» Announcements | Everyone Log on at 9:00PM Thursday December 4th to set a members online record.  | » Online Users: 69 | | 22 members and 47 guests | | Bas , bluthart , Canuck , Douglas Robinson , enm , fivestring , FredP , GeorgeL , Howard Acheson , JackLeg , jwallwork , Kicbak , Larry Rose , manirban73 , Mike Davis , NCTurner , Partman , Sandy Rose , SteveColes , tmerrill , TopKnot , woodnick | | Most users ever online was 180, 04-22-2008 at 12:18 AM. |  | |
04-21-2008, 09:21 PM
#1 |
Name: Rick City: Autryville State: NC County: Cumberland Join Date: Feb 2006 Avg Visit Freq/Week = 6.30 over 30 days | I know that this has been discussed numerous times, but I have Freud table saw blades that accumulate pitch on the carbide tips. Freud recommends kerosene as a cleaner, but it just doesn;t seem to cut the pitch for me. I have tried using bristle and brass bristle brushes, but the pitch stubbornly stays put even after soaking for days.
Do you think that making a small scraper out of brass or aluminum would damage the carbide tips? A scraper is the only option I seem to have because brushes don't seem to work.
Thanks for any suggestions. |
04-21-2008, 09:24 PM
#2 |
Name: Jimmy Coull City: Clayton State: NC County: Johnston Join Date: Sep 2006 Age: 49 Avg Visit Freq/Week = 4.90 over 30 days | Rick,
You'll find a good cleaning method in the post link below.
Jimmy http://www.ncwoodworker.net/forums/s...ad.php?t=10854
__________________
Jimmy "There are no strangers here, only friends that haven't met " I only buy what I need now, not what I want..... except for lumber ! Remember: Support your local Sawyers and Kiln Operators. |
04-21-2008, 09:34 PM
#3 |
Name: Jerry City: Salisbury State: NC County: Rowan Join Date: Feb 2006 Avg Visit Freq/Week = 7.00 over 30 days | I have found that oven cleaner does a great job removing pitch from saw blades. I also use a brass bristle brush along with it if I get in a hurry. Rinse good with hot water afterward and dry.
Jerry
__________________
We make a living by what we get...............We make a life by what we give
#4 |
Name: Dennis Reynolds City: Ivan's Corner (Monroe) State: NC County: Union Join Date: Jan 2007 Avg Visit Freq/Week = 6.53 over 30 days | I found that link interesting. Baking soda or strong coffee. Hmmmm...... I wonder what it'd cost to soak a saw blade or 2 in some o' that frappucino stuff from Starbuck's? .gif) |
04-21-2008, 09:41 PM
#5 |
Name: Greg City: Gastonia State: NC County: Gaston Join Date: Oct 2006 Age: 44 Avg Visit Freq/Week = 5.83 over 30 days | If you want to spend a few buck$, I have had great success with the CMT 2050 cleaner. I'm not cutting a lot of sappy pine or whatever, but this stuff cleans my blades in about 30 minutes.  Not sure if Woodcraft has a sample bottle so you can "try before you buy", but might be worth asking.
__________________ |
04-21-2008, 10:27 PM
#6 |
Name: Mark City: Goldsboro State: NC County: Wayne Join Date: Mar 2006 Avg Visit Freq/Week = 6.30 over 30 days | Denatured alcohol works well for me. Dissolves the resin in about 5 minutes to where it easily wipes off with a rag or using a tooth brush or soft bristle parts brush for the worst spots. Doesn't damage the factory coating on the blade and doesn' chemically react with the solder on the teeth or the carbide like a strong alkaline cleaner will.
__________________
My only regret in life is that I did not listen more and talk less
04-21-2008, 10:51 PM
#7 |
Name: Bruce City: Apex State: NC County: Wake Join Date: Nov 2005 Avg Visit Freq/Week = 6.77 over 30 days | I take a lid from a drywall compound bucket and place blade in it. Then I spray the teeth with LA's Awesome from the dollar store. I like the orange kind, as it smells better. If the blade is really gunked up, I take a second lid and place on top of the first, and let blade steep a few minutes. Then I take either a nylon, of brass brush and clean blade. The brushes come from HF and are often on sale for less than a buck for a pack of three that includes a nylon, brass, and stainless steel brushes. Rinse, dry and spray with rust preventive. Main thing is to not wait till it is an impossible job. |
04-21-2008, 10:59 PM
#8 |
Name: Amy Dowden City: Chapel Hill State: NC County: Orange Join Date: Jul 2006 Avg Visit Freq/Week = 2.33 over 30 days | I use Rockler's pitch and resin cleaner to clean my freud blades and it does a great job. Back around Christmas they had a set of the concentrated cleaner, a pan to fit the blade in, a brass brush, and a little container for router bits on clearance for around $10. The pan even has a spout to pour the solution back out. I just store it in a one gallon milk jug.
It looks like they don't have the clearanced kit anymore. Here is a link to the new kit ($25): http://www.rockler.com/product.cfm?p...esin%20cleaner
I'm cheap. I would only buy the cleaner and I would buy an oil pan somewhere else.
Amy |
04-21-2008, 11:22 PM
#9 | | Vice-President Libraries Administrator
Name: Rob City: Hendersonville State: NC County: Henderson Join Date: Nov 2005 Age: 66 Avg Visit Freq/Week = 7.00 over 30 days | I use a product called Sprayway No. 836 Saw Cleaner (Pitch and Gum Remover), but it needs to be used with caution (as shown in this NIH report) because it contains quite a bit of Sodium Hydroxide. It is a spray product -- I don nitrile gloves and use it on the blade in a plastic tray and then loosen any stubborn pitch using a stiff nylon brush after letting it soak for 4-5 minutes. Then I Wipe off all of the residue with a clean terry cloth rag and spray the blade with a thin film of WD-40, which gets wiped off as well. Blades look like new. I know that Oven cleaner has lots of Sodium Hydroxide too and that is why Freud doesn't like it, but I've never seen any problems using this stuff the way I do.
I'd like to hear from Charles M if he thinks I'm compromising my good carbide blades (I haven't used it on my Freud LU85R012 96-tooth ultimate, 'cause it stays clean!!).
__________________
Rob  Truths: There is no such thing as a 25 hour day, so why do I keep trying to cram so much into every day so it seems that way! |
04-22-2008, 08:43 AM
#10 |
Name: Charles City: High Point State: NC County: Guilford Join Date: Nov 2005 Avg Visit Freq/Week = 3.50 over 30 days | Originally Posted by McRabbet I use a product called Sprayway No. 836 Saw Cleaner (Pitch and Gum Remover), but it needs to be used with caution (as shown in this NIH report) because it contains quite a bit of Sodium Hydroxide. It is a spray product -- I don nitrile gloves and use it on the blade in a plastic tray and then loosen any stubborn pitch using a stiff nylon brush after letting it soak for 4-5 minutes. Then I Wipe off all of the residue with a clean terry cloth rag and spray the blade with a thin film of WD-40, which gets wiped off as well. Blades look like new. I know that Oven cleaner has lots of Sodium Hydroxide too and that is why Freud doesn't like it, but I've never seen any problems using this stuff the way I do.
I'd like to hear from Charles M if he thinks I'm compromising my good carbide blades (I haven't used it on my Freud LU85R012 96-tooth ultimate, 'cause it stays clean!!). Sodium Hydroxide (Lye) is one of the chemicals to avoid as it will attack the bond between the cobalt and the tungsten and might also affect the brazing. Sounds like that's about the same as oven cleaner. |
04-22-2008, 10:41 AM
#11 |
Name: Dolan Brown City: Wallace State: NC County: Duplin Join Date: Dec 2005 Age: 60 Avg Visit Freq/Week = 6.07 over 30 days | The best and cheapest thing I have used is Greased Lighting http://www.samsclub.com/shopping/nav...=5&item=197831
I mix is 1 part cleaner and 1 part water. Put it in a spray bottle. Lay the blade on two shop towel, spray the blade...let it set for a minute or two and brush with an old toothbrush. Presto clean blade.
__________________
You can't work without tools.
So many tools so little money. |
04-22-2008, 12:22 PM
#12 |
Name: David City: Raleigh State: NC County: Wake Join Date: Feb 2007 Age: 47 Avg Visit Freq/Week = 2.33 over 30 days | Lacquer thinner will work.
David |
04-22-2008, 12:26 PM
#13 |
Name: Todd Vaughn City: Holly Springs State: NC County: Wake Join Date: Feb 2007 Age: 34 Avg Visit Freq/Week = 5.60 over 30 days | I use the water and baking soda method. Has worked for me so far.
tv
__________________
I'm Jayhawk born and Jayhawk bred and when I die I'll be Jayhawk dead. ... |
04-22-2008, 01:32 PM
#14 |
Name: Gazzer City: Durham State: NC County: Durham Join Date: Aug 2006 Avg Visit Freq/Week = 3.73 over 30 days | I've been using a solution of TSP with good success for a long time. Soak times are a bit longer (hour or two) but it's cheap and works well.
-G |
04-22-2008, 03:10 PM
#15 | | Site Programmer
Name: Jim Campbell City: Hillsborough State: NC County: Orange Join Date: Feb 2006 Age: 38 Avg Visit Freq/Week = 3.03 over 30 days | Boiling hot water and dish soap.
Beware, Palmolive softens the blades so much that you won't need to use any Oil of Olay to keep the blade soft and silky smooth..... (kidding).
__________________
"Its not about the destination, its about the joinery!"
| |  | | | Thread Tools | | | | Display Modes | Linear Mode |
Posting Rules
Members: 2,135
Threads: 16,380
2nd Top Poster: jeff... (6,357) | | Welcome to our newest member, rsellers | |
