» Announcements | July 15 - 2009 Calendar Contest Opens (See this thread for Categories and Submission Rules) - Be sure your photos meet size and resolution! September 1 - All Calendar Photos Must be Submitted September 27 - Southern Raleigh Shop Crawl October 11 - Fall Gathering in Asheville October 24 & 25 - Klingspor Extravaganza - Hickory, NC | » Online Users: 43 | | 0 members and 43 guests | | No Members online | | Most users ever online was 180, 04-21-2008 at 11:18 PM. |  |
06-26-2007, 12:52 PM
#1 | | Member
Name: barry City: Louisburg State: NC County: Franklin Join Date: Jan 2006 | the mill OK guys this is not really a gloat more just a purchase i have recently acquired a new toy a chain saw mill. Not your typical mill...... great for the backyard user... light weight..about 85lbs with out the saw ... big on performance .....introducing the logosol M7 MILL it is amaseing how easly the saw is cranked thru the log so far i have cut cedar and red oak still need a little adjustments `leaves a extremely smooth face surface but i though you guys might like to see it ..... if you cant get log onit you can put it on the log thay make a smaller version for the woodworker |
06-26-2007, 12:58 PM
#2 | | Member
Name: Ed City: Charlotte State: NC County: Mecklenburg Join Date: Apr 2006 | Re: the mill That's cool Barry! Do you have to have the chain filed special for the rip cuts or does it work OK with the standard file? |
06-26-2007, 01:08 PM
#3 | | Member
Name: barry City: Louisburg State: NC County: Franklin Join Date: Jan 2006 | Re: the mill it uses a rip chain leaves a 1\4 in kerf creates a little waste but you don't have to be a wood master to get great results either the package came with a power sharpener the high end kind bench mounted and adjustable it is pretty cool ........going to bulid a solar kiln next about 500bf |
06-26-2007, 01:53 PM
#4 | | Moderator Advisory Panel
Name: Roger Deese City: Durham State: NC County: Durham Join Date: Jul 2005 Age: 62 | Re: the mill Nice Barry. Definitely a tool gloat. YOU SUCK!!!
And it even comes with a place for your beer
Roger
__________________
I ain't never had too much fun!
06-26-2007, 01:55 PM
#5 | | Webmaster Senior Moderator Advisory Panel
Name: Dave O'Nan City: Clayton State: NC County: Johnston Join Date: Aug 2005 Age: 38 | Re: the mill Very cool, it looks like a fun toy tool  .
I hope that cold beer is just there for size comparison
BUSTED, and YOU SUCK!!!!!
Dave
__________________   Nothing left to do but smile, smile, smile
--Dr. Seuss
06-26-2007, 02:10 PM
#6 | | Member
Name: jeff... City: State: NC County: Granville Join Date: Mar 2006 | Re: the mill what's the shortest thing you could saw on that? looks like it might be a great little bowl blank machine. I'm a little confused it looks like you cutting with the front of the saw vers the back or am I all wet? Glad to see you getting into to tree cycling sweet.
__________________
Mills Custom Sawing Life is like a jar of Habanero peppers. What you do today, might burn your A _ _ tomorrow. Colonel Sandurz: Prepare ship for light speed.
Dark Helmet: No, no, no, light speed is too slow.
Colonel Sandurz: Light speed, too slow?
Dark Helmet: Yes, we're gonna have to go right to ludicrous speed. |
06-26-2007, 02:43 PM
#7 | | Member
Name: barry City: Louisburg State: NC County: Franklin Join Date: Jan 2006 | Re: the mill well they say you can cut your own shingles so i would guess 18 inches if you can hold it you can cut it it has some attachments for small stuff 1\4 inch thick ....that small piece of cedar is 1\4 in thick ....the length as set is about 16.9 ft but you can put together any number of mills to get the length you want they set a world record of 118ft 2x4 by putting 7 mils together that must a been 1 long tree
take a log cut a cant out of it notch the cant put your blanks in raise and cut it will raise in 1\8 ant 1\4 inch increments independently per side
thanks guys and you are right i do SUCK and i could not have done it with out the support of the LOML the projects are going backup now |
06-26-2007, 02:56 PM
#8 | | Member
Name: barry City: Louisburg State: NC County: Franklin Join Date: Jan 2006 | Re: the mill her are some better pics |
06-27-2007, 11:02 AM
#9 | | Member
Name: Mike C. City: Winston Salem State: NC County: Forsyth Join Date: Jun 2007 | Re: the mill Bman, that looks like a really cool unit. I went up to the M7 web site to gather some more detail. I like the design of the horizontal slide for the saw. Correct me if I'm wrong but it looks like it takes two separate cranks to elevate the log into position. One question though, with the two cranks how do you accurately elevate the log to maintain a consistant thickness on subsequent cuts? I've been dreaming of some low cost way to trailer in a unit to set up shop for some slab cutting. Right now I'm using my Granberg chainsaw mill and a crude concoction of 2x6x10's to get my first cut. That and my compact utility tractor (Bessie) I've been able to muddle my way through. I AM extremely jealous! Mike C. |
06-27-2007, 12:22 PM
#10 | | Member
Name: barry City: Louisburg State: NC County: Franklin Join Date: Jan 2006 | Re: the mill [quote=Gone2dMtns;91685] Correct me if I'm wrong but it looks like it takes two separate cranks to elevate the log into position. One question though, with the two cranks how do you accurately elevate the log to maintain a consistant thickness on subsequent cuts?
you are not wrong it does have indepentent lifts ...but once set correctly you count the clicks 1 click = 1/4 inch or 1/8 depending on setting
procedure is first cut just shave a flat on the log flip it on lift set it for level you have a scale on each lift make the cut ....rase each side = number of clicks ex for 4/4 need 5 clicks i click for the saw kerf make the cut or you can cant the log into the size you want then  slice and dice
once put together i was cutting with no problems pretty slick
if you or anyone would would like to see it pm me...... be happy to show it to you in person  or we could do some cutting for you for $$$ or wood |
06-27-2007, 12:39 PM
#11 | | Moderator
Name: Mike Hall City: Indian Trail State: NC County: Union Join Date: Feb 2006 Age: 41 | Re: the mill Congrats Barry! Looks like a handy tool to have!
__________________
__________________________________________
We shall not fail or falter; we shall not weaken or tire...Give us the tools and we will finish the job - Sir Winston Churchill You hear that honey??? I need more tools... |
06-27-2007, 01:11 PM
#12 | | Member
Name: jeff... City: State: NC County: Granville Join Date: Mar 2006 | Re: the mill Oh I get it, it's modeled after the old circular blade ratchet mill, 1 click = 1 inch, 2 clicks = 2" and so on... Seems yours is configurable for a click to be 1/8 or a 1/4, if yours is set on 1/4, 5 clicks would get you an 1" board? I assume at least 1/4" for a chain kerf. Pretty slick, it's also a built in clicak'able toe, so you can cut your first and second face parallel with the pith.
Pretty cool... and oh by the way since I forgot YOU SUCK
__________________
06-27-2007, 04:33 PM
#13 | | Member
Name: barry City: Louisburg State: NC County: Franklin Join Date: Jan 2006 | Re: the mill yeah you will have to get by to check it out .....with a homemade jig you can do octagon posts tapered or not .....check out this pic the top is about 1" square the bottom is 6 inch i think i am going to hang a light off it....i was just playing around with a small cedar my son got on a landscapeing job Maye'sPropertyManagment www.MayePM.com his web site needs work ...i guess i will have to fixit for him .....pm me if his services are needed
cheap plug !!!!!!! got keep the free wood comming |
06-27-2007, 05:35 PM
#14 | | Webmaster Senior Moderator Advisory Panel
Name: Dave O'Nan City: Clayton State: NC County: Johnston Join Date: Aug 2005 Age: 38 | Re: the mill Originally Posted by bman Maye'sPropertyManagment www.MayePM.com his web site needs work ...i guess i will have to fixit for him .....pm me if his services are needed
cheap plug !!!!!!! got keep the free wood comming Yep, it needs some work  If he comes down to the Wake Forest/ N. Raleigh area I would be happy to hand him all the work that is too small for the company I work for to handle. I get request all the time for jobs that just really aren't in our scope of work and would be great for someone starting up or with a smaller scale business.
Dave
--Dr. Seuss
Posting Rules
Members: 1,791
Threads: 14,572
2nd Top Poster: jeff... (5,780) | | Welcome to our newest member, Inmyshop | » Today's Birthdays | |
None
