| Re: Replacing jointer knives The problem and risk comes from the extra thickness of trying to get 1/8" knives in there. The lock bar (gib, shim, whatever) is backed so close to the hex head screws that only a ground skinny wrench will get in the slot. When a 5/16" wrench is ground that skinny, it has a tendency to spread over the flats before the proper torque can be applied. This means a possible risk of slinging a knife. When the old Delta jointers sling a knife its usually when an unfamiliar operator tries to put 1/8" knives in a used jointer that's new to them. There's no guarantee that a knife will come out, but the risk is higher. I've seen many of the older Delta machines that people are using 1/8" knives in them with no knife slinging, but once they realize the risk, few continue the practice.
1/8" carbide knives in Delta jointers are particularly insidious about coming out, I guess because they are so heavy and slick.
For a setting video, Google: bob vaughan + jointer |
