North Carolina Woodworker
Discounts on 2010 NCWW Calendar through Nov 30th!!
Javascript DHTML Drop Down Menu Powered by dhtml-menu-builder.com
Go Back   North Carolina Woodworker > Tools, Equipment, and Techniques > Power Tools and Their Use
» Upcoming Events
Fall 2009 Raffle drawing this Friday (11/20): See This Thread For Details
Closed Thread
Old 01-06-2009, 11:35 PM   #1
Flat part on router base
Joe Scharle's Avatar
City: Holly Springs
State: NC
County: Wake
Threads: 159
Show Printable Version Email this Page   Quote this post in a PM to Joe Scharle
Joe Scharle Joe Scharle is offline 01-06-2009, 11:35 PM
Anyone have any idea why the newer bases are not completely round?
Old 01-07-2009, 12:04 AM   #2
City: Lancaster
State: SC
County: Lancaster
Threads: 161
Avg Visit Freq/Week
= 0.39 over 180 days
Re: Flat part on router base
Hope someone knows because I have also wondered the same thing.
Show Printable Version Email this Page   Quote this post in a PM to Keye
Old 01-07-2009, 12:36 AM   #3
Bas is offline Bas
Senior Administrator
Bas's Avatar
City: Raleigh
State: NC
County: Wake
Threads: 211
Avg Visit Freq/Week
= 6.96 over 180 days
Just a guess: To make it easier to guide it along a straight edge?
__________________
Bas.
I don't need it. I just want it.
Show Printable Version Email this Page   Quote this post in a PM to Bas
Old 01-07-2009, 01:57 AM   #4
thrt15nc's Avatar
City: Clayton
State: NC
County: Johnston
Threads: 39
Avg Visit Freq/Week
= 5.64 over 180 days
Let me take a guess at this. If you're routing a dado up against a guide using a router with a round base and the bit isn't perfectly centered to the base, AND you rotate the router a little, it could go out of it's straight line. If you use one with the straight side to the base you'll keep the router in the same placement and you won't have that problem?? Okay, I'm ready. Beat me up! Am I hallucinating?
Tom
__________________
"Until one has loved an animal, part of their soul remains unawakened." - Anatole France
Show Printable Version Email this Page   Quote this post in a PM to thrt15nc
Old 01-07-2009, 09:32 AM   #5
City: Holly Springs
State: NC
County: Wake
Threads: 159
Avg Visit Freq/Week
= 7.00 over 180 days
I know from use that there's more friction with the flat against a fence. And if the flat moves just slightly away from flush, the bit will swing greatly off track. But if a point on the round base is used as a reference, then less friction and the reference is more forgiving. In fact, I add a round base to my routers that have the flats.
This jig is the main reason I like a round base. The 2 fences are squeezed against a sample of the piece that will fit into the resultant dado regardless of it's thickness. I like to run the router down & back without having to rotate the router, cord & vac hose. BTW, this pic shows the setup for a rabbet, but dado or sliding DT the is same.
Old 01-07-2009, 09:54 AM   #6
Executive Vice-President
Libraries Administrator
McRabbet's Avatar
City: Hendersonville
State: NC
County: Henderson
Threads: 155
Avg Visit Freq/Week
= 6.88 over 180 days
I agree with Joe that is it easier to control round bases for accuracy -- I've had plenty of routers and my only ones without round bases are the little ones (a P-C Trim router and a Trend T3).
__________________
Rob Payne
Truths: There is no such thing as a 25 hour day, so why do I keep trying to cram so much into every day so it seems that way!
Show Printable Version Email this Page   Quote this post in a PM to McRabbet
Old 01-07-2009, 12:15 PM   #7
City: Holly Springs
State: NC
County: Wake
Threads: 159
Avg Visit Freq/Week
Bump
Old 01-07-2009, 12:30 PM   #8
City: Concord
State: NC
County: Cabarrus
Threads: 34
Avg Visit Freq/Week
= 6.03 over 180 days
I always thought it was because bases usually aren't perfectly centered, as Tom mentioned. I know i have run into problems before when i've used different points on a round base to guide the router along a fence.
__________________
Eric
Show Printable Version Email this Page   Quote this post in a PM to thrytis
Old 01-07-2009, 12:35 PM   #9
City: Lancaster
State: SC
County: Lancaster
Threads: 161
Avg Visit Freq/Week
Funny, the only router I have that does not have a round base is my largest router, 2.5 hp.
Old 01-07-2009, 12:39 PM   #10
Gotcha6's Avatar
City: Ivan's Corner (Monroe)
State: NC
County: Union
Threads: 87
Avg Visit Freq/Week
= 6.73 over 180 days
I think Tom has a valid point about some routers not being perfectly centered on their bases. The downside I see is when you may need to rout to a right angle & turn, you'd overshoot your line on the next cut. It shouldn't be a problem to rout against a circular base & straightedge as long as you aren't twirling the router around and around as you make the cut.
The flat could also be used to cut a dado wider than the bit if the difference between the 2 distances was within the limits and tolerances of what needed to be cut. Just make 1 pass on the flat and another on the circle.
OH! I just thought of the REAL reason. So's you can lay it down on its side & it won't roll off the table!
__________________
WHAT BOX?
Show Printable Version Email this Page   Quote this post in a PM to Gotcha6
Old 01-07-2009, 01:06 PM   #11
Name: Alan Schaffter
City: Washington
State: NC
County: Beaufort
Threads: 263
Avg Visit Freq/Week
= 6.69 over 180 days
Tom and Dennis
have it right. Some routers do not have the ability to center the bit.
By the way, you are missing out if you don't have a centering pin. A couple of places sell them. The one I like from Lee Valley has a 1/4" shank on one half and a 1/2" shank on the other. They are good for aligning the bushings and base (if he collars fit tight)
Woodcraft sells this:
Woodworker supply sells this:
I use this one from Lee Valley:
Show Printable Version Email this Page   Quote this post in a PM to Alan in Little Washington
Old 01-07-2009, 01:09 PM   #12
City: Holly Springs
State: NC
County: Wake
Threads: 159
Avg Visit Freq/Week
I just asked a sales clerk, and here's the answer. "It's so you don't put the black piece on backwards".
SPARE ME!
Was hoping CharlesM would chime in with a believeable answer.
My big Milwaukee has a round base, my DW625 and Freud2200E have a flat on the base. My small Sears have round bases and the GMC has a flat on he base.
Old 01-07-2009, 09:54 PM   #13
Treasurer
City: Wake Forest
State: NC
County: Wake
Threads: 184
Avg Visit Freq/Week
= 6.53 over 180 days
How does having a flat keep you from putting the black piece on backwards???
I had never thought of so it doesn't roll off the table. That does make sense, but I don't think I have had one of my round ones roll off anyway. It seems the handles stick out too far to let that happen.
Show Printable Version Email this Page   Quote this post in a PM to Travis Porter
Old 01-07-2009, 10:22 PM   #14
Alex Franke's Avatar
City: Chapel Hill
State: NC
County: Orange
Threads: 12
Avg Visit Freq/Week
= 0.00 over 180 days
Is it a plunge base? My guess is that it provides more friction/accuracy when you're plunging a hole while holding it against a straight edge. You don't want to router to rotate at all along the straight edge when all you want is a hole...
I would center the bit and use the round part to glide, though.
Show Printable Version Email this Page   Quote this post in a PM to Alex Franke
Old 01-07-2009, 10:30 PM   #15
Gotcha6's Avatar
State: NC
County: Union
Threads: 87
Avg Visit Freq/Week
SPARE ME!
If you're in the standard BORG the only thing you can find out from a sales clerk is where the restroom is & I already know that real well. I can read the box.
I find customer service in those places nonexistent. I will say that Lowe's has most of their sales clerks trained to tell you which aisle something is on -but they won't take you to it.
Maybe the correct answer to Joe's question is so they could get more bases outa one piece of plastic.
__________________
WHAT BOX?
Closed Thread
base , flat , part , router
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Plunge router base sticking at times jonnyfontaine Power Tools and Their Use 5 04-16-2008 10:16 AM
PC base for Bosch router made from scrap johnpipe108 "How To" Forum 4 04-30-2007 07:33 PM
Router-table sub-plate aids small part shaping johnpipe108 "How To" Forum 2 04-13-2007 12:22 AM
Order your 2010 Calendar!
Carolina Lumber Sourcing
» Stats
Members: 3,663
Threads: 25,104
Top Poster: DaveO (14,701)
Welcome to our newest member, Keith Senderak
» Today's Birthdays
Dick Barnes (74)
Powered by vBadvanced CMPS v3.2.0
Powered by vBulletin® Version 3.8.2
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.3.0
Template-Modifications by TMS
Content Copyright © 2005 - 2009 North Carolina Woodworker, Inc.
