» Announcements |
The Woodworking Source Grand Opening
Was a Success!!
» Online Users: 33 |
| 10 members and 23 guests |
AlexL
dave "dhi"
FredP
Joe Scharle
mlzettl
mshel
NC Scroller
rsitzejr
skysharks
| Most users ever online was 180, 04-22-2008 at 12:18 AM. |
07-16-2007, 01:27 PM
#1
This Space for rent
City: Stovall
State: NC
County: Granville
Avg Visit Freq/Week = 6.78 over 125 days
Router and router table help plz
I got an older 3 1/4 HP router I think it's a Makita 3612BR. Anyways, I built a good stout router table and I mounted an external speed control. For the top I used 2 peices of 3/4 birch ply wood and cut a 1/2 thick piece of polycrylic for the insert to hang the router.
I got two problems...
* because I did such a thick top I'm having a hard time adjusting the router bit high enough - do they make an extension?
* I would like to replace the top with something that will flip up one the ends to support longer stock, something good and slick, maybe with rollers. It's not uncommon for me to rout 12' long boards. What's a good top that I can buy to slip my router in and I can upgrade with fancy gadgets over time?
The base is fine it's good and stout but it's the top that I would like to replace.
Thanks
__________________
"Do, or do not. There is no 'try'." -- Jedi Master Yoda
07-16-2007, 04:02 PM
#2
This Space for rent
City: Wake Forest
State: NC
County: Wake
Avg Visit Freq/Week = 5.26 over 125 days
Re: Router and router table help plz
You need to recess the router into the top. Say use a straight bit to leave a 1/4" to 1/2" of thickness. That is my first suggestion.
As for a top, mileage varies. Cheap and dirty would be to go and buy a sheet of melamine and rip it down to the width you want. Again, recess the router into the top.
07-16-2007, 04:33 PM
#3
This Space for rent
City: Charlotte
State: NC
County: Mecklenburg
Avg Visit Freq/Week = 7.00 over 125 days
Hey Jeff - So what are you routing in 12' long boards ?!?
Inquiring minds want to know
pete
07-16-2007, 06:47 PM
#4
This Space for rent
City: Washington
State: NC
County: Beaufort
Avg Visit Freq/Week = 6.33 over 125 days
I have one of these extensions in my table. I really like it. It makes for easy one-handed bit changes above, and it seems very well balanced.
http://www.amazon.com/Router-Technol...dp/B000EXQ2FA/
HTH
__________________
Humility is being corrected by your 4 year old on a woodworking project.
07-16-2007, 07:08 PM
#5
This Space for rent
City: Southern Pines
State: NC
County: Moore
Avg Visit Freq/Week = 2.58 over 125 days
MDF makes a really slick surface if you finish it with a few coats of wiping polyurethane, and it's dirt cheap as material go these days. Make sure to finish both sides to prevent warping. If it is well supported underneath 3/4" MDF will remain reasonable flat (which is all I have come to expect). Sand the final coat to 600 grit and wax, and 12' boards will glide across.
07-16-2007, 09:47 PM
#6
This Space for rent
City: Stovall
State: NC
County: Granville
pete
Bull nose deck plank, it's better than walking 12' 4 times with a router spinning a 1/2 round over bit
__________________
07-16-2007, 09:50 PM
#7
This Space for rent
City: Stovall
State: NC
County: Granville
Originally Posted by jwaterdawg
That is exactly what I'm looking for - just ordered one.
Thanks man !!!
Now for the top, I think I'll just build something so I can attach a 12" roller on each side and call it done for now. I still would like to find a good top.
Thanks
__________________
07-18-2007, 06:42 PM
#8
Libraries Administrator
City: Hendersonville
State: NC
County: Henderson
Thanks
Jeff,
I may be too late with this, but I have the 1/2" version of this Router Bit extension from MLCS and it works fine.
__________________
 Truths: There is no such thing as a 25 hour day, so why do I keep trying to cram so much into every day so it seems that way!
07-19-2007, 10:17 AM
#9
This Space for rent
City: Raleigh
State: NC
County: Wake
Avg Visit Freq/Week = 2.46 over 125 days
Jeff:
I have a Freud table insert for their FT3000 (3 1/4 hp model) which has two rings that can be inserted for different size bits. I also have a wooden insert that fits around it (took quite some time). It may fit your router (they look very similar), but if not, you can drill new holes.
I would be glad to trade for wood.
919-420-0267 (Raleigh)
| Thread Tools |
| Display Modes |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
Similar Threads
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
NYW Router Table
MikeF |
Power Tools and Their Use |
12 |
12-11-2006 05:12 PM |
Router Table Plans and Router
Travis |
General Woodworking |
3 |
11-15-2006 03:12 PM |
Router table
erasmussen |
5 |
07-24-2006 11:41 PM |
Router Table
smessick |
17 |
09-07-2005 10:27 PM |
» Stats |
Members: 2,076
Threads: 16,133
2nd Top Poster: jeff... (6,256)
| Welcome to our newest member, Tom |
» Today's Birthdays |
None
