North Carolina Woodworker
Changes to DQ as of 12/1/2008 Very important that you read
Go Back   North Carolina Woodworker > Tools, Equipment, and Techniques > Power Tools and Their Use
Notices
» Announcements
Everyone Log on at 9:00PM Thursday December 4th to set a members online record.
Featured Photos
by redhawknc1
24861 photos
9957 comments
by ChrisMathes
24861 photos
9957 comments
by GeorgeL
24861 photos
9957 comments
by smitty49
376 photos
19 comments
» Online Users: 50
19 members and 31 guests
bppaulson , DaveO , Douglas Robinson , Glennbear , jeff... , Kdub , Keye , mlzettl , NZAPP1 , ptt49er , sshelton , taandctran , TexasTimbers , Threejs , thrt15nc , tmerrill , TN Woodie , TopKnot , woodylarry
Most users ever online was 180, 04-22-2008 at 12:18 AM.
Closed Thread
Old 02-09-2006, 03:17 PM   #1
Director
sapwood's Avatar
City: Durham
State: NC
County: Durham
Threads: 199
Avg Visit Freq/Week
= 6.53 over 30 days
Cool
My 15 year old Griz tablesaw has a problem with the arbor nut loosening
The frequency has increased and resulted in damage to one blade. Luckily it has always occured powering down the saw, not during a cut.
(1) After cutting power, the nut loosens.
(2) The saw arbor continues to rotate with the blade loose
(3) Lack of resistance on motor fails to engage the "brake" that normally slows blade down
(4) Since the brake doesn't engage the arbor spins freely with the blade slipping for a frightening minute or so. (meanwhile I'm cringing under the extension wing until it stops).
I use a Blade-Loc to hold blade during and apply more than appropriate force to the arbor nut. The blade is secure!
The tablesaw is 15 years old and has some vibration. HF dial indicator doesn't show noticeable wobble in shaft and the arbor, flange, and nut are clean and smooth. I assume vibration is causing the nut to loosen.
Could this indicate worn bearings?
Other suggestions to check?
Sapwood
__________________
I ain't never had too much fun!
Show Printable Version Email this Page   Quote this post in a PM to sapwood
Old 02-09-2006, 03:43 PM   #2
City: Fuquay Varina
State: NC
County: Wake
Threads: 38
Avg Visit Freq/Week
= 5.83 over 30 days
Sapwood,
Is this the original nut?
I had a similar (not exact) issue on my old Craftsman table saw.
It turned out to be the 20 year old nut had worn and did not hold pressure.
It would actually back off .
Check the nur and the arbor threads for rounding.
That was the only sign of wear I had.
yf
Show Printable Version Email this Page   Quote this post in a PM to yellofins
Old 02-09-2006, 03:52 PM   #3
Monty's Avatar
City: Hickory
State: NC
County: Catawba
Threads: 229
Avg Visit Freq/Week
= 0.70 over 30 days
Full kerf or thin kerf?
__________________
My fledgeling woodworking web site: ShootingBoard.net
Show Printable Version Email this Page   Quote this post in a PM to Monty
Old 02-09-2006, 03:53 PM   #4
Webmaster
Director
DaveO's Avatar
City: Clayton
State: NC
County: Johnston
Threads: 568
Avg Visit Freq/Week
= 7.00 over 30 days
I would definitely check what Yellofin mentioned. Your problem sounds strange to me. Is the arbor nut left-hand threaded? If it is, it would seem the the rotation of the blade would continue to keep the nut tight despite any vibrations. I have only hand tightened my arbor nut on my Griz. 0444Z to find it a struggle to remove with a wrench after making several cuts. Sounds like you should get a new saw for your Birthday
I hope you figure it out, that doesn't sound like a fun problem to have
Dave
__________________
Nothing left to do but smile, smile, smile
--Dr. Seuss
Show Printable Version Email this Page   Quote this post in a PM to DaveO
Old 02-09-2006, 04:15 PM   #5
Vice-President
Libraries Administrator
McRabbet's Avatar
City: Hendersonville
State: NC
County: Henderson
Threads: 117
Avg Visit Freq/Week
= 7.00 over 30 days
You may have a worn section on the arbor as well as having a nut that is worn enough to lose it's grip at that constant tightening point. Does this same thing happen if you install a dado set? If you have a blade stabilizer (I use one from Forrest with my WWII on my G1023SLX), then try to use it as an additional spacer to give the nut a new portion of arbor to grab on. If either the dado set or blade with stabilizer still slip, I recommend you get a new nut from Grizzly. Then, if it is the arbor, you could double nut the blade on and I'm sure it would not slip.
My .02 for fixes, but seeing it's your Birthday, be bold and ask LOYL for something you really need -- a new saw.
__________________
Truths: There is no such thing as a 25 hour day, so why do I keep trying to cram so much into every day so it seems that way!
Show Printable Version Email this Page   Quote this post in a PM to McRabbet
Old 02-09-2006, 04:29 PM   #6
windknot's Avatar
City: Tarboro
State: NC
County: Edgecombe
Threads: 27
Avg Visit Freq/Week
= 0.00 over 30 days
I have a 1023Z also but no problems. I suggest calling Griz. They are great about support. I bet they can answer the question without hesitation. My $.02 though, is the nut is bad.
Show Printable Version Email this Page   Quote this post in a PM to windknot
Old 02-09-2006, 05:52 PM   #7
Director
sapwood's Avatar
City: Durham
State: NC
County: Durham
Threads: 199
Avg Visit Freq/Week
= 6.53 over 30 days
Thanks folks, all good suggestions (except buy a new one ).
I'll start with Griz, they have always been helpful before. And the nut/arbor definitely could be worn.
Sapwood
Edit oops: full kerf
__________________
Old 02-09-2006, 08:41 PM   #8
Member
Steve D's Avatar
City: Horse Shoe
State: NC
County: Henderson
Threads: 69
Avg Visit Freq/Week
= 0.23 over 30 days
DOes your Griz have a bell washer? This is a washer that is slightly concave and actually flattens when tightened. My Grizley contractor saw has one and that should also help to prevent the nut from loosening. My saw is almost the same vintage and has see heavy use without ever having the nut come loose. I'm curious to hear what Grizzly has to say.
__________________
Home of the USS Crescent battle group.
Show Printable Version Email this Page   Quote this post in a PM to Steve D
Old 02-10-2006, 12:30 PM   #9
Director
sapwood's Avatar
City: Durham
State: NC
County: Durham
Threads: 199
Avg Visit Freq/Week
= 6.53 over 30 days
Well, I chatted with the Grizzly folks. As usual, the support folks are extremely nice. They suggested that the arbor and arbor nut are probably worn. The parts aren't too expensive and the guy said it should be easy to do. I responded that he doesn't know me
We also agreed I should probably replace bearings, since removing/replacing the cast iron top is the toughest part. I can get all the parts for about $40 and I have successfully replaced top a couple of times.
Hmmm, do I have the courage to tackle this? To date, my success with mechanical repairs has been minimal
Sapwood
__________________
Old 02-10-2006, 01:41 PM   #10
D L Ames's Avatar
Name: D L Ames
City: Fayetteville
State: NC
County: Cumberland
Threads: 66
Avg Visit Freq/Week
= 0.00 over 30 days
Go for it Roger..........you can do it!
D L
__________________
People sleep peaceably in their beds at night only because rough men stand ready to do violence on their behalf. George Orwell (1903 - 1950)
Show Printable Version Email this Page   Quote this post in a PM to D L Ames
Old 02-10-2006, 01:43 PM   #11
Webmaster
Director
DaveO's Avatar
City: Clayton
State: NC
County: Johnston
Threads: 568
Avg Visit Freq/Week
= 7.00 over 30 days
I would tackle it If you have removed your CI top before and got everything lined back up right, then you have done the hard part. I wouldn't think that the arbor and bearing replacement could be to difficult. Let me know if you need a hand, not that I have ever done it before, but two people standing around scratching their heads is always more fun than one
Dave
__________________
--Dr. Seuss
Old 02-10-2006, 05:18 PM   #12
Director
gator's Avatar
City: Oxford
State: NC
County: Granville
Threads: 122
Avg Visit Freq/Week
= 7.00 over 30 days
Let me know what day you plan the operation and if I'm not busy, I'll come down and watch too.
George
Show Printable Version Email this Page   Quote this post in a PM to gator
Old 02-10-2006, 05:29 PM   #13
Vice-President
McRabbet's Avatar
State: NC
County: Henderson
Threads: 117
Avg Visit Freq/Week
= 7.00 over 30 days
Hey Roger, why don't you set up a live web cam so all of us will be able to watch!
__________________
Old 02-10-2006, 06:15 PM   #14
Director
sapwood's Avatar
City: Durham
State: NC
County: Durham
Threads: 199
Avg Visit Freq/Week
= 6.53 over 30 days
Excellent idea and I certainly appreciate the offers of assistance. I'm not to proud to accept help.
However, I fear any live video feeds might be rated XXX for "obscene language content".
Sapwood
__________________
Old 02-11-2006, 08:02 AM   #15
golfdad's Avatar
City: Clayton
State: NC
County: Johnston
Threads: 19
Avg Visit Freq/Week
= 2.33 over 30 days
I beleive I would call "Pappa Grizz" and see what he has to say. Thats a pretty scary thought there. My Grizz is abouth the same age as yours but haven't had a problem "yet"???
Show Printable Version Email this Page   Quote this post in a PM to golfdad
Closed Thread
1023 , griz , problem
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
» Log in
User Name:
Password:
Not a member yet?
Register Now!
Search Rockler.com's Extensive Woodworking Catalog
Search from over
9000 products!
Highland Woodworking Link
» Stats
Members: 2,135
Threads: 16,383
2nd Top Poster: jeff... (6,362)
Welcome to our newest member, rsellers
» Today's Birthdays
Red Sonja (39)
Powered by vBulletin® Version 3.7.0
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Content Copyright © 2005 - 2008 North Carolina Woodworker, Inc.
