North Carolina Woodworker
2009 Fall Raffle is Under Way        Our Greatest Collection of Prizes to Date        See the Links Below to Purchase Tickets Online    Good Luck to All
Javascript DHTML Drop Down Menu Powered by dhtml-menu-builder.com
Go Back   North Carolina Woodworker > Tools, Equipment, and Techniques > Power Tools and Their Use
» Upcoming Events
Fall 2009 Raffle Is Under Way: See This Thread For Details, Our Biggest Raffle Yet. Purchase Link Located Just Under This Box: GOOD LUCK!
Nov 14: Durham, Orange, Chatham Shop Crawl    Sign up here!
» Fall 2009 Raffle Online Purchase Link
Closed Thread
Old 10-13-2006, 12:00 PM   #1
Installing Side Extension Wings on TS
woodworker2000's Avatar
City: Raleigh
State: NC
County: Wake
Threads: 58
Show Printable Version Email this Page   Quote this post in a PM to woodworker2000
woodworker2000 woodworker2000 is offline 10-13-2006, 12:00 PM
How do you get these things level with the main table and how much variance is acceptable? I started by inserting the bolts and snugging them up, then tapping the wing with a rubber mallet on the top and bottom until it felt like it was the same level as the table. I checked for variations in table height by running my fingertips back and forth over the seam and tightened the bolts when it felt level. I can still feel that a seam is there so I'm wondering if I'm doing this incorrectly.
I don't have a straightedge but is there a way to measure it using a dial guage and magnetic base (one of those articulating arm bases)? Or am I just supposed to get it as close as I can using the "run your hand over the seam method"?
Thanks.
Old 10-13-2006, 12:48 PM   #2
chris99z71's Avatar
City: Garner
State: NC
County: Wake
Threads: 163
Avg Visit Freq/Week
= 0.35 over 180 days
Re: Installing Side Extension Wings on TS
I've never heard of a method for leveling extension wings using a dial indicator...I guess that it wouldn't be that hard though...
Set the base with the arm extended and zero it with everything on the table top, including the tip for the indicator. Then rotate the arm to extend over the wing with the tip on the far edge of the wing - without changing the arm angles.
I think most just do it with a reasonable straight edge. I used a 4' sheetrock square that I've got. A descent 4' level would probably work too. I don't think it really requires a whole lot of precision. Just flat enough that it doesn't change that angle between the piece that you're cutting and the blade.
To level it, put pieces of masking tape either along the top or bottom edge the the mating surface between the wing and table and then tighten it up. Sort of a trial and error routine.
Hope this helps.
__________________
"If you can't learn to do something well, learn to enjoy doing it poorly."
----9-11-01----343----Never Forget----
Show Printable Version Email this Page   Quote this post in a PM to chris99z71
Old 10-13-2006, 01:46 PM   #3
Advisor
Founder
SteveColes's Avatar
City: Apex
State: NC
County: Wake
Threads: 1072
Avg Visit Freq/Week
= 6.81 over 180 days
I've got two 72" levels that I use for that kind of thing. Both levels have a magnetic side.Then I use them front and back of the table as long straight edges. If you'd like to borrow them, just PM me.
BTW, I've found that even when the edges are flush to the main table, the machining isn't good enough that the outer edge isn't level. It tends to sag at the ends. Then you have to use shims to get the whole thing level.
Show Printable Version Email this Page   Quote this post in a PM to SteveColes
Old 10-13-2006, 03:33 PM   #4
chris99z71's Avatar
City: Garner
State: NC
County: Wake
Threads: 163
Avg Visit Freq/Week
What do you use as shims, Steve? Just curious.
__________________
Old 10-13-2006, 05:14 PM   #5
Advisor
Founder
SteveColes's Avatar
City: Apex
State: NC
County: Wake
Threads: 1072
Avg Visit Freq/Week
Anything will work. The last time I used some thin washers that just happened to work.
Old 10-13-2006, 06:05 PM   #6
City: Raleigh
State: NC
County: Wake
Threads: 58
Avg Visit Freq/Week
= 6.38 over 180 days
Thanks for the replies. Sounds like I've got some work to do to get these things right but I know if I don't get them to a point where I feel like its done right, it will bug me until I take everything apart and start over. Much easier to do it the right way before I put the fence rails on.
As far as shims, I've heard of cutting them from an aluminum beverage can....after you empty the contents of course....sometimes you have to empty three or four of them before you get it right......
Old 10-13-2006, 07:42 PM   #7
Gofor's Avatar
City: Goldsboro
State: NC
County: Wayne
Threads: 56
Avg Visit Freq/Week
= 4.47 over 180 days
Chris, I clamped a board to the table top (over hanging the edge) at the front and back, and then clamped the extension to the bottom of the board. This flushed up the edges. I had no droop on the outer ends (lucky, I guess). I had the outer edge of the extension braced up with a board on a sawhorse to help support the weight while I aligned it and got the bolts hand tight, then tightened the clamps. Smooth hardwood or metal works best to clamp to to get a perfect fit.
HTHs
__________________
"The three hardest things to make in your shop are time, space, and money" - Buz Buskirk (quoted in Woodworking Magazine, Spring 2009)
Show Printable Version Email this Page   Quote this post in a PM to Gofor
Old 10-14-2006, 10:26 PM   #8
City: Apex
State: NC
County: Wake
Threads: 293
Avg Visit Freq/Week
= 6.26 over 180 days
I suggest that you get a copy of John White's book "Care and Repair of Shop Machines". He shows how to do this very operation. It is one of the best books on setting up shop machines. Costs less than $20 and money well spent. John is the manager of FWW's shop.
Show Printable Version Email this Page   Quote this post in a PM to junquecol
Closed Thread
extension , installing , side , wings
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Installing Mortised Hinges rick7938 General Woodworking 6 06-15-2006 09:43 AM
Price for installing hardwood floors-eastern NC cskipper Request For Custom Projects 14 04-22-2006 02:53 PM
Woodpecker Table Saw Extension and Ridgid TS Ken Massingale Power Tools and Their Use 4 12-17-2005 11:40 AM
Carolina Lumber Sourcing
» Stats
Members: 3,615
Threads: 24,792
Top Poster: DaveO (14,683)
Welcome to our newest member, bsewell
» Today's Birthdays
ptt49er (28)
Powered by vBadvanced CMPS v3.2.0
Powered by vBulletin® Version 3.8.2
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.3.0
Template-Modifications by TMS
Content Copyright © 2005 - 2009 North Carolina Woodworker, Inc.
