North Carolina Woodworker
Changes to DQ as of 12/1/2008 Very important that you read
Go Back   North Carolina Woodworker > Tools, Equipment, and Techniques > Power Tools and Their Use
Notices
» Announcements
Everyone Log on at 9:00PM Thursday December 4th to set a members online record.
Featured Photos
by toolman
24861 photos
9957 comments
by newtonc
24861 photos
9957 comments
by jstraw
24861 photos
9957 comments
by bluewing92
24861 photos
9957 comments
» Online Users: 58
22 members and 36 guests
bluthart , ccccarving , gordonmt , jeff... , Jim Roche , manirban73 , Mike Davis , Mike Gilley , MIKE NOAH , NCTurner , newtonc , NZAPP1 , Partman , PeteM , Ralrick , rcflyer23 , russellellis , Splint Eastwood , SteveColes , titan04 , tom hintz , woodlaker2
Most users ever online was 180, 04-22-2008 at 12:18 AM.
Closed Thread
Old 04-12-2008, 03:07 PM   #1
davejones's Avatar
City: Stokesdale
State: NC
County: Guilford
Threads: 14
Avg Visit Freq/Week
= 3.27 over 30 days
I'm trying to cut some 3-1/2" wide strips of 3/4" birch ply on my Compound Miter Saw, but it seems to want to burn through the wood rather than cut it.
The blade is the cheapo original that came with the saw, but it does say it is a plywood blade and has not seen much wood in its lifetime. I thought it was just due to some buildup on the blade, but I cleaned it and the burning did not improve at all. Also, the motor bogs down while cutting burning through the wood.
Is it just time for a new blade? Would sharpening be likely to correct this? Any experience you all can share would be greatly appreciated.
Thanks in advance!
Show Printable Version Email this Page   Quote this post in a PM to davejones
Old 04-12-2008, 03:20 PM   #2
Ray Martin's Avatar
City: Raleigh
State: NC
County: Wake
Threads: 98
Avg Visit Freq/Week
= 0.00 over 30 days
Dave,
I guess the first thing that I'd check would be the blade. Is it sharp and is it clean? Is the blade flat? does it have a bent tooth? Does it appear to have a wobble to it when it runs? The problem could also be the wood. If the motor is bogging down in 3/4" ply, check the wood to see if it is twisted, warped, bent, curved, etc. If the wood has any movement to it while you are cutting, that could bind the blade too.
What kind of a saw are you using? Might also be time for a tune up.
Ray
__________________
I cut that board twice and it's STILL too short.
Show Printable Version Email this Page   Quote this post in a PM to Ray Martin
Old 04-12-2008, 03:32 PM   #3
davejones's Avatar
City: Stokesdale
State: NC
County: Guilford
Threads: 14
Avg Visit Freq/Week
= 3.27 over 30 days
Thanks for the quick reply Ray. The blade doesn't seem to wobble, and the wood doesn't seem to be the problem either. The burning starts as soon as the blade touches the wood (no kerf to close up yet).
I'm not really sure how sharp the blade is. It hasn't been used in a while and had some buildup on it, which I tried to clean. I may try to go over it again and see if that helps.
The saw is a Ryobi Compound Miter Saw. Not an expensive saw, or overly powerful, but I would expect it to cut better than it is.
Old 04-12-2008, 03:47 PM   #4
Ray Martin's Avatar
City: Raleigh
State: NC
County: Wake
Threads: 98
Avg Visit Freq/Week
= 0.00 over 30 days
Dave,
OK... back to the blade. Make sure the teeth are clean of any pitch, gum, peanut butter, etc. Is this an all steel blade? If it is a carbide blade, the carbide is brazed on to the tips of the teeth. They should stick out to the side of the blade body just a bit... maybe a 1/32". If the blade is perfectly flat (teeth not set / no carbide), then the sides of the teeth are rubbing on the sides of your cut and heat builds up really quick. If this is the case, just replace the blade. A good blade (sharp and clean) will leave a very smooth cut and should generally be burn free. (Some woods just burn rally easily.)
Ray
__________________
Old 04-12-2008, 04:34 PM   #5
City: Clayton
State: NC
County: Johnston
Threads: 142
Avg Visit Freq/Week
= 4.90 over 30 days
One other question, and I'm not trying to be funny, is the blade installed backwards ? You wouldn't be the first person here to install a blade backwards DAMHIKT.
Also if it is correctly installed, is it a carbide blade, if not , just replace it.
Good luck,
Jimmy
__________________
Jimmy
"There are no strangers here, only friends that haven't met"
I only buy what I need now, not what I want..... except for lumber !
Remember: Support your local Sawyers and Kiln Operators.
Show Printable Version Email this Page   Quote this post in a PM to JimmyC
Old 04-12-2008, 06:51 PM   #6
Director
toolferone's Avatar
City: Raleigh
State: NC
County: Wake
Threads: 147
Avg Visit Freq/Week
= 7.00 over 30 days
For plywood I would use a 80 tooth carbide blade. I feel pretty sure the blade is the problem.
__________________
Tom
www.dreamshopwoodworks.com
TWA
Triangle Woodworking Association Member
Membership chairperson.
Show Printable Version Email this Page   Quote this post in a PM to toolferone
Old 04-12-2008, 08:05 PM   #7
davejones's Avatar
City: Stokesdale
State: NC
County: Guilford
Threads: 14
Avg Visit Freq/Week
= 3.27 over 30 days
I tried cutting a 2x4 and it went right through it, so the blade is installed the right way. It is all steel, no carbide.
I was able to get by today using the table saw (oops! gave away my gloat before I had a chance to post it), but I think the next time I need the Compound Miter Saw I will be buying a new blade.
Thanks for your input.
Old 04-12-2008, 09:09 PM   #8
Director
gator's Avatar
City: Oxford
State: NC
County: Granville
Threads: 122
Avg Visit Freq/Week
= 7.00 over 30 days
Push come to shove, you could use your table saw blade on the Compound Miter Saw. It won't have the negative hook angle preferred for a Compound Miter Saw but should work well enough to cut 3/4" material.
George
__________________
2B1ASK1
Show Printable Version Email this Page   Quote this post in a PM to gator
Old 04-12-2008, 10:48 PM   #9
Trent Mason's Avatar
City: Wrightsville Beach
State: NC
County: New Hanover
Threads: 34
Avg Visit Freq/Week
= 6.77 over 30 days
The blade that came with my bandsaw had me thinking I needed a new bandsaw. It wouldn't even resaw a 2x4". Then I bought a new (much better) blade and was resawing 4x4's of brazilian cherry all day yesterday with no problems at all. I would just buy a new better blade. Good luck!
Trent
__________________
"flight of the sea birds, scattered like lost words......"
The ability to do woodworking no longer available in Bud Light.
"We should never separate the lives we live
from the words we speak."
— Paul Wellstone
Show Printable Version Email this Page   Quote this post in a PM to Trent Mason
Old 04-13-2008, 01:31 AM   #10
City: Chapel Hill
State: NC
County: Orange
Threads: 19
Avg Visit Freq/Week
= 6.07 over 30 days
Def. get a new blade. I used the one that come on my Bosch and they are total crap. It was burning 1x2 oak then I switched over to the infinity tools Compound Miter Saw blade and it was like having a totally new saw with a ton more power. I kept the old blade and used it to cut laminate flooring.
Wes
Show Printable Version Email this Page   Quote this post in a PM to Kicbak
Closed Thread
blade , cms , problem
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Similar Threads
[Problem-Gallery] [Problem-Gallery] Minor problem entering Detail in photo's. KC7CN Help Desk 3 11-19-2007 01:34 AM
[Problem-Gallery] Problem viewing cskipper Help Desk 3 10-28-2007 09:47 PM
Problem squaring blade on saw... oderus1671 Scrollsaw Work 13 02-13-2007 07:18 PM
» Log in
User Name:
Password:
Not a member yet?
Register Now!
Search Rockler.com's Extensive Woodworking Catalog
Search from over
9000 products!
Highland Woodworking Link
» Stats
Members: 2,135
Threads: 16,382
2nd Top Poster: jeff... (6,359)
Welcome to our newest member, rsellers
» Today's Birthdays
Red Sonja (39)
Powered by vBulletin® Version 3.7.0
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Content Copyright © 2005 - 2008 North Carolina Woodworker, Inc.
