North Carolina Woodworker
Discounts on 2010 NCWW Calendar through Nov 30th!!
Javascript DHTML Drop Down Menu Powered by dhtml-menu-builder.com
Go Back   North Carolina Woodworker > Tools, Equipment, and Techniques > Power Tools and Their Use
» Upcoming Events
Fall 2009 Raffle drawing this Friday (11/20): See This Thread For Details
Closed Thread
Old 01-19-2009, 09:50 PM   #1
Bandsaw extension tables?
merrill77's Avatar
City: Raleigh
State: NC
County: Wake
Threads: 42
Show Printable Version Email this Page   Quote this post in a PM to merrill77
merrill77 merrill77 is offline 01-19-2009, 09:50 PM
I expect the primary uses for my new bandsaw will be resawing and cross-cutting to length. In either case, it seems like it would be handy to have significantly longer tables (front, back and side). Due to my space constraints, they would need to fold down when not in use. I flipped through all of the bandsaw jigs in my ShopNotes collection and found nothing of the sort.
Anyone ever heard of such a thing?
__________________
Turning beautiful wood into scraps...one board at a time.
Go Boilermakers!
Old 01-19-2009, 10:00 PM   #2
Administrator
DaveO's Avatar
City: Clayton
State: NC
County: Johnston
Threads: 692
Avg Visit Freq/Week
= 7.00 over 180 days
Re: Bandsaw extension tables?
I use roller stands when ripping or re-sawing long length stock on my bandsaw. I personally wouldn't turn to my bandsaw for precision cross-cuts.
I would suspect that you could make folding extension tables for the bandsaw the same way you would make them for a tablesaw. A narrow fixed piece attached to the table with the longer table hinged to it. Fold up legs that would drop into place as the tables were unfolded.
Dave
__________________
Nothing left to do but smile, smile, smile
--Dr. Seuss
Show Printable Version Email this Page   Quote this post in a PM to DaveO
Old 01-20-2009, 09:47 AM   #3
Treasurer
City: Wake Forest
State: NC
County: Wake
Threads: 184
Avg Visit Freq/Week
= 6.53 over 180 days
I made a set with fold out legs that I clamped on to my big bandsaw. Nothing special. I just made a U out of some plywood the length that I wanted. Reason I made a U was to hold the plywood straight with right angles. At the far end, I put another piece of plywood on it that acted as a "pivoting" leg so when I took this assembly off I could fold up the leg, and finally, on the edge closest to the bandsaw I put just screwed a piece of plywood to give me a place to clamp/bolt the thing to the table.
All in all, it turned out pretty well. The plywood I used was some of the special wavy wood Home Depot and Lowes carries so it had a few issues. Getting it lined up correctly so that it didn't interfere with the rip fence was not easy, and it will have to be modified depending on your type of fence and bandsaw, but not too bad.
Lets see.... Any regrets.... Not really. It worked, and I still have them. I was using the set up to resaw 8 foot long pine two by fours and it worked well. I would make a couple of improvements. USE GOOD PLYWOOD!!!! Good jigs need good quality materials. I would also probably put a lag screw in the bottom of the legs to act as an adjuster so I could get the table level.
Show Printable Version Email this Page   Quote this post in a PM to Travis Porter
Old 01-20-2009, 10:25 PM   #4
City: Apex
State: NC
County: Wake
Threads: 301
Avg Visit Freq/Week
= 6.30 over 180 days
A couple (?) years back, John White did an article on "pimping out" a band saw. He built a stand, and best I can remember, he added wings to stand. Article was in FWW. Maybe I can find it. If someone has FWW on CD, they could look it up fast.
Show Printable Version Email this Page   Quote this post in a PM to junquecol
Old 01-21-2009, 12:39 AM   #5
City: Weddington
State: NC
County: Union
Threads: 11
Avg Visit Freq/Week
= 5.06 over 180 days
Here's the article:
http://www.taunton.com/finewoodworki...F.aspx?id=2810
Pretty cool shopmade base at the end.
Show Printable Version Email this Page   Quote this post in a PM to PeteQuad
Old 01-26-2009, 09:23 PM   #6
merrill77's Avatar
City: Raleigh
State: NC
County: Wake
Threads: 42
Avg Visit Freq/Week
= 5.91 over 180 days
Hey Dave (or anyone else) - can you elaborate on this?
Is this due to the small work surface? Blade drift? Blade marks on the cut surface?
__________________
Go Boilermakers!
Old 01-26-2009, 09:48 PM   #7
Administrator
DaveO's Avatar
City: Clayton
State: NC
County: Johnston
Threads: 692
Avg Visit Freq/Week
Yes to all of the above. And I have a tablesaw and Compound Miter Saw that will do the job much better. I would guess with proper, highly meticulous tuning and an awesome blade you could get your bandsaw to cut as cleanly as a tablesaw or Compound Miter Saw. But I have never seen a cut that rivals them...close but there is still tooth marks.
Dave
Dave
__________________
--Dr. Seuss
Old 01-26-2009, 10:39 PM   #8
Gotcha6's Avatar
City: Ivan's Corner (Monroe)
State: NC
County: Union
Threads: 87
Avg Visit Freq/Week
= 6.73 over 180 days
IIRC a few years back Dave Marks did a project where he cut tenons on a bandsaw using a back stop on the blade. Other than that one time I've never seen anyone use one for a clean cross cut. DaveO is right. To get a fine tooth cut you have to have a thin blade and that amplifies drift, and a thicker blade will have a coarse tooth count for a poor cut. It's a lose - lose proposition - but could be tried as a last resort.
__________________
WHAT BOX?
Show Printable Version Email this Page   Quote this post in a PM to Gotcha6
Closed Thread
bandsaw , extension , tables
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Bedside tables just about done . . . PeteM General Woodworking 19 03-24-2008 03:48 PM
Matching End Tables stoneskippers General Woodworking 19 12-18-2007 10:14 AM
Bedside tables - WIP PeteM General Woodworking 6 11-19-2007 08:26 AM
End Tables Joe Scharle General Woodworking 19 09-12-2007 12:23 AM
Outfeed Tables Canuck Power Tools and Their Use 8 02-17-2006 09:29 PM
Order your 2010 Calendar!
Carolina Lumber Sourcing
» Stats
Members: 3,663
Threads: 25,105
Top Poster: DaveO (14,701)
Welcome to our newest member, Keith Senderak
» Today's Birthdays
Dick Barnes (74)
Powered by vBadvanced CMPS v3.2.0
Powered by vBulletin® Version 3.8.2
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.3.0
Template-Modifications by TMS
Content Copyright © 2005 - 2009 North Carolina Woodworker, Inc.
