North Carolina Woodworker
Go Back   North Carolina Woodworker > Tools, Equipment, and Techniques > Power Tools and Their Use
Closed Thread
Old 05-11-2008, 03:00 PM   #1
Member
Woodman2k's Avatar
City: Mooresville
State: NC
County: Iredell
Threads: 25
Cutterhead Choices?
New Question , Old Subject?
What is the difference between a Shelix Cutterhead and a Spiral Cutterhead on a Jointer application.Do they perform the same? Is it safe to assume that a Shelix head is only coming from Byrd one way or another.It is an option from Grizzly although you can get the spiral head mounted but the Shelix head is ordered and shipped seperate to be installed by the owner.Steve,enlighten me before I make an expensive mistake.Are they the best two choices besides straight knifes?
Show Printable Version Email this Page   Quote this post in a PM to Woodman2k
Old 05-11-2008, 04:42 PM   #2
NCPete's Avatar
City: Hope Mills
State: NC
County: Cumberland
Threads: 196
Re: Cutterhead Choices?
Greg,
as I understand it, the Grizzly spiral heads have straight-edged cutters and approach the piece square to it, where the Byrd heads have a slight arc in the cutter which is presented on an angle to the piece being fed... does that make any sense?
__________________
Failure is the opportunity to begin again more intelligently. – Henry Ford
However your life is, meet it and live it.
Henry David Thoreau
They that can give up essential liberty to obtain a little temporary safety, deserve neither liberty, nor safety. Benjamin Franklin
Show Printable Version Email this Page   Quote this post in a PM to NCPete
Old 05-11-2008, 09:27 PM   #3
Member
Woodman2k's Avatar
City: Mooresville
State: NC
County: Iredell
Threads: 25
Pete,
I have seen two different versions of the spiral cutter.One has a spiral shaped long blade and the other one looks like a Shelix but the drum that the cutters are connected to is almost flush with the top of the cutters.I didn't notice the difference in the individual cutters but I will look at that.
Old 05-11-2008, 10:46 PM   #4
Webmaster
Libraries Administrator
Advisory Panel
McRabbet's Avatar
City: Hendersonville
State: NC
County: Henderson
Threads: 108
Here are pictures of the two types of cutterheads. The first is the standard carbide cutterhead that Grizzly offers for their jointers -- this 8" version is $ 295 on sale. Note that the cutters are in line with the axis of the cutterhead, but they are oriented in a spiral pattern around the head. They cut one at a time, but square to the work surface. Replacement cutters are about $24.95/10.
Here is the shelix cutterhead, made by Byrd and marketed by Grizzly, too (among others, including Byrd). Note that the cutters are not aligned parallel to the axis, but are at an angle as well as in a spiral pattern. They hit the work surface at an angle and have a shearing action. This 8" version is $ 349.95 on sale and replacement cutters are $29.95/10.
The Byrd head reportedly cuts even smoother than the spiral cutter and is probably worth the extra money.
__________________
Truths: My other vice is .... I got cleared by my Doctor, so I'm eager to get back to it!
Show Printable Version Email this Page   Quote this post in a PM to McRabbet
Old 05-12-2008, 08:04 AM   #5
Member
Sanders Woodworking's Avatar
City: Mount Ulla
State: NC
County: Rowan
Threads: 8
I have a Byrd cutterhead on a Powermatic 209HH. It gives an amazing finish, it's quiet and there is almost no vibration. I would pay the extra for the Byrd. I am reworking an old 16" jointer with a 2 knife cutterhead. I plan to buy a Byrd cutterhead for it if everything else is in good enough shape to warrant the expense.
Show Printable Version Email this Page   Quote this post in a PM to Sanders Woodworking
Old 05-12-2008, 09:19 AM   #6
Webmaster
Advisory Panel
SteveColes's Avatar
City: Apex
State: NC
County: Wake
Threads: 832
I had the byrd on my 6" Delta that I just sold, and just put one on the Shop Fox 8" (same as the grizzly 490) that I just bought. It's hard to believe the difference in noice, vibration, and smoothness of cut. Then I added a link belt, WOW!Well worth the extra money.
If it were me I'd go to Girozzly with the byrd. BUT be aware, that it was a real pain to remove the pully and bearings from the stock head.
__________________
Steve Coles
"If you can't say something nice, at least make it funny"
Show Printable Version Email this Page   Quote this post in a PM to SteveColes
Old 05-12-2008, 11:41 AM   #7
Member
Name: Alan Schaffter
City: Washington
State: NC
County: Beaufort
Threads: 183
Originally Posted by SteveColes View Post
I had the Byrd on my 6" Delta that I just sold, and just put one on the Shop Fox 8" (same as the grizzly 490) that I just bought. It's hard to believe the difference in noise, vibration, and smoothness of cut. Then I added a link belt, WOW!Well worth the extra money.
If it were me I'd go to Grizzly with the Byrd. BUT be aware, that it was a real pain to remove the pulley and bearings from the stock head.
I concur. Go with the Byrd.
I have one on my 8" jointer and there was one on my 15" planer that I sold. I would put one on my 20" but the price for a Shelix for the large head on my old Delta is too much (over $2K!!!!). Check out the price for one at Holbren (Contact Brian and mention the Woodnet 10% discount)
It is easy to remove the bearings if you use a bearing puller, which you don't have to buy- you can borrow them for free from AutoZone, Pecision Auto, etc. Don't attempt it without a bearing puller, unless you plan to replace the bearings, which is advisable if you have and old machine.
Show Printable Version Email this Page   Quote this post in a PM to Alan in Little Washington
Old 05-12-2008, 02:37 PM   #8
jtodd71's Avatar
City: Pfafftown
State: NC
County: Forsyth
Threads: 99
I have Allens Planer now and have a Delta 8 inch Joiner and it has the Byrd head also you can carry on a conversation while they are in use.
__________________
Jon Todd
www.98esten.com
Show Printable Version Email this Page   Quote this post in a PM to jtodd71
Old 05-13-2008, 02:01 PM   #9
Member
City: Raleigh
State: NC
County: Wake
Threads: 2
I have Steve Cole's jointer now, and it's so quiet it's unnerving. With ear protection on and the DC going, it's hard to tell if the jointer is running. One advantage of the Shelix is that the blades run at a slight diagonal to the work item, so it makes more of a slice than a straight chop. Helpful for figured wood.
Show Printable Version Email this Page   Quote this post in a PM to Vestus
Closed Thread
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
shimming jointer cutterhead gilliu Power Tools and Their Use 5 01-05-2008 12:30 AM
CLT CL: Grizzly 8" Jointer w/ Spiral Cutterhead Tarhead Found for Sale/Hot Deals 4 01-01-2008 10:15 PM
Router plate choices McRabbet Power Tools and Their Use 14 04-15-2007 10:00 AM
Byrd cutterhead installation on Grizzly 0490 jointer mike_wood Power Tools and Their Use 7 01-26-2007 05:09 PM
6" Jointer Choices Steve W Power Tools and Their Use 15 01-24-2007 11:57 PM
Powered by vBulletin® Version 3.7.0
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0 RC5
