| | #1 |
| Member | Cutterhead spring I recently bought a used 8" jointer. The knives needed changing. This is my first trying this task. While taking the old knives out I noticed that one knife had no springs in the holes. Either I lost them or they were missing when I started. I was wondering where do I go to get replacement springs. Also since I'm going through all this trouble is there anything else I should rebuild or do while I got the cutterhead apart? |
| | #2 |
| Moderator | Re: Cutterhead spring norm, if you use the jointer-pals, I don't think those springs will matter at all??? the magnets will hold the knife at the right height while you tighten 'em into place. I may be totally wrong, but my wife isn't here, so maybe just this once???
__________________ Failure is the opportunity to begin again more intelligently. – Henry Ford However your life is, meet it and live it. Henry David Thoreau They that can give up essential liberty to obtain a little temporary safety, deserve neither liberty, nor safety. Benjamin Franklin |
| | #4 |
| Member | Re: Cutterhead spring ![]()
__________________ Chad Pen turning is fast and fun! It is highly addictive! All your free time you once had will become a thing of the past!! And Down The Dark Side Of Woodworking You! Will! Goooooo!! ![]() |
| | #5 |
| Moderator | Re: Cutterhead spring Originally Posted by norm932 I wouldn't have told my wife about the missing springs!
Besides, the jig will make setting the knives that much easier, you might be able to justify both.
| | #6 |
| Member | Re: Cutterhead spring I would want the springs. Although a jointer pal/buddy will help, it is only an accessory. As to where to get the springs, Might try an Ace or True value hardware. If that doesn't work, a gun shop may have some. Since you are tuning the jointer up, I would additionally check to see if there is any sag in the tables that needs to be shimmed up. Metal beer (or soda) cans make good shim stock.
__________________ Forget the phase converter. Rules are either Bernhard, Scott or Nahm have one. Well, depends. It would be nice to be first. I HAVE THE ITCH AND AM OUT OF REMISSION!!!! WHAT TO BUY, WHAT TO BUY!!! ![]() ![]() |
| | #7 |
| Member | Re: Cutterhead spring no springs / jigs necessary for a spiral head. If your gonna get in hot water over a 30 dollar jig may as well make it worthwhile!
__________________ STRIKER |
| | #8 |
| Member | Re: Cutterhead spring 3 rare earth magnets and a 6" piece of steal works fine in lew of jointer jigs. you can also use a strip magnet glued to a strait edge. bring tables up to same level. stick the magnets to the steel one on each end and one in the middle. stick it to the table and center the middle magnet over the knife. do one side then the other only snuging it up. after set tighten all down. the jig is easier [i have one] but its not that hard to do without. |
| | #9 |
| Member | Re: Cutterhead spring Thanks guys, I got the knives changed and tables adjusted. Everything working fine, and finished boards are so flat they stick to the table (not bad for a first time rookie). BTW I had already heard from the wife when I bought the Jointer Pal last week. Which I will have to admit made the job alot easier than I thought it would be. Once "top dead center" was found and the other marks required for the jig, everything went smooth. |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Cutterhead Choices? | Woodman2k | Power Tools and Their Use | 8 | 05-13-2008 02:01 PM |
| shimming jointer cutterhead | gilliu | Power Tools and Their Use | 5 | 01-05-2008 12:30 AM |
| CLT CL: Grizzly 8" Jointer w/ Spiral Cutterhead | Tarhead | Found for Sale/Hot Deals | 4 | 01-01-2008 10:15 PM |
| Byrd cutterhead installation on Grizzly 0490 jointer | mike_wood | Power Tools and Their Use | 7 | 01-26-2007 05:09 PM |
