North Carolina Woodworker
Discounts on 2010 NCWW Calendar through Nov 30th!!
Javascript DHTML Drop Down Menu Powered by dhtml-menu-builder.com
Go Back   North Carolina Woodworker > Tools, Equipment, and Techniques > Power Tools and Their Use
» Upcoming Events
Fall 2009 Raffle drawing this Friday (11/20): See This Thread For Details
Closed Thread
Old 01-16-2006, 11:13 PM   #1
Lathe speed
Mountaincraft's Avatar
City: Cedar Mountain
State: NC
County: Transylvania
Threads: 7
Show Printable Version Email this Page   Quote this post in a PM to Mountaincraft
Mountaincraft Mountaincraft is offline 01-16-2006, 11:13 PM
I am new to turning, and my work would require me to sometimes use recycled wood. Previously, I turned a few ballisters to repair a rail on someone elses lathe. I didn't kill myself, by way of common sense or probably luck.
According to my training (rotational moments of inertia blah blah), I am afraid of a lathe that has a starting speed above 300 rpm. Most of what I would do might be long, possibly thick stuff. Is this a valid concern?
Old 01-16-2006, 11:24 PM   #2
Monty's Avatar
City: Hickory
State: NC
County: Catawba
Threads: 232
Avg Visit Freq/Week
= 2.02 over 180 days
Re: Lathe speed
My midi starts at 500 rpm. I'm still here! If you're nervous about an off-balance piece, stand over at the end of the lathe when you start it up.... let it spin for a little bit before starting to work it.
__________________
My fledgeling woodworking web site: ShootingBoard.net
Show Printable Version Email this Page   Quote this post in a PM to Monty
Old 01-16-2006, 11:38 PM   #3
State: NC
Threads: 7
Avg Visit Freq/Week
= 0.00 over 180 days
Re: Lathe speed
I have a feeling that a midi won't do what I want with what I'm asked for...
Old 01-17-2006, 08:36 PM   #4
JRD is offline JRD
JRD's Avatar
City: Cary
State: NC
County: Wake
Threads: 74
Avg Visit Freq/Week
= 6.46 over 180 days
Re: Lathe speed
While I'm more of a woodturner focusing on bowls, dishes, and the like, I have turned a few spindle shaped objects. I use a Delta Midi lathe and while the speeds range from about 500 up to 13,000, I almost always stay at 500 rpm and have had no problems.
About the only concern I would have is if the spindle is relatively small in diameter. The longer the spindle and the smaller the diameter the more problems you'd experience with the work "whipping" as you work it, throwing everything out of true round.
What you could do is make a second support out of ply and rollers that would mount to the bed about half way along it's length. That would add extra support to the piece being worked, preventing it from flexing and the resulting out of round problem.
As for the workpiece coming loose, at lower speeds (below 800 or so) I've never had a piece come loose unless I was applying too much perpendicular pressure relative to the piece being worked.
Hope this helps.
Show Printable Version Email this Page   Quote this post in a PM to JRD
Old 01-18-2006, 12:25 AM   #5
State: NC
Threads: 7
Avg Visit Freq/Week
Re: Lathe speed
I'm thinking a very long bed, very slow, lathe. A midi with 2 bed extensions and electronicly variable speed. Can't see a need for longer. If piecing together, a mini will do. Just swing is the limit, but no problems with ballasters
Closed Thread
lathe , speed
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Order your 2010 Calendar!
Carolina Lumber Sourcing
» Stats
Members: 3,663
Threads: 25,107
Top Poster: DaveO (14,702)
Welcome to our newest member, Keith Senderak
» Today's Birthdays
Dick Barnes (74)
Powered by vBadvanced CMPS v3.2.0
Powered by vBulletin® Version 3.8.2
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.3.0
Template-Modifications by TMS
Content Copyright © 2005 - 2009 North Carolina Woodworker, Inc.
