North Carolina Woodworker
Calendar Voting Has Begun Read This First
Go Back   North Carolina Woodworker > Tools, Equipment, and Techniques > Power Tools and Their Use
Notices
» Announcements
September 8 - Voting Begins
September 27 - Southern Raleigh Shop Crawl
October 11 - Fall Gathering in Asheville
October 24 & 25 - Klingspor Extravaganza - Hickory, NC
Featured Photos
by John Jankowski
160 photos
50 comments
by Threejs
101 photos
7 comments
by BBF
21740 photos
6210 comments
by Mike W.
21740 photos
6210 comments
Closed Thread
Old 06-13-2008, 12:50 PM   #1
davejones's Avatar
City: Stokesdale
State: NC
County: Guilford
Threads: 12
Avg Visit Freq/Week
= 3.08 over 66 days
Ridgid Jointer
Well, I am getting close to my next tool purchase (6" jointer).
I was looking at the Ridgid JP0610 and read somewhere that it has a minimum 3/4" thickness (due to the blade guard).
For those of you that own this machine, has this ever been a problem for your? How often do you need to face joint material thinner than 3/4"?
Do other 6" jointers in this price range have similar restrictions? Any recommendations for other jointers in this price range?
Thanks in advance!
Dave
Show Printable Version Email this Page   Quote this post in a PM to davejones
Old 06-13-2008, 01:14 PM   #2
City: Gastonia
State: NC
County: Gaston
Threads: 11
Avg Visit Freq/Week
= 6.26 over 66 days
Re: Ridgid Jointer
Dave,
I have this jointer and forgot that the minimum thickness was 3/4". It has never been an issue with me, but I usually use it to face joint thicker stock on the way to the planer anyway - not an issue for edge jointing.
See Tom's review (and the jointer I later bought from him) on his site.
This jointer has worked fine for me and I recently replaced the knives (after a broken drywall screw snuck through on a piece of free Walnut). The only real headache was finding a mobile base - ended up using the Rockler base kit.
Greg
__________________
Show Printable Version Email this Page   Quote this post in a PM to GregSmith
Old 06-13-2008, 02:16 PM   #3
Bas is offline Bas
Bas's Avatar
City: Cary
State: NC
County: Wake
Threads: 90
Avg Visit Freq/Week
= 7.00 over 66 days
Re: Ridgid Jointer
I have the Grizzly 6" jointer (G0452). It has similar limitations.
If the stock is too thin, it won't move the blade guard out of the way. This is actually quite a stupid design, because stock that's just thick enough might get trapped this way, especially if it starts out being thick enough but repeated passes over the jointer make it too thin. To joint thinner stock, you can remove the blade guard of course. That's not very safe. Many people have made their own fixed guards using Lexan.
The main reason for not jointing thin stock is the danger of it breaking apart or getting caught somewhere and kicking back. I don't think there is anything dangerous in jointing a 4" wide 1/2" thick 3' long board of poplar. But I would not want to joint an 1" wide 1/4" thick 8' long board of Balsa. That's asking for trouble. Get a drum sander if you need to work with a lot of thin stock.
The Grizzly is comparable to the Ridgid. JET also makes a good 6" jointer. Lowe's has the 6" Delta on sale right now, in some places as low as $92 (normally ~$360)! Add a $10 off coupon and you've got a real steal. The Delta has an open stand, not an enclosed base, so dust collection isn't stellar. They appear on Craig's List fairly regularly as well. The main reason I got the G0452 is because of the built-in mobile base.
__________________
Bas.
I don't need it. I just want it.
Show Printable Version Email this Page   Quote this post in a PM to Bas
Old 06-13-2008, 03:32 PM   #4
City: Raleigh
State: NC
County: Wake
Threads: 9
Avg Visit Freq/Week
= 1.27 over 66 days
Re: Ridgid Jointer
To compensate for poor designs come off an engineers desk and never get tested by said engineer (speaking here as a proud graduate from the College of Engineering at NCSU!)...
I would suggest a little time with tin snips, a drill and a tap:
Get some aluminum roof flashing and cut a strip the length of the opening curve on the blade guard, and wide enough to just clear the blades. Next drill and tap a few holes for say 6-32 screws in the edge of the bald guard. Punch matching holes in the flashing strip and screw it in place.
The benefits of this idea:
1) Aluminum flashing is thin enough and soft enough that it should not injure your blades if they come in contact with each other.
2) This strip is replaceable if it ever get damaged.
3) Less chance of a jam.
All of that said I will LOUDLY agree that a drum sander is the better choice for thin or narrow stock.
Chris Tully
Show Printable Version Email this Page   Quote this post in a PM to cptully
Old 06-13-2008, 04:40 PM   #5
erasmussen's Avatar
Name: earl rasmussen
City: Pikeville
State: NC
County: Wayne
Threads: 117
Avg Visit Freq/Week
= 6.68 over 66 days
Re: Ridgid Jointer
I got the ridgid its never been a problem for me
__________________
Earl
"If you want to learn how to build a house, build a house.
Don't ask anybody, just build a house."
"Oland tool, better than a bowl gouge, a lot cheaper to make." Darrell Feltmate around the woods
Show Printable Version Email this Page   Quote this post in a PM to erasmussen
Old 06-13-2008, 05:51 PM   #6
Webmaster
Senior Moderator
Advisory Panel
DaveO's Avatar
City: Clayton
State: NC
County: Johnston
Threads: 533
Avg Visit Freq/Week
= 7.00 over 66 days
Re: Ridgid Jointer
I have it and have jointed stock thinner than ¾", maybe down to ½". I use push blocks and allow the front push block to push the fence open and then hand over hand the stock the rest of the way through. Not the best method but it works for the very few times I have needed to work that thin of stock.
Chris's solution would be smarter if you are going to joint thinner stock often.
Dave
__________________
Nothing left to do but smile, smile, smile
--Dr. Seuss
Show Printable Version Email this Page   Quote this post in a PM to DaveO
Old 06-13-2008, 09:43 PM   #7
Shayne's Avatar
City: Raleigh
State: NC
County: Wake
Threads: 10
Avg Visit Freq/Week
= 5.09 over 66 days
Re: Ridgid Jointer
Ditto to what Dave said. The few times I've had ~1/2 stock I just used the push blocks. As long as you expect the guard not to move until you make contact with push blocks, it's not a big deal. The first time I did it, I didn't realize this would happen so it was a little bit of surprise as I was pushing the stock threw
Show Printable Version Email this Page   Quote this post in a PM to Shayne
Old 06-13-2008, 09:57 PM   #8
Senior Moderator
newtowood's Avatar
City: Salisbury
State: NC
County: Rowan
Threads: 125
Avg Visit Freq/Week
= 7.00 over 66 days
Re: Ridgid Jointer
I have the Ridgid also and so far it has been a good jointer. I built a plywood base for it and put casters on it. It is actually very solid even without the casters locked. It was cheaper than purchasing a good mobile base.
__________________
Tracy
Making Friends One Post At A Time
Show Printable Version Email this Page   Quote this post in a PM to newtowood
Old 06-14-2008, 10:20 AM   #9
davejones's Avatar
City: Stokesdale
State: NC
County: Guilford
Threads: 12
Avg Visit Freq/Week
= 3.08 over 66 days
Re: Ridgid Jointer
Thanks for all the info.
I had given up on the Delta JT360 since I hadn't seen one in either of my local Lowe's stores for quite some time. After I read Bas' thread yesterday and the other thread about finding one for $92, I started calling darn near every Lowe's in NC. Finally found one in Pittsboro for $202, which I will be picking up later today!!! Not the $92 dollar steal that someone else got, but still a great deal!
I will have to check out the Delta's blade guard and see whether I will need to modify it or not. I probaly won't be using thin stock all that often anyways, so the push block trick may work just fine.
Pics and formal gloat to come....
Closed Thread
jointer , ridgid
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Similar Threads
Quickly, I Need Info on Gray RIDGID Jointer LeftyTom Power Tools and Their Use 4 08-28-2007 07:02 PM
MM jointer / planer 1phase, 16"jointer 3phase Raleigh Toddler Found for Sale/Hot Deals 10 05-01-2007 03:59 PM
Ridgid Floor DP and Ridgid 14" Bandsaw - Raleigh CL $175 Each woodworker2000 Found for Sale/Hot Deals 0 03-26-2007 04:10 PM
» Log in
User Name:
Password:
Not a member yet?
Register Now!
» Stats
Members: 1,841
Threads: 14,773
2nd Top Poster: jeff... (5,858)
Welcome to our newest member, scowie
» Today's Birthdays
b4man
Highland Woodworking Link
Powered by vBulletin® Version 3.7.0
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
