North Carolina Woodworker
Oh, Oh, Changes in Progress
Go Back   North Carolina Woodworker > Tools, Equipment, and Techniques > Power Tools and Their Use
Notices
» Announcements
The Woodworking Source Grand Opening
Was a Success!!
Featured Photos
by McRabbet
24524 photos
10034 comments
by TXnNC
24524 photos
10034 comments
by BarryC
24524 photos
10034 comments
by Sharp Blade
24524 photos
10034 comments
» Online Users: 27
8 members and 19 guests
flatheadfisher , FredP , golfdad , jerrye , NC Scroller , Partman , rcorne01 , Splint Eastwood
Most users ever online was 180, 04-22-2008 at 12:18 AM.
Closed Thread
Old 04-15-2008, 05:23 PM   #1
This Space for rent
woodnick's Avatar
City: Tarboro
State: NC
County: Edgecombe
Threads: 47
Avg Visit Freq/Week
= 6.89 over 125 days
Sharpening turning tools
What! If any are the disavantages of using a slow speed grinding wheel for sharpening lathe chisels?
__________________
Two Twenty Two Rule:
2 Weeks to think about it...
2 Hours to fixture it...
2 Minutes to cut it.
Sharp tools cut fast and true
Show Printable Version Email this Page   Quote this post in a PM to woodnick
Old 04-15-2008, 05:26 PM   #2
This Space for rent
rsitzejr's Avatar
City: Sanford
State: NC
County: Lee
Threads: 40
Avg Visit Freq/Week
= 7.00 over 125 days
Re: Sharpening turning tools
None that I can see, the slower the speed, the less heat built up. Heat will pull the temper out of steel.
__________________
Learning to turn one stick at a time.
Show Printable Version Email this Page   Quote this post in a PM to rsitzejr
Old 04-15-2008, 05:58 PM   #3
This Space for rent
Mike Davis's Avatar
City: Westfield
State: NC
County: Stokes
Threads: 72
Avg Visit Freq/Week
= 6.83 over 125 days
To me the best wheel would be 14 inch or larger, water cooled and around 400 rpm.
Show Printable Version Email this Page   Quote this post in a PM to Mike Davis
Old 04-15-2008, 06:09 PM   #4
This Space for rent
ptt49er's Avatar
City: Charlotte
State: NC
County: Mecklenburg
Threads: 44
Avg Visit Freq/Week
= 6.38 over 125 days
Mike, how do you sharpen your chisels?
__________________
~Phillip
"Okay Hunny, so my hobby is collecting other hobbies. Atleast I'm well rounded!"
Show Printable Version Email this Page   Quote this post in a PM to ptt49er
Old 04-15-2008, 07:59 PM   #5
This Space for rent
City: Jacksonville
State: NC
County: Onslow
Threads: 8
Avg Visit Freq/Week
= 0.00 over 125 days
If your talking about dry bench grinders doesn’t matter if your using 1,700 or 3,400 rpm’s with friable wheels. Both will blue your tools and remove a lot of steel in a hurry if not careful. If your good at free hand grinding, mounting a grinding wheel on the lathe and using tool rest, gives you cheapest slow speed (under 1,000rmp) dry grinder around.
If your talking wet bench grinders, which run below a 1,000 rpm. Studies have shown edge will last longer. Now that HP sells a wet grinder for $100.00 price no longer an issue until you start buying jigs.
Both dry & wet grinders have pros & cons. You’ll find studies that say HSS tools should be sharpened on a fast 3400 rpm grinder. Obviously that contradicts what slow wet grinder proponents have to say. Some turners have both types of grinders.
Boils down to cost, how much do you want to pay for a grinder. Also your ability to get a smooth bevel (without many facets) and without changing bevel angle every time you sharpen your tools.
Been using a Sears 3400 rpm 6" grinder for years. Before that used belt sander, stones, & diamond hones which didn’t work well for me. Buying a Wolverine jig helped me with bevel consistency, and cost to replace tools as often.
Show Printable Version Email this Page   Quote this post in a PM to Wildwood
Old 04-15-2008, 08:30 PM   #6
This Space for rent
Mike Davis's Avatar
City: Westfield
State: NC
County: Stokes
Threads: 72
Avg Visit Freq/Week
Depends on the tool, I have the regular assortment except none of the newer more expensive stuff. Most often I use a small belt sander (with special 3-M belts that I order from www.trugrit.com) when the tool needs more than a touch up with the diamond hone. Which by the way works extremely well for me.
I have parts for a home made 10 inch wet grinder but not enough room to set it up, also an antique wet grinder with the same obstacle.
Mostly I have found it's not the tool that is the problem, it's how you use it. I can grind a needle on a dry grinder and not overheat the metal. (That's just an extreme example.) However, it's easier and quicker to use my belt sander.
I think a lot of folks are not comfortable sharpening so they put it off as long as possible. They think as long as the tool is cutting leave it alone.
I absolutely disagree with that way of thinking. Before it gets dull hit it with a hone to keep it fresh and sharp. Then you don't have to take off so much metal getting it back in shape. Just get in the habit of keeping a small hone in your pocket and touch up every time you stop. Same thing with your pocket knife. Don't let it get so dull that you have to work and work to get it sharp. 3 or 4 strokes on each side of the blade should bring it back to life.
Old 04-15-2008, 10:53 PM   #7
This Space for rent
Woodman2k's Avatar
City: Mooresville
State: NC
County: Iredell
Threads: 32
Avg Visit Freq/Week
"Mostly I have found it's not the tool that is the problem, it's how you use it. I can grind a needle on a dry grinder and not overheat the metal. (That's just an extreme example.) However, it's easier and quicker to use my belt sander."
I agree with Mike,I have both 1800 and 3600 ,6" and 8" grinders and use them on different tools with Wolverine and home made fixture jigs to maintain consistent angles.Regular honings with a diamond file keep the heavy re-sharpenings to a minimum.As far as bluing the tool,sometimes that doesn't mean a thing. Thanx
Sorry Mike,the quote thing didn't work.
Show Printable Version Email this Page   Quote this post in a PM to Woodman2k
Old 04-16-2008, 12:13 AM   #8
This Space for rent
AndyBarnhart's Avatar
City: Cary
State: NC
County: Wake
Threads: 91
Avg Visit Freq/Week
= 5.10 over 125 days
I am not particularly good at sharpening tools that don't have a straight edge. Actually, I am not good at straight edges either, but I have a Veritas rolling guide I use to get plane blades and chisels beveled and sharpened properly. But honing I can do. I hone my favorite carving gouges religously because I doubt I would ever get them back into the proper arc and the proper bevel without a bunch of facets if they needed grinding. The skew is my favorite spindle turning tool largely because I can actually sharpen one.
I generally did more harm than good trying to use my 6" dry grinder. I have a big cheap wet grinder that is really made more for sharpening mower blades than woodworking tools, but I can get an edge shaped on it without destroying the steel and then I go to diamond stones and then fine grit paper (from the auto parts store) stuck to a fake granite tile with spray adhesive. This is a slow process, but doesn't require much talent or funds, so it suits me pretty well...
__________________
-Andy
Wag more - bark less.
http://www.CarvedTones.com
Show Printable Version Email this Page   Quote this post in a PM to AndyBarnhart
Old 04-16-2008, 01:47 PM   #9
This Space for rent
ptt49er's Avatar
City: Charlotte
State: NC
County: Mecklenburg
Threads: 44
Avg Visit Freq/Week
What do you guys think of hand powered grinders? Like the one I've seen once or twice on Woodworks?
__________________
~Phillip
Old 04-16-2008, 02:12 PM   #10
This Space for rent
City: Cary
State: NC
County: Wake
Threads: 91
Avg Visit Freq/Week
No one should ever consider buying one of those (I have been outbid on several ). I am considering converting the cheap wet grinder (the aforementioned mower blade sharpener) into one. The cheap loud universal motor on the grinder is the thing I hate most about it. I have been checking the thrift stores nearby from time to time. My current "look for" list includes a busted meat grinder or similar mechanism. My assumption is that controlling the heat would be much easier at slow speeds.
__________________
-Andy
Old 04-16-2008, 02:28 PM   #11
This Space for rent
Mike Davis's Avatar
City: Westfield
State: NC
County: Stokes
Threads: 72
Avg Visit Freq/Week
I'd like to find an old sewing machine cabinet with the foot treadle intact. I could set up a grinder and maybe my jewelers lathe on the same table.
Old 04-16-2008, 03:46 PM   #12
This Space for rent
City: Cary
State: NC
County: Wake
Threads: 91
Avg Visit Freq/Week
There is one for sale near here for $75:
http://raleigh.craigslist.org/for/633223039.html
I have a plan for a foot powered scroll saw that I purchased on a whim, have never built and probably never will. It has a treadle flywheel plan in it that seems pretty reasonable (in fact, that was the main reason I got it; I don't like the construction of the rest of it and would have built a different table and legs). It is a PDF file. If you want, I can send it to you and if you decide to build the treadle/flywheel mechanism I will delete my copy (I am not trying to violate the license, even though I think it is no longer sold).
__________________
-Andy
Old 04-16-2008, 04:08 PM   #13
This Space for rent
Mike Davis's Avatar
City: Westfield
State: NC
County: Stokes
Threads: 72
Avg Visit Freq/Week
That sewing machine looks too nice to butcher for a frankentool.
Old 04-16-2008, 05:01 PM   #14
This Space for rent
FredP's Avatar
City: franklinton
State: nc
County: franklin
Threads: 75
Avg Visit Freq/Week
ROFL... my thoughts exactly! its worth more as an antique I think.
Show Printable Version Email this Page   Quote this post in a PM to FredP
Old 04-16-2008, 06:04 PM   #15
This Space for rent
City: Cary
State: NC
County: Wake
Threads: 91
Avg Visit Freq/Week
OK, I am veering off in the weeds a bit topic wise, but it reminds me of an interesting anecdote. My wife wanted a sewing machine cabinet; the kind the machine flips down into and all that. I did build a bench for it, rather poorly, but that's another story. Anyway, with all the perfect joins, tight tolerances and fancy mechanisms, this was a project I did not want to take on. So we went to the flea market, the indoor one up on Capitol Blvd in Raleigh, and looked at various ones. She wanted it white (painting it for her is yet another saga) so I was looking at light colored ones. But in one shop she kept insisting about a dark colored one (not a solid dark wood) that looked pretty similar to a scratched up maple one she had just passed over. I was insisting that it would be far easier for me to sand and finish or paint the other than to get this one white. Plus the other one was empty and the dark one had on old junky looking machine with rotted belts in it that I was going to have to remove and deal with. My wife was giving me that smile that says inside she is thinking of strangling me, so I bought the dark one. The price had come down substantially due to my genuine reluctance. I think I paid $30. When we got out to the car my wife finally spilled the beans - "You idiot! This machine is worth 5 times as much as mine!" All it needed was about a $50 tune up at a local sewing center and she had a top of the line machine worth several hundred dollars. But don't even get me started on how hard it is to paint pine white after it has walnut stain and lacquer on it...
__________________
-Andy
Closed Thread
sharpening , tools , turning
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Similar Threads
Sharpening Tools need help skysharks Hand Tools and their Use 21 09-26-2007 09:12 PM
Sharpening Lathe Tools Quickly & Accurately WoodWrangler Woodturning 12 09-15-2007 08:54 AM
New turning tools Dusty Sawyer Woodturning 5 01-04-2007 02:18 PM
Tools for turning bowls cskipper Woodturning 24 03-13-2006 08:56 AM
