North Carolina Woodworker
Oh, Oh, Changes in Progress
Go Back   North Carolina Woodworker > Tools, Equipment, and Techniques > Power Tools and Their Use
Notices
» Announcements
The Woodworking Source Grand Opening
Was a Success!!
Featured Photos
by rococojo
24524 photos
10034 comments
by BumoutBob
376 photos
14 comments
by Pop
24524 photos
10034 comments
by Douglas Robinson
24524 photos
10034 comments
» Online Users: 31
9 members and 22 guests
dave "dhi" , FredP , McRabbet , mlzettl , mshel , NC Scroller , rsitzejr , Splint Eastwood , woodylarry
Most users ever online was 180, 04-22-2008 at 12:18 AM.
Closed Thread
Old 08-22-2007, 07:20 PM   #1
Member
Advisory Panel
gator's Avatar
City: Oxford
State: NC
County: Granville
Threads: 120
Avg Visit Freq/Week
= 6.78 over 125 days
Needed: Compressor Operation for Dummies
Sometimes this old brain just doesn't understand things. Let me explain what I think I know and then chime in with what is real.
The air you use to run air tools comes directly from the holding tank via pressure valves/gauges. If a compressor is rated at say, 7CFM@40PSI/4.9CFM@90PSI/4.3CFM@115PSI, that is the rating of the compressor pump and how fast and at what pressure it fills the tank. Thus if I have an air compressor that came with the first rating and find a pump/motor that is rated at say 7.76CFM@115PSI and put this pump/motor on my tank, would my tank output still be at what it is now or would it go to the higher spec. Remember, I have not changed the valves/gauges on the output side of the tank. In other words, is the rating of an air compressor related to the pump/motor and how fast it fills the tank or to the effeciency of how well you get the air out of the tank to the tool. To me the two are not directly related. (I do realize that if you take more from the tank than can be replaced in the same amount of time, then the compressor will run behind and run continous). All this being the case why can one not run high CFM tools from a holding tank, just in shorter spurts as the pump tries to catch up?
Confused!!!!!
George
__________________
2B1ASK1
Show Printable Version Email this Page   Quote this post in a PM to gator
Old 08-22-2007, 07:46 PM   #2
This Space for rent
FredP's Avatar
City: franklinton
State: nc
County: franklin
Threads: 75
Avg Visit Freq/Week
= 7.00 over 125 days
Re: Needed: Compressor Operation for Dummies
the motor and pump determin CFM@??? PSI. the size of the tank doesnt matter much. a larger tank will take longer to fill than a small tank if the CFM@PSI is the same because it holds more air. however for high consumption tools a larger tank allows you to use the tool for longer periods of time before the pump kicks in and if the CFM@PSI is large enough you could run the tool as long as you like because the pump will replace the tank air faster than the tool uses it. small tanks can be used for most air tool but in moderation. any motor and pump needs to cool or they will stop working in short order. using a high volume tool off a small tank even with a high CFM motor and pump will eventually burn up the compressor because it will run hot unless you let it cool down between those short bursts. my shop compressor puts out around 17 CFM@ around 100 psi. but it only has a 40 gallon tank so things like sandblasters would require a break every now and then to allow the motor and pump to cool. I can use a blow nozel or impact wrench continuousely and the compressor will cycle fine however i do let it cool down once in a while just because. [ because i realy like my compressor! ]
fred p
__________________
fred p
carpenter by trade... idiot by design.
www.ncwoodencreations.com
Show Printable Version Email this Page   Quote this post in a PM to FredP
Old 08-22-2007, 10:28 PM   #3
This Space for rent
City: Wake Forest
State: NC
County: Wake
Threads: 129
Avg Visit Freq/Week
= 5.26 over 125 days
Totally agree with Fred. One side note, on most compressors I have seen there are no valves or such on the output unless you install one yourself. The hook up is straight off of the tank. The pressure switch is in between the compressor and the tank and kicks on and off when the tank reaches certain pressures just like a well pump pressure switch does.
Show Printable Version Email this Page   Quote this post in a PM to Travis Porter
Old 08-22-2007, 11:09 PM   #4
Member
Advisory Panel
gator's Avatar
City: Oxford
State: NC
County: Granville
Threads: 120
Avg Visit Freq/Week
I think that all compressors have a pressure adjust valve on the output line. I can adjust my output pressure from about 20PSI to 115PSI. It has two gauges, one showing tank pressure and one showing output line pressure. Output line pressure will never be higher than tank pressure.
But, I guess the basic question from all my ramblings was if I want to run a spray gun needing 6.5 CFM but my compressor is rated at 4.3, I can do it but only in spurts, and trying to upgrade only allows the tank to fill faster. Or, is there something I am missing and I really need a compressor rated at 6.5 or higher before I can run that spray gun. You know how people say the pancake types won't run spray gun but if I only run it for 10-15 seconds, wouldn't it work?
George
__________________
2B1ASK1
Old 08-22-2007, 11:31 PM   #5
This Space for rent
Gofor's Avatar
City: Goldsboro
State: NC
County: Wayne
Threads: 47
Avg Visit Freq/Week
= 5.94 over 125 days
It sounds like the compressor/motor are fine, but you have volume limiting restrictions between them and the tool. Your problem may be the fittings between your air compressor tank and your tool. 1/4" NPT fittings/hoses do not allow enough volume of air to supply an HVLP gun for example regardless of the tank pressure. If your regulator, oil/water separator, etc are 1/4" NPT fittings, you probably are not getting the volume needed to supply the tool. You may get by with one 1/4" fitting (ie, the 20 gal tank exit), but by the time you add the regulator, several quick disconnects, and a few feet of 1/4" id hose, you cannot get the volume of air you need without upping the pressure to 300 psi. Try upgrading the regulator to a 3/8 ID min inlet/outlet fitting, quick disconnects (air hose fittings) to "high volume" (normally 5/16" id), and go with a minimum 3/8" air hose until you get to within 5" of the tool. If you can go with a larger ID fitting coming out of the tank, do so. The regulator is most likely your main restriction.
__________________
My only regret in life is that I did not listen more and talk less
Show Printable Version Email this Page   Quote this post in a PM to Gofor
Old 08-23-2007, 12:13 PM   #6
This Space for rent
DavidF's Avatar
City: Pittsboro
State: NC
County: Chatham
Threads: 157
Avg Visit Freq/Week
= 4.03 over 125 days
George
I would say yes, you can run the gun for short bursts, unless the volume of air you are consuming robs the tank so quickly that the available pressure goes below that required. I run my tank outlet at 90psi and re regulate to 30psi at the gun when spraying with HVLP. If you drop below 25 - 30psi at the gun then you will not get good atomization. With other high volume tools it is not quite so important as they just stop working!
__________________
"There is no trouble so great or grave that cannot be much diminished by a nice cup of tea" Bernard-Paul Heroux
Show Printable Version Email this Page   Quote this post in a PM to DavidF
Old 08-23-2007, 01:40 PM   #7
This Space for rent
FredP's Avatar
City: franklinton
State: nc
County: franklin
Threads: 75
Avg Visit Freq/Week
the problem with spraying finish from too small a tank and less than required CFM is you may run out of air before you get to a stopping point that is condusive to a good finish. IE... if you need to make four passes and run out of air after only 2 passes your finish will suffer.
fred p
__________________
fred p
Old 08-23-2007, 02:03 PM   #8
This Space for rent
jeff...'s Avatar
City: Stovall
State: NC
County: Granville
Threads: 441
Avg Visit Freq/Week
Don't know about you guys but I love my air tools
__________________
"Do, or do not. There is no 'try'." -- Jedi Master Yoda
Show Printable Version Email this Page   Quote this post in a PM to jeff...
Old 08-24-2007, 07:48 AM   #9
NCPete's Avatar
City: Hope Mills
State: NC
County: Cumberland
Threads: 204
Avg Visit Freq/Week
= 6.94 over 125 days
gator, I have an air tank you could use to increase your available capacity, it was my plan to put it in line with my pancake compressor to increase available air, but then found to good a deal on a 2hp (almost real 2hp- one of the re-rated machines formerly labled 6 hp at sears) compressor with a 33 gallon tank. lemme know, we can make the North Carolina Woodworker Express go to work!
__________________
Failure is the opportunity to begin again more intelligently. – Henry Ford
However your life is, meet it and live it.
Henry David Thoreau
They that can give up essential liberty to obtain a little temporary safety, deserve neither liberty, nor safety. Benjamin Franklin
Show Printable Version Email this Page   Quote this post in a PM to NCPete
Old 08-24-2007, 08:19 AM   #10
Member
Advisory Panel
gator's Avatar
City: Oxford
State: NC
County: Granville
Threads: 120
Avg Visit Freq/Week
Pete,
Thanks for the offer but I have a 21 gal compressor now. The first specs I listed, the lower ones, are the specs of the one I have now. I saw a reasonably good deal on a 5HP pump and motor and was considering upgrading but after thinking I came up with the supposition I made in my original post. That is, that a bigger pump and motor wouldn't do anything except fill my tank faster and that I really would not have any more capacity (CFMvsPSI) in real life than I do now.
George
__________________
2B1ASK1
Old 08-24-2007, 11:41 AM   #11
This Space for rent
City: Wake Forest
State: NC
County: Wake
Threads: 129
Avg Visit Freq/Week
IMO, with a 21 gallon compressor, you can do some spraying. When the compressor starts up, it is time to finish that pass and let it catch up a bit. Adding an extra tank to the mix will keep it from having to kick in as frequently.
Back on the discussion of the regulators, Gator, you are right. I have a 20 gallon compressor and it does have regulators for the output. On my bigger compressor (60 gallon stationary) it does not have regulators for the output. Just a connection right off of the tank.
Closed Thread
compressor , dummies , needed , operation
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Similar Threads
Air Compressor? golfdad Power Tools and Their Use 5 12-12-2006 10:25 AM
Split again - air compressor psi/cfm chris99z71 Finishing 14 11-16-2006 10:29 AM
COMPRESSOR, nailer Joe Scharle Member Announcements 5 07-19-2006 08:11 AM
Air Compressor info sapwood Power Tools and Their Use 15 03-14-2006 06:24 PM
» Log in
You last visited: at
Log Out
User Name:
Password:
Not a member yet?
Register Now!
Search Rockler.com's Extensive Woodworking Catalog
Search from over
9000 products!
Highland Woodworking Link
» Stats
Members: 2,076
Threads: 16,133
2nd Top Poster: jeff... (6,256)
Welcome to our newest member, Tom
» Today's Birthdays
None
Powered by vBulletin® Version 3.7.0
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Content Copyright © 2005 - 2008 North Carolina Woodworker, Inc.
