as your reference? This will probably eliminate the need to shim cutter head. I strongly suggest that you obtain a copy of John White's book, "Care and Repair of Shop Machines." John is the manager for Fine Woodworking's shop. Has about the best directions for setting up jointer that I have seen.
Show Printable Version Email this Page   Quote this post in a PM to junquecol
Old 01-04-2008, 11:02 PM   #5
City: Chapel Hill
State: NC
County: Orange
Threads: 44
Avg Visit Freq/Week
= 2.21 over 95 days
Gil,
I have a six inch Grizzley jointer. When I jointed boards to make panels, they were touching on each end with a gap in the middle. I shimmed the outfeed table with a piece of folded sandpaper (grit folded on itself) and it worked great for years after that. I also didn't breathe too hard on it.
Good luck!
Amy
Show Printable Version Email this Page   Quote this post in a PM to adowden
Old 01-05-2008, 12:30 AM   #6
City: Durham
State: NC
County: Durham
Threads: 3
Avg Visit Freq/Week
= 0.00 over 95 days
Hi All,
Thank you, thank you for the advice!
I have requested John White's book at the public library -- you can also read it online for free at Google books which is really nice, but I don't have a computer down in the shop. As described in his book, I plan to make some "masterbars" out of MDF tomorrow, as I don't have a straightedge as long as the entire jointer-bed.
I went to Fastenal to look for brass shim-stock and was told that the variety pack was a special order and costs $47! Too rich for me. There is a cheaper sampler pack from Lee Valley tools, but I wanted more immediate gratification and went to Harbor Freight and found feeler gauges for $3. I bought four packs -- so now I have a variety of widths for each corner of the jointer
I'll try to post some pictures of the calibrating -- the video on this site for adjusting knives is excellent. I'm still struggling with how to approach my perceived situation of having the infeed and outfeed tables fairly parallel to each other, but not at all parallel with the cutterhead. I guess I'll end up shimming the outfeed table a fair bit, the cutter head a little, and hopefully not have to resort to having too much diagonal slant to the knives seating in the cutter.
Gil
Closed Thread
cutterhead , jointer , shimming
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Similar Threads
CLT CL: Grizzly 8" Jointer w/ Spiral Cutterhead Tarhead Found for Sale/Hot Deals 4 01-01-2008 10:15 PM
Asking for a little jointer help Jim Hancock General Woodworking 12 11-03-2007 08:56 PM
MM jointer / planer 1phase, 16"jointer 3phase Raleigh Toddler Found for Sale/Hot Deals 10 05-01-2007 03:59 PM
Byrd cutterhead installation on Grizzly 0490 jointer mike_wood Power Tools and Their Use 7 01-26-2007 05:09 PM
» Log in
User Name:
Password:
Not a member yet?
Register Now!
Highland Woodworking Link
» Stats
Members: 1,931
Threads: 15,235
2nd Top Poster: jeff... (6,003)
Welcome to our newest member, Berta
» Today's Birthdays
Ray Martin
Powered by vBulletin® Version 3.7.0
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Content Copyright © 2005 - 2008 North Carolina Woodworker, Inc.
