» Announcements |
The Woodworking Source Grand Opening
Was a Success!!
» Online Users: 50 |
| 12 members and 38 guests |
Alan in Little Washington
bitbight
Dudelive
gator
gsdoby
Marlin
Matt Schnurbusch
mvgraz
NCPete
ptt49er
skeeter
TopKnot
| Most users ever online was 180, 04-22-2008 at 12:18 AM. |
04-21-2008, 04:33 PM
#1
This Space for rent
City: Chapel Hill
State: NC
County: Orange
Avg Visit Freq/Week = 6.72 over 125 days
Jointer belt problem
I have one of the grey Ridgid 6" jointers. The last couple of times I've used it, I've smelled a slight burning rubber smell. Also, the belt jumps off the pulleys. I bought two different 36" V belts today and they both keep coming off the pulleys. Any ideas as to what the problem may be?
04-21-2008, 04:38 PM
#2
This Space for rent
City: Concord
State: NC
County: Cabarrus
Avg Visit Freq/Week = 7.00 over 125 days
Re: Jointer belt problem
The simple answers are not enough tension and/or the pulleys not aligned perfectly. Alos, look at the pulleys to be sure they are not cracked or damaged otherwise though that is not all that likely, but olook anyway.
04-21-2008, 08:30 PM
#3
This Space for rent
City: Matthews
State: NC
County: Union
Avg Visit Freq/Week = 5.49 over 125 days
Mis-aligned pulleys would be my guess.
__________________
A woodworker is one that works for hours getting machinery set to perfection, then pulls out an imperfect piece of wood and makes a beautiful imperfect project.
04-21-2008, 09:00 PM
#4
This Space for rent
City: Goldsboro
State: NC
County: Wayne
Avg Visit Freq/Week = 5.94 over 125 days
Is it possible the set screws on the pulleys have loosened to the point the pulleys are sliding or spinning? If spinning, you may have a loose key floating around somewhere.
__________________
My only regret in life is that I did not listen more and talk less
04-21-2008, 09:10 PM
#5
This Space for rent
Name: Alan Schaffter
City: Washington
State: NC
County: Beaufort
Avg Visit Freq/Week = 6.66 over 125 days
My belt has never come off, but the lower pulley has loosened and shifted on the motor shaft a couple times.
04-21-2008, 10:55 PM
#6
This Space for rent
City: Apex
State: NC
County: Wake
Avg Visit Freq/Week = 5.82 over 125 days
The pulley on the head is usually a small diameter. A notched belt works better than a standard one. Goodyear sells their as Power Flex. I would try a notched belt first, assuming that the pulleys are in alignment.
04-21-2008, 11:19 PM
#7
This Space for rent
City: Chapel Hill
State: NC
County: Orange
I tried a notched belt today. That didn't work so I then tried a regular belt, again with no luck. The pulleys seem to be aligned but I will give it a closer inspection tomorrow.
04-22-2008, 11:36 PM
#8
This Space for rent
City: Apex
State: NC
County: Wake
Is the pitch the same on both old and new belt? Try spinning cutter head with out the belt attached, just to rule out the bearings. If the pulley is die cast material (zinc), replace it with a cast iron pulley.
| Thread Tools |
| Display Modes |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
» Stats |
Members: 2,077
Threads: 16,141
2nd Top Poster: jeff... (6,256)
| Welcome to our newest member, Tom |
» Today's Birthdays |
None
