North Carolina Woodworker
Oh, Oh, Changes in Progress
Go Back   North Carolina Woodworker > Tools, Equipment, and Techniques > Power Tools and Their Use
Notices
» Announcements
The Woodworking Source Grand Opening
Was a Success!!
Featured Photos
by Glennbear
24537 photos
10036 comments
by NZAPP1
24537 photos
10036 comments
by cranbrook2
16 photos
0 comments
by DeCe
24537 photos
10036 comments
» Online Users: 53
25 members and 28 guests
Bob T , CaptnA , cliff56 , cpowell , DaveO , FredP , gator , GregSmith , JackLeg , Joe Scharle , KurtG , matt roberts , Mike Davis , MikeL , NZAPP1 , ptt49er , rcflyer23 , rsitzejr , SteveCogs , Sully , TedAS , tom hintz , TopKnot , TracyP , Trent Mason
Most users ever online was 180, 04-22-2008 at 12:18 AM.
Closed Thread
Old 04-29-2006, 07:22 AM   #1
This Space for rent
SkintKnuckle's Avatar
City: Winston Salem
State: NC
County: Davidson
Threads: 11
Avg Visit Freq/Week
= 6.94 over 125 days
Seeking Tenon Jig Advice
I have some rough cut cherry and have an order for an end table from my daughter-in-law.
I was curious what technique is best?
1- Get a tenon jig for my table saw, any suggestions on which jig?
2- Use the table saw miter gauge and nibble away.
3- Use table saw and band saw to cut cheeks.
4- Router table.....I haven't finished my just yet.
Thanks ahead for comments.
__________________
My second name is Honey, you need to fix the .......
Show Printable Version Email this Page   Quote this post in a PM to SkintKnuckle
Old 04-29-2006, 08:38 AM   #2
This Space for rent
4yanks's Avatar
City: Southern Pines
State: NC
County: Moore
Threads: 17
Avg Visit Freq/Week
= 2.58 over 125 days
Re: Seeking Tenon Jig Advice
Any of the methods you mentioned should work fine. I cut mine on my tablesaw. I use a crosscutt sled to cut the shoulders. I have the old (heavy) style delta tenon jig that I use now for the cheeks. However, I used to use a jig that I constructed that rode against the fence to good effect. To make the jig use some 3/4 MDF or other flat material of similiar thickness. Cut 2 pieces to form the legs of a right triangle. Rabbet one side (this piece will be verticle to the saw table) to accept thickness of the other (this piece will rest horizontally on the table surface). Cut 2-3 pieces of material to serve as braces for the right angle of the main pieces. Glue and screw the whole thing together to ensure that the 2 main pieces remain at 90* to each other. Finally add a thin strip of material to the verticle surface at it's trailing edge to serve as support for your stock. Use the jig against the fence with your stock clamed vertically against it. This is a cheap and effective tenon jig that can be used for raising panels as well if it is sized properly. Hope this helps.
Show Printable Version Email this Page   Quote this post in a PM to 4yanks
Old 04-29-2006, 09:09 AM   #3
Asst. Webmaster
Senior Moderator
DaveO's Avatar
City: Clayton
State: NC
County: Johnston
Threads: 563
Avg Visit Freq/Week
= 7.00 over 125 days
One other method you didn't suggest, may or may not be applicable, is to use a dado set in either the tablesaw or RAS. I just did some tenons like that on the RAS with a stop block to keep the cheeks square.
Dave
__________________
Nothing left to do but smile, smile, smile
--Dr. Seuss
Show Printable Version Email this Page   Quote this post in a PM to DaveO
Old 04-29-2006, 09:12 AM   #4
This Space for rent
Joe Scharle's Avatar
City: Holly Springs
State: NC
County: Wake
Threads: 121
Avg Visit Freq/Week
Big, heavy type is best. If you make a raised panel jig described by 4yanks and most of us have done, make sure that it has no play on the fence and that you can clamp the work fore & aft. Real easy to cut a 'wedge' tenon otherwise.
The tenon will usually have a washboard of kerf marks and yellow glue does not fill a void.
If I must make a tenon; my first choice
Look into "loose tenons" and incorporate that into your design of your router table. Look in my gallery for a cheap example. I can route perfect mortises every time, but you wouldn't believe the amount of kindling I've made with little tabs on the ends!
Show Printable Version Email this Page   Quote this post in a PM to Joe Scharle
Old 04-29-2006, 10:56 AM   #5
This Space for rent
City: Rocky Mount
State: NC
County: Nash
Threads: 97
Avg Visit Freq/Week
= 5.26 over 125 days
I used to use 2. Now I generally use 3.
As far as 1, FWIW McRabbet has made a tenoning jig plan available in the download section http://ncwoodworker.net/forums/downl...do=file&id=110
Show Printable Version Email this Page   Quote this post in a PM to cpowell
Old 04-29-2006, 10:56 PM   #6
Libraries Administrator
McRabbet's Avatar
City: Hendersonville
State: NC
County: Henderson
Threads: 118
Avg Visit Freq/Week
= 6.78 over 125 days
Martin,
You'll find step-by-step pictures of my Loose Tenon jig in my Photo Gallery under Jigs & Fixtures. And, I have pictures of a panel raising jig that can also be used to hold stock for cutting tenons (it's just a big version of the jig that 4yanks described in his post). Hope this augments the other answers you've gotten.
__________________
Truths: There is no such thing as a 25 hour day, so why do I keep trying to cram so much into every day so it seems that way!
Show Printable Version Email this Page   Quote this post in a PM to McRabbet
Closed Thread
advice , jig , seeking , tenon
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Similar Threads
Leigh Mortise & Tenon Jig Opinions WoodWrangler Power Tools and Their Use 7 04-12-2006 10:29 PM
Woodworker needs employment advice! Barrett Miller Member Announcements 3 02-23-2006 09:49 PM
Scrollsaw advice ChrisMathes Scrollsaw Work 8 02-02-2006 10:19 AM
Finishing advice needed DaveO General Woodworking 6 10-21-2005 09:25 AM
» Log in
You last visited: at
Log Out
User Name:
Password:
Not a member yet?
Register Now!
Search Rockler.com's Extensive Woodworking Catalog
Search from over
9000 products!
Highland Woodworking Link
» Stats
Members: 2,076
Threads: 16,136
2nd Top Poster: jeff... (6,256)
Welcome to our newest member, Tom
» Today's Birthdays
None
Powered by vBulletin® Version 3.7.0
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Content Copyright © 2005 - 2008 North Carolina Woodworker, Inc.
