North Carolina Woodworker
Oh, Oh, Changes in Progress
Go Back   North Carolina Woodworker > Tools, Equipment, and Techniques > Power Tools and Their Use
Notices
» Announcements
The Woodworking Source Grand Opening
Was a Success!!
Featured Photos
by lwhughes149
24537 photos
10036 comments
by Jim Murphy
24537 photos
10036 comments
by jtodd71
24537 photos
10036 comments
by rococojo
24537 photos
10036 comments
» Online Users: 48
17 members and 31 guests
Bas , Boilermaker , Canuck , cpowell , flatheadfisher , FredP , John Jankowski , NC Scroller , NCPete , nelsone , ptt49er , RayH , rsitzejr , Sealeveler , Tarhead , Travis Porter , Turtlewood
Most users ever online was 180, 04-22-2008 at 12:18 AM.
Closed Thread
Old 01-21-2008, 06:10 PM   #1
This Space for rent
Badabing's Avatar
City: Charlotte
State: NC
County: Mecklenburg
Threads: 28
Avg Visit Freq/Week
= 3.98 over 125 days
New grinding wheel problem
Need some help
I have an 8'' variable speed bench grinder. I'm using it mostly to sharpen lathe tools. It came with a 60 grit gray wheel and a wire wheel. I thought I'd replace the wire wheel with a white aluminum oxide wheel so today I got a Camel brand 8'' white AO wheel. Mounted it and there is a lot of vibration. Looks like the wheel is not perfectly round. I had to readjust it twice to get it to turn without wobble too.
My first question is how good are the plastic arbor spacers? This wheel has a few concentric plastic spacers so that the arbor is adjustable from 1/2'' to 1 1/4''. Could these be the problem?
Second question: how do you dress a wheel? Is it different for the white AO versus the gray one? The grinder came with a dressing tool (star wheels). Should I use that or do I need a diamond dresser?
OK, that was more than two questions, forgive me
Anybody have experience with grinding wheels and can offer some advise?
__________________
Ciao,
http://www.joeswoodstuff.com
If you cannot laugh at yourself, you have not earned the right to laugh at others. -- I said that.
Show Printable Version Email this Page   Quote this post in a PM to Badabing
Old 01-21-2008, 06:46 PM   #2
Asst. Webmaster
Senior Moderator
DaveO's Avatar
City: Clayton
State: NC
County: Johnston
Threads: 563
Avg Visit Freq/Week
= 7.00 over 125 days
Re: New grinding wheel problem
All a dressing or truing tool does is remove part of the wheel to either expose new grit or correct an out-of-round/flat situation. I would think that the star wheel dresser would do as well as the diamond dresser for that job. If the situation is really bad and the vibration is extreme, you might return the wheel (things are made on a Monday or Friday ) and get a new one, or you could get a Oneway Wolverine wheel dresser and get it dead on - http://www.oneway.ca/sharpening/dressing_jig.htm
I doubt that the arbor spacers are bad, modern technology ought to be able to produce those consistently. But seeing as the wheels are "baked" to create their consistency, I could see how something could be un-precise.
I would return the wheel and try another.
Dave
__________________
Nothing left to do but smile, smile, smile
--Dr. Seuss
Show Printable Version Email this Page   Quote this post in a PM to DaveO
Old 01-21-2008, 06:59 PM   #3
Canuck's Avatar
City: Cary
State: NC
County: Wake
Threads: 134
Avg Visit Freq/Week
= 6.94 over 125 days
I recently had the same type of an issue with an 8" Norton 120 grit wheel I had ordered from Hartville Tool. It wobbled like crazy!!!
I packaged it up and returned it. The new wheel (replacement) is much better but still needed a tad of dressing. Running pretty well now.
Good luck!
__________________
..............found out many years ago that Elbow Grease doesn't come in a bottle!!!!
Show Printable Version Email this Page   Quote this post in a PM to Canuck
Old 01-21-2008, 07:05 PM   #4
This Space for rent
meika123's Avatar
City: Advance
State: NC
County: Davie
Threads: 48
Avg Visit Freq/Week
= 0.17 over 125 days
Originally Posted by Badabing View Post
Need some help
To attempt to answer your question. I have both the bench grinder and a "Square Wheel" belt grinder. I use the bench grinder for just casual rough work. But if I want to remove a lot of material in a short time, nothing beats a 36-60 grit belt. I used to be a knife maker, and used the belt for grinding blades. As far as sharpening chisels, etc, nothing beats the belt.
As for the dresser, I use the metal handled star wheel dresser. I also have the solid carbide dressing stick, but the wheels work much better.
Mind you, you can still use the grinding wheel perfectly well, but I prefer the belt.
__________________
Dave in NC
"A man's gotta know his limitations"!
Show Printable Version Email this Page   Quote this post in a PM to meika123
Old 01-21-2008, 07:43 PM   #5
This Space for rent
City: Jacksonville
State: NC
County: Onslow
Threads: 8
Avg Visit Freq/Week
= 0.00 over 125 days
Would make sure when installing a new wheel on a grinder you don't over tighten the nut. Hand tight works find. So don't grab a wrench and try for crazy tight. I hold onto the other wheel when tightening the nut by hand.Once I install a new wheel will spin by hand to see if its got any noticeable wobble, before turning. If looks okay will turn on grinder for a few minutes and let the wheel get happy. If wheel is wobbling after coming up to speed and a light pass with the dresser won't fix it will return the wheel for a new one. A star dresser will work but you need a very light touch, same is true for a diamond dresser. I prefer the diamond dresser only because I do less damage with it. Have both the wolverine and single point diamond dresser. I've had good luck with Norton wheels from sharpeningsupplies.com. I also change out both wheels at the same time. Good luck.
Show Printable Version Email this Page   Quote this post in a PM to Wildwood
Closed Thread
grinding , problem , wheel
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Similar Threads
Wobbly grinder wheel woodArtz Power Tools and Their Use 11 06-22-2007 08:51 PM
Tormek Leather honing wheel SteveColes Hand Tools and their Use 5 06-14-2006 11:31 PM
Ceramic Grinding wheel Handturnedbowls Reviews 2 04-26-2006 04:13 PM
Marking Wheel Joe Scharle General Woodworking 2 10-14-2005 05:57 PM
» Log in
You last visited: at
Log Out
User Name:
Password:
Not a member yet?
Register Now!
Search Rockler.com's Extensive Woodworking Catalog
Search from over
9000 products!
Highland Woodworking Link
» Stats
Members: 2,076
Threads: 16,136
2nd Top Poster: jeff... (6,256)
Welcome to our newest member, Tom
» Today's Birthdays
None
Powered by vBulletin® Version 3.7.0
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Content Copyright © 2005 - 2008 North Carolina Woodworker, Inc.
