» Announcements | September 8 - Voting Begins
September 27 - Southern Raleigh Shop Crawl October 11 - Fall Gathering in Asheville October 24 & 25 - Klingspor Extravaganza - Hickory, NC | » Online Users: 78 | | 16 members and 62 guests | | AlexL , Bas , bitbight , Canuck , HMH , John Jankowski , jtodd71 , lwhughes149 , Mike Davis , newtowood , PLC'woodart , redhawknc1 , Tar Heel , TedAS , woodlaker2 , woodnick | | Most users ever online was 180, 04-21-2008 at 11:18 PM. |  |
06-23-2008, 08:59 PM
#1 | | Member Advisory Panel
Name: Michael Shelley City: Wilson State: NC County: Wilson Join Date: Jul 2005 Age: 59 Avg Visit Freq/Week = 6.89 over 65 days | Form a gasket question What with all the different types of sealants out there, what would be the best type to seal a gearbox housing? I won't be using a gasket, just the sealant.
Mike |
06-23-2008, 09:08 PM
#2 |
Name: jeff... City: State: NC County: Granville Join Date: Mar 2006 Avg Visit Freq/Week = 6.68 over 65 days | Re: Form a gasket question Me personally I would go to Napa and buy a sheet of gasket material and cut my own with an exacto knife.
__________________
Mills Custom Sawing Never corner something that you know is meaner than you. |
06-23-2008, 09:21 PM
#3 |
Name: Mark City: Goldsboro State: NC County: Wayne Join Date: Mar 2006 Avg Visit Freq/Week = 5.49 over 65 days | Re: Form a gasket question With or without a gasket, permatex has always worked for me.
__________________
My only regret in life is that I did not listen more and talk less
06-23-2008, 09:29 PM
#4 | | Senior Moderator
Name: Tracy City: Salisbury State: NC County: Rowan Join Date: Feb 2008 Age: 47 Avg Visit Freq/Week = 7.00 over 65 days | Re: Form a gasket question A properly formed gasket will seal better than form a gasket. A formed paper or cork gasket does not typically squeeze out under torque as form a gasket can. If you use form a gasket apply a thick enough bead to seal but not thick enough to ooze into the gear oil in the gearbox. JMTCW
__________________ Tracy Making Friends One Post At A Time  |
06-23-2008, 09:39 PM
#5 |
Name: Travis City: Wake Forest State: NC County: Wake Join Date: Dec 2005 Avg Visit Freq/Week = 3.77 over 65 days | Re: Form a gasket question If I was definitely not going to buy or make a gasket, I would go with permatex. Wicked stuff, but seals excellently. Be sure to wear gloves as it is tough to get off your hands. DAMHIKT. |
06-23-2008, 09:43 PM
#6 |
Name: earl rasmussen City: Pikeville State: NC County: Wayne Join Date: Dec 2005 Avg Visit Freq/Week = 6.68 over 65 days | Re: Form a gasket question Indian head gasket shallec, unless you might want to take it apart at some point of time
__________________
Earl "If you want to learn how to build a house, build a house.
Don't ask anybody, just build a house." "Oland tool, better than a bowl gouge, a lot cheaper to make." Darrell Feltmate around the woods |
06-23-2008, 09:50 PM
#7 | | Member Advisory Panel
Name: Michael Shelley City: Wilson State: NC County: Wilson Join Date: Jul 2005 Age: 59 Avg Visit Freq/Week = 6.89 over 65 days | Re: Form a gasket question Originally Posted by jeff... Me personally I would go to Napa and buy a sheet of gasket material and cut my own with an exacto knife. You know, this might not be a bad idea. I think I have an old gasket I could trace around. I really don't want to take this thing apart again so I may as well go the whole nine yards.
MIke |
06-23-2008, 10:14 PM
#8 |
Name: Bruce City: Apex State: NC County: Wake Join Date: Nov 2005 Avg Visit Freq/Week = 5.71 over 65 days | Re: Form a gasket question Take it apart, and clean all surfaces. Use some oil base paint to paint mating surfaces. While paint is still wet, use cover to print pattern on gasket material. While gasket material is drying, clean paint off gear box cover. Repair holes in cover. Cut out print, and use transfer punches to locate holes for bolts. Use hollow punch to punch out holes for bolts. See how easy that was?  Remember, it doesn't have to be pretty, only functional. You might want till after assembly to use an exacto knife to trim outside of gasket. |
06-23-2008, 10:33 PM
#9 |
Name: jeff... City: State: NC County: Granville Join Date: Mar 2006 Avg Visit Freq/Week = 6.68 over 65 days | Re: Form a gasket question Originally Posted by junquecol Take it apart, and clean all surfaces. Use some oil base paint to paint mating surfaces. While paint is still wet, use cover to print pattern on gasket material. While gasket material is drying, clean paint off gear box cover. Repair holes in cover. Cut out print, and use transfer punches to locate holes for bolts. Use hollow punch to punch out holes for bolts. See how easy that was?  Remember, it doesn't have to be pretty, only functional. You might want till after assembly to use an exacto knife to trim outside of gasket. nice trick with the paint I'm going to try that next time for sure. I do it the midevil way just outline with a sharpie and start cutting - lay the cover and gasket material on a piece of pine insert the bolts in the holes and whack them hard enough with a hammer to get a hole outline on the gasket material. Then cut an X and trim the holes with the knife. Your right it don't need to be pretty just good enough to seal.
__________________
06-24-2008, 06:26 AM
#10 |
Name: Tom City: Yadkinville State: NC County: Yadkin Join Date: Jun 2006 Avg Visit Freq/Week = 6.78 over 65 days | Re: Form a gasket question An alternative to cutting: lay a piece of gasket material over what it will cover. Tap around the outside and inside edges with the round side of a ball peen hammer. Gasket will be the shape you need. What you cannot tap with the hammer, cut with a knife.
__________________
The Tao of Tom: Be good to your pet(s). Invest in good Karma.
06-24-2008, 07:49 AM
#11 |
Name: Phillip Cooper City: Maiden State: NC County: Catawba Join Date: Dec 2006 Age: 47 Avg Visit Freq/Week = 6.57 over 65 days | Re: Form a gasket question I'll throw one in here, being from the automotive industry, I've found that an actual gasket of some sort is best over any kind of silicone or other gasket makers that are in a tube. The place for those is corners where gaskets meet, or in instances where the finish on the two metals is so good that an anaerobic sealer is ok. I've never used silicone with a gasket as the silicone is slick enough to cause the gasket to squeeze out with pressure from the bolts. The indian head sealer is good with a gasket, acts more like a glue and will be difficult to take apart later, I'd only use it if it has lots of heat and tends to have movement between the two bolted together parts. In your situation I doubt that is the case. The napa gasket material and ball peen hammer trick or paint marks would be my method, put together dry.
__________________ Today a pile of wood, tomorrow a pile of sawdust...... |
06-24-2008, 10:20 AM
#12 |
Name: Jimmy Coull City: Clayton State: NC County: Johnston Join Date: Sep 2006 Age: 49 Avg Visit Freq/Week = 6.35 over 65 days | Re: Form a gasket question Originally Posted by LeftyTom An alternative to cutting: lay a piece of gasket material over what it will cover. Tap around the outside and inside edges with the round side of a ball peen hammer. Gasket will be the shape you need. What you cannot tap with the hammer, cut with a knife.
I agree with you Tom, I spend years working the power generation field cuttin gaskets this way, just do two bolt hole first for pin placement and the gasket won't move. Permatex is unequivocally the nastiest sealant that I've ever used, but it works best.
Jimmy
__________________ "There are no strangers here, only friends that haven't met " I only buy what I need now, not what I want..... except for lumber ! Remember: Support your local Sawyers and Kiln Operators. |
06-24-2008, 11:40 AM
#13 |
Name: George Lesniak City: Fuquay Varina State: NC County: Wake Join Date: Nov 2005 Age: 47 Avg Visit Freq/Week = 7.00 over 65 days | Re: Form a gasket question Originally Posted by mshel What with all the different types of sealants out there, what would be the best type to seal a gearbox housing? I won't be using a gasket, just the sealant.
Mike Mike,
First, I have a few questions before I can provide an accurate response. What is the gearbox attached to? What type of fluid is in the gearbox? Hydraulic oil, gear lube, transmission fluid etc. Did the original application use a gasket? What is the gearbox housing and cover made of? Sealants are a science, there is no one size fits all solution. There are dozens of variations of Permatex sealants, each with a specific intended application.
Oh and BTW, go to CARQUEST, not Napa  CARQUEST world headquarters is right here in Raleigh.
George |
Posting Rules
Members: 1,828
Threads: 14,750
2nd Top Poster: jeff... (5,848) | | Welcome to our newest member, woodenyouknowit | » Today's Birthdays | |
None
