North Carolina Woodworker
Go Back   North Carolina Woodworker > Tools, Equipment, and Techniques > Power Tools and Their Use
» Announcements
July 15 - 2009 Calendar Contest Opens (See this thread for Categories and Submission Rules) - Be sure your photos meet size and resolution!
September 1 - All Calendar Photos Must be Submitted
September 27 - Southern Raleigh Shop Crawl
October 11 - Fall Gathering in Asheville
October 24 & 25 - Klingspor Extravaganza - Hickory, NC
» Online Users: 43
2 members and 41 guests
McRabbet , tom hintz
Most users ever online was 180, 04-21-2008 at 11:18 PM.
Featured Photos
by Alan in Little Washington
21448 photos
4927 comments
21448 photos
4927 comments
by fdfrye
346 photos
17 comments
by Phil S
21448 photos
4927 comments
Closed Thread
Old 06-20-2008, 08:23 PM   #1
Member
Advisory Panel
mshel's Avatar
City: Wilson
State: NC
County: Wilson
Threads: 133
JB Weld
This question is for those of you who are experienced in using JB weld.
Q. Will this stuff seal a leak even if the leak is in progress at the time the stuff is applied?
__________________
Whatever the mind can conceive and believe, the mind can achieve.
~ Dr. Napoleon Hill
http://carolina-heirlooms.ncwoodworker.net/
Show Printable Version Email this Page   Quote this post in a PM to mshel
Old 06-20-2008, 08:24 PM   #2
Senior Moderator
newtowood's Avatar
City: Salisbury
State: NC
County: Rowan
Threads: 116
Re: JB Weld
What kind of leak?
__________________
Tracy
Making Friends One Post At A Time
Show Printable Version Email this Page   Quote this post in a PM to newtowood
Old 06-20-2008, 08:24 PM   #3
Member
Gotcha6's Avatar
City: Ivan's Corner (Monroe)
State: NC
County: Union
Threads: 34
Re: JB Weld
Nope
__________________
"Whether you think you can or you think you can't - you're right." - Henry Ford
Show Printable Version Email this Page   Quote this post in a PM to Gotcha6
Old 06-20-2008, 08:26 PM   #4
Senior Moderator
newtowood's Avatar
City: Salisbury
State: NC
County: Rowan
Threads: 116
Re: JB Weld
Never had it seal anything currently leaking, or leaking during the curing time.
__________________
Tracy
Old 06-20-2008, 08:35 PM   #5
Member
Advisory Panel
mshel's Avatar
City: Wilson
State: NC
County: Wilson
Threads: 133
Re: JB Weld
Well, I can vouch for it not sealing, just wanted to know if someone had actually had luck with it. Long story short, my planer is weaping oil from the gearbox via two pin holes in the casting. I plan on draining the oil from the gearbox next week and try again. The holes had to be there the whole time but finally the oil worked it's way through the paint. Probably some air voids in the casting. Really @#$$%$ me off but what are you going to do. Right, fix a problem not caught by the off shore folks. I have been very happy with the planer all in all so I guess this is just a little bump in the road.
__________________
~ Dr. Napoleon Hill
Old 06-20-2008, 08:44 PM   #6
Member
Gotcha6's Avatar
State: NC
County: Union
Threads: 34
Re: JB Weld
The problem is the oil has probablby soaked into the pores of the casting metal & will inhibit the bonding of the metal to the JB Weld. You'd have better luck draining the gear box & cleaning the pinhole with a degreaser such as lacquer thinner or spray carb cleaner. If it's just a smill pinhole, try a self drilling screw if aesthetics aren't a concern. Otherwise, drill & tap it with a tapered tap & put in a set screw with some RTV silicone or Loc Tite. If it's in an area subject to stress such as a bearing seat, I'd try welding with nickel welding rod.
__________________
Old 06-20-2008, 09:44 PM   #7
Member
Advisory Panel
mshel's Avatar
City: Wilson
State: NC
County: Wilson
Threads: 133
Re: JB Weld
The area where it is leaking is on the top of a protrusion where the oil seal is located. I don't fancy drilling holes in the casting and if there is no simple fix, I will just get a replacement cover. I do think I will drain the oil, clean up the area and give it another try.
__________________
~ Dr. Napoleon Hill
Old 06-20-2008, 09:51 PM   #8
Member
Gotcha6's Avatar
State: NC
County: Union
Threads: 34
Re: JB Weld
If the area is not subject to pressure, you may try just cleaning it up & applying some RTV silicone from the inside.
__________________
Old 06-20-2008, 10:09 PM   #9
Member
jeff...'s Avatar
City:
State: NC
County: Granville
Threads: 412
Re: JB Weld
JB Weld needs a clean dry surface to bond to. oil or water + JB Weld = Failure. Don't know if this hole of yours is under pressure - but I have seen folks fix holes in oil pans on old tractors and gear boxes with a regular old tire plug - seemed to work well... as long as you can jam it up in there. But I don't recall any of the covers being cast - so I don't know if it'll work... Try drilling a hole and tapping it put a short bolt in the hole with some loc-tite and rubber washer that should take care of the leak.
__________________
Mills Custom Sawing
Life is like a jar of Habanero peppers. What you do today, might burn your A _ _ tomorrow.
Colonel Sandurz: Prepare ship for light speed.
Dark Helmet: No, no, no, light speed is too slow.
Colonel Sandurz: Light speed, too slow?
Dark Helmet: Yes, we're gonna have to go right to ludicrous speed.
Show Printable Version Email this Page   Quote this post in a PM to jeff...
Old 06-20-2008, 10:20 PM   #10
Member
City: Apex
State: NC
County: Wake
Threads: 211
Re: JB Weld
If it were mine (it isn't), I would drain and remove gearbox cover. Clean it with some detergent (solvents will probably take the paint off). Let dry, and then JB Weld from the inside. You may find some more pores that also could use some attention.
Show Printable Version Email this Page   Quote this post in a PM to junquecol
Old 06-20-2008, 11:50 PM   #11
NCPete's Avatar
City: Hope Mills
State: NC
County: Cumberland
Threads: 200
Re: JB Weld
I like Bruce's approach to fixing the problem.... I need to pick up some JB Weld to fix a hole in the intake in my truck, it is pouring water onto the alternator as fast as I pour it into the radiator...
__________________
Failure is the opportunity to begin again more intelligently. – Henry Ford
However your life is, meet it and live it.
Henry David Thoreau
They that can give up essential liberty to obtain a little temporary safety, deserve neither liberty, nor safety. Benjamin Franklin
Show Printable Version Email this Page   Quote this post in a PM to NCPete
Old 06-21-2008, 08:54 AM   #12
JRD is offline JRD
Member
JRD's Avatar
City: Cary
State: NC
County: Wake
Threads: 59
Re: JB Weld
Don't know if this will work or not, but years ago when I flew RC airplanes, oil from the fuel would often get under the covering and into the Balsa wood frame which weakened it.
I learned back then that K2R spot remover is an excellent way to pull oil residue out of a surface. Spray on, wait until dry, brush off. Several treatments would make Balsa wood almost like fresh again.
It might degrease the casting enough to allow a JB Weld.
Show Printable Version Email this Page   Quote this post in a PM to JRD
Closed Thread
weld
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
» Log in
User Name:
Password:
Not a member yet?
Register Now!
» Stats
Members: 1,791
Threads: 14,572
2nd Top Poster: jeff... (5,780)
Welcome to our newest member, Inmyshop
» Today's Birthdays
None
Highland Woodworking Link
Powered by vBulletin® Version 3.7.0
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
