Thanks to the help of C Powell, I finally got my Saylor Beall compressor up and running. I purchased this off Craigs list sometime last fall, sans a motor for $125.00 ( 5 hp 2 stage / 60 gal horizontal tank model) This is a stock photo which looks very much like mine.
[IMG]file:///C:/DOCUME%7E1/Owner/LOCALS%7E1/Temp/moz-screenshot.jpg[/IMG]
I had to purchase the following:
New 5 hp baldor motor single phase
New dual groove sheave for motor
New motor starter
New valve rebuild kit
New wrist pin for exhaust piston
New rod / rod cap inserts for both pistons
New pressure switch
New regulator
New belts
Since I was trying to do this as cheap as I could, I did all the replacement work myself and just needed the extra hand on wiring the starter and getting the head back on after I replaced the wrist pin and rod inserts
Total cost including the original purchase price is $804.00. Not exactly gloat worthy but if I were to buy this unit new, it would have been in the $2,500 - 3000 range. Built like a tank and right now it purrs like a kitten.
My next addition will be a hose reel which will add about another 100 or so. Shouldn't be starved for air from now on.
