Originally Posted by Travis Porter
$600 seems a bit high to me.
Depends where you're coming from. I happen to know that the 28-350 is the modern day equivalance of a $5000.00 plus bandsaw in quality. A couple of years back I found two at Dempsey's in Richmond VA. He wanted $1200.00 for the pair. One was three phase, both needed the $75.00 tires, bearings, guide tune up, tire crowning, belts, and one needed a pulley. I handed him the cash right then and there and came back with my Safari van and collected both of them.
One went unrestored to a friend. He loaded it on a trailer. When unloading it, the saw fell over on the ground. He called asking what could be wrong. Answer: Nothing. Set it up and get on with the restoration. It made a believer out of him.
The guides are easy to adjust and are similar to the old Delta 14's, only on steroids. Consider: Two tangent circles give how much contact? Two 5/8" blocks of hardened steel give how much contact? Also the side blocks don't emboss the blade with gummy sawdust if you're resawing or busting out green bowl blanks.
Put a total of $1200.00 into one and you'll still be about 40¢ on the dollar value. The fact that other sellers call their product a "bandaw" doesn't necessarily mean its the same thing.
$600.00 is a fair price. Getting it cheaper is also nice, but having a machine of that quality level in your shop is priceless (up to $5000.00, that is
In the old Safari
If you're transporting only one
Back insides. Everything is adjustable
upper axle bracket assembly
Upper axle bracket, outside
Lower guide
Upper guide
