North Carolina Woodworker
Discounts on 2010 NCWW Calendar through Nov 30th!!
Javascript DHTML Drop Down Menu Powered by dhtml-menu-builder.com
Go Back   North Carolina Woodworker > Tools, Equipment, and Techniques > Power Tools and Their Use
» Upcoming Events
Fall 2009 Raffle drawing this Friday (11/20): See This Thread For Details
Closed Thread
Old 11-22-2005, 09:04 AM   #1
Cove cutting with TS
D L Ames's Avatar
Name: D L Ames
City: Fayetteville
State: NC
County: Cumberland
Threads: 66
Show Printable Version Email this Page   Quote this post in a PM to D L Ames
D L Ames D L Ames is offline 11-22-2005, 09:04 AM
Does anyone have any advise or wisdom to share on cutting coves with the tablesaw. I have used this technique before on a very limited basis but would like to expand my knowledge on this technique.
Here is a set up I have used before to cut some coves on the top and bottom of some boxes I built.
In this case I clamped the fence up 45 degrees to the blade and ran my material through multiple passes raising the blade 1/16" for each pass.
This set up worked great for what I needed at the time but I understand you can use a similar set up to cut a full cove down the center of a board. I am just not sure how to set up the fence to make a full cove cut. A while back I read an article that mentioned you can change the shape (depth, width) of the cove by changing the angle of the fence to the blade.
Also, this technique requires a lot of sanding afterwards to remove the machine marks. Has anyone ever tried this technique using a molding head with a radius type cutter? If so, where the result any smoother?
I look forward to any advice that can be offered or discussion generated.
D L
__________________
People sleep peaceably in their beds at night only because rough men stand ready to do violence on their behalf. George Orwell (1903 - 1950)
Old 11-22-2005, 09:32 AM   #2
chris99z71's Avatar
City: Garner
State: NC
County: Wake
Threads: 163
Avg Visit Freq/Week
= 0.27 over 180 days
Re: Cove cutting with TS
Now don't take this as gospel because I've never tried it, but it seems that in order to get it down the middle of the board, you'd have to have your fence farther back from the blade (away from the user). Far enough that the blade doesn't contact the fence. Does this make any sense?
__________________
"If you can't learn to do something well, learn to enjoy doing it poorly."
----9-11-01----343----Never Forget----
Show Printable Version Email this Page   Quote this post in a PM to chris99z71
Old 11-22-2005, 09:51 AM   #3
Monty's Avatar
City: Hickory
State: NC
County: Catawba
Threads: 232
Avg Visit Freq/Week
= 2.02 over 180 days
I would think you need two fences - front and back, to hold the workpiece securely. Or a fence and featherboards. You can change the profile of the cove by altering not only the angle of the fence, but also the tilt of the blade. Get down on the level of the table saw surface and sight down the blade parallel to the fence to get an idea what the profile will look like with various changes in blade tilt/fence angle. Basically, tilting the blade will just move the apex of the cove over, creating a larger radius on one side and a tighter radius on the other side. There is also a parallelogram jig that can help with setting the fence angle.
There is an excellent web site on this subject here.
__________________
My fledgeling woodworking web site: ShootingBoard.net
Show Printable Version Email this Page   Quote this post in a PM to Monty
Old 11-22-2005, 10:10 AM   #4
chris99z71's Avatar
City: Garner
State: NC
County: Wake
Threads: 163
Avg Visit Freq/Week
Good link Insomniac! Now I can start thinking about a molding head cutter...must...resist...urge...AHHHHH!!!!
I believe I'm entering the advanced stages of woodguy disease, no...molding head cutters are under 1000lbs...
__________________
Old 11-22-2005, 10:11 AM   #5
City:
State:
County:
Threads: 35
Avg Visit Freq/Week
= 0.00 over 180 days
I agree with Insomniac, use the double guide board method and whatever you do use push sticks and pads. One of my closest woodworking friends just ran fingers though a window molding bit on the router table over the weekend. To me the coving operation is a dangerous operation under any circumstances and I always recommend using push pads to control the stock, no hands!
I also recommend using a nice sharp 50 tooth combination blade. Let's be careful out there
Show Printable Version Email this Page   Quote this post in a PM to Big Mike
Old 11-22-2005, 11:10 AM   #6
Joe Scharle's Avatar
City: Holly Springs
State: NC
County: Wake
Threads: 159
Avg Visit Freq/Week
= 7.00 over 180 days
As you've already discovered it's a long, slooooow process. When I've had to do it (not often, because if I can buy a pre milled molding, I will) I'll hog out as much of the waste as I can with a dado blade or molding set fed straight on using the saw fence. Then my finish pass will be between 2 board fences set at whatever angle that allows the front and rear of the piece to pass the same tooth of my regular sawblade. Leave yourself plenty of wood between the top of the cove and the flat part you're pushing down on. It's scary when the board snaps halfway through the blade. The millmarks are a pain. I used 2-3 flutter sets on my drill before I got it to the point I could hand sand with paper wrapped around a big round turning. Good luck
Show Printable Version Email this Page   Quote this post in a PM to Joe Scharle
Old 11-22-2005, 11:44 AM   #7
City:
State:
County:
Threads: 35
Avg Visit Freq/Week
DL, I failed to answer part of your question. No, I have never used a molding head cutter but once I saw Norm do it on NYW. He used a 1" round nose to cut his cove and it seemed to do a wonderful job. It would scare me to death to think about that big cutter whirling under the wood which can break at any time as Joe said. Try not to pass your hands or push blocks over the cutting area if you can help it.
Old 11-22-2005, 11:56 AM   #8
Member
Steve D's Avatar
City: Horse Shoe
State: NC
County: Henderson
Threads: 69
Avg Visit Freq/Week
Yikes.... Call Woodguy, he just bought a moulder / planer. (it only average out to 1000 lbs when combined with the rest of his recent tool haul).
As already stated, use care. Also make sure that your stock and fences are flat and straight.
Show Printable Version Email this Page   Quote this post in a PM to Steve D
Old 11-22-2005, 03:01 PM   #9
sapwood's Avatar
City: Durham
State: NC
County: Durham
Threads: 216
Avg Visit Freq/Week
= 6.42 over 180 days
Well, I'm probably in over my head here--but what the heck
I've used a taper jig riding along fence to cut a cove. By using featherboards, clamping, and whatever; and utilizing the handle on the taper jig I was able to keep my hands away from blade. The tapering jig also provided a bit more length than the fence alone does.
Does this sound dangerous?
Sapwood
__________________
I ain't never had too much fun!
Show Printable Version Email this Page   Quote this post in a PM to sapwood
Old 11-22-2005, 03:26 PM   #10
mkepke's Avatar
City: Fuquay Varina
State: NC
County: Wake
Threads: 56
Avg Visit Freq/Week
= 6.14 over 180 days
I use a basic set up consisting of two scrap guide boards clamped to the saw table with a Sears molding head with 1" radius knives.
My set up removes wood in a very..expeditious..manner (3HP saw and big knives on the molding head).
There are four basic parameters of the cove that you can modify:
1) the location of the cove in the board. You modify this by moving the guide boards forward or backward on the saw table relative to the leading AND trailing teeth of the blade
2) the height of the cove. Via the tablesaw height adjustment
3) arc of the cove. This one is tricky. It is a result of the angle of incidence formed between the guide boards and the saw blade. The more acute the angle, the 'tighter' the arc.
4) the evenness of the cove, i.e. whether it is an even cove or a lopsided cove. You vary the bevel angle setting of the saw blade.
I prefer using a molding head cutter since it is both stronger and cheaper than using a good blade.
Gooseneck cabinet scraper is a must for removing saw marks (as luck has it, Woodcraft has 'em on sale this week).
I agree that it is (never) a good idea to pass hands or pushblocks directly over the blade. An easy remedy is to screw some scrap plywood or even better lexan across the guide-boards thereby covering the blade.
-Mark
Show Printable Version Email this Page   Quote this post in a PM to mkepke
Old 11-22-2005, 10:30 PM   #11
D L Ames's Avatar
Name: D L Ames
City: Fayetteville
State: NC
County: Cumberland
Threads: 66
Avg Visit Freq/Week
Thanks to all for your responses to this thread. I fully concur with all the comments on safety and the hazards associated with this type of operation. You're right Big Mike, a molding head cutter would be a big chuck of steel whirling away not far from the fingers......yikes.
Insom, that is a very informative link and helps me a bunch. I especially liked the chart laid out on that link that shows various profiles that can be formed by changing the angle of the fence and the bevel of the blade. That chart is worth printing and keeping on file out in the shop.
Sapwood, the technique you used sounds interesting but I am having a hard time visualizing it in my mind. Do you by chance have an pics of this set up we could look at?
Mark, thanks for your post outlining the parameters that effect the profile of the cove and how changes to these parameters modify the final outcome. I like the idea of adding a guard to the fences above the blade.
Bladeburner, good point about leaving enough wood at the bottom of the cove. I bet having the board snap halfway through would add a little too much excitement into one life and exactly the wrong moment.
D L
__________________
Old 11-22-2005, 11:59 PM   #12
mkepke's Avatar
City: Fuquay Varina
State: NC
County: Wake
Threads: 56
Avg Visit Freq/Week
Gratuitous cove molding shot. The beads on the top and bottom edges are made by bead cutters in the same molding head used for the cove itself.
The crack did not appear until AFTER I got .5" through the thickness. Oh well.
The wood is 5/4 red oak.
-Mark
Old 11-23-2005, 08:28 AM   #13
D L Ames's Avatar
Name: D L Ames
City: Fayetteville
State: NC
County: Cumberland
Threads: 66
Avg Visit Freq/Week
Wow........great photo Mark. It's amazing to stand there and look at a tablesaw and even begin to imagine some of the things that it is capable of producing. Beautiful work.
D L
__________________
Old 11-23-2005, 12:25 PM   #14
Executive Vice-President
Libraries Administrator
McRabbet's Avatar
City: Hendersonville
State: NC
County: Henderson
Threads: 155
Avg Visit Freq/Week
= 6.88 over 180 days
D L - There is an excellent, well-illustrated article on cutting coves on a table saw in Fine Woodworking, No 168 (January/February 2004) on pages 68-73. In addition to set-up methods, safety and "how-to's", the author has provided a method to establish the proper blade height, tilt angle and fence angles for cutting any cove you want. Originally in the form of an Excel spreadsheet, there is an online calculator on the Fine Woodworking website at http://www.taunton.com/finewoodworking/pages/nmw030.asp.
I also found a calculator you can download on Woodbin.com at http://www.woodbin.com/downloads/index.htm Cove safely!
I found another article in Woodworker's Journal (October 2003, pg 60-61) that includes an Excel spreadsheet formula to calculate fence angles for symmetrical coves given the desired depth and width.
Originally Posted by D L Ames
Thanks to all for your responses to this thread. I fully concur with all the comments on safety and the hazards associated with this type of operation. D L
__________________
Rob Payne
Truths: There is no such thing as a 25 hour day, so why do I keep trying to cram so much into every day so it seems that way!
Last edited by McRabbet; 12-07-2005 at 10:35 PM.. Reason: Added WWJ article reference
Show Printable Version Email this Page   Quote this post in a PM to McRabbet
Old 11-23-2005, 01:00 PM   #15
D L Ames's Avatar
Name: D L Ames
City: Fayetteville
State: NC
County: Cumberland
Threads: 66
Avg Visit Freq/Week
Rob, Those are both dynamite and very informative links. Thanks for posting them.
D L
__________________
Closed Thread
cove , cutting
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
TS Jig for cutting spline slots. D L Ames General Woodworking 1 11-05-2005 11:02 PM
Order your 2010 Calendar!
Carolina Lumber Sourcing
» Stats
Members: 3,663
Threads: 25,104
Top Poster: DaveO (14,701)
Welcome to our newest member, Keith Senderak
» Today's Birthdays
Dick Barnes (74)
Powered by vBadvanced CMPS v3.2.0
Powered by vBulletin® Version 3.8.2
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.3.0
Template-Modifications by TMS
Content Copyright © 2005 - 2009 North Carolina Woodworker, Inc.
