| Re: Jointer height opinions I had this problem, but instead of cutting the cabinet of my jointer down, I decided to put the Unisaw up on wheels and bought a steel frame with wheels for it.
HTC was having a clearance sale on many of their odd size models at that time. I couldn't find one of the sale models to fit my saw, but their sale price of $30 delivered made it such a good deal that I ordered one knowing that was too small, but was the right basic design, with plans to make it fit my saw, somehow, when it arrived. When it came, I cut the 1X2 steel frame of it in several places and welded in 1x2" extension pieces to increase the frame size and make it fit my Unisaw and it's 50" table extension. A little gray metalic rattle can paint from Lowe's and it looked like l had bought the correct, but significantly more expensive model from HTC. Very impressive for $30, a can of paint, and about 2 hours work (1x2 square pipe scraps were on hand).
However, after getting the Unisaw onto it, I discovered that the saw's table was still not quite high enough. I then made a plywood spacer to put in the frame under the saw and a smaller one under the saw table legs. These 3/4" thick inserts lifted the Unisaw just high enough for wood to clear the jointer fence by about 1/4" and solved the problem without the need to cut down my jointer's cabinet. A side benefit of the plywood spacer is that it prevents sawdust from falling out of the bottom of the saw cabinet onto the floor, making it easier to move the saw whenever I need to.
Charley |
