I own a model 1014 variable speed Jet mini lathe. i placed a double pole, double throw switch in the control box and it worked fine. I had both forward and reverse directional flow of the motor until I actually accidentally hit the double pole switch while in forward motion.
Now all i have is wide open speed, still in both directions. My question is I guess I burnt the contacts closed in the rheostat switch (the variable control switch) or do you think I burnt the circuit board somewhere.
I am electrically inclined and understand switches, relays and such. I am just not all that familiar with the electronic side of things such as all of those little resistors, diodes and such.
Any info or advice, would be greatly appreciated.
Man alive...........
