North Carolina Woodworker
Oh, Oh, Changes in Progress
Go Back   North Carolina Woodworker > Tools, Equipment, and Techniques > Power Tools and Their Use
Notices
» Announcements
The Woodworking Source Grand Opening
Saturday November 22
Featured Photos
by cmartinson
24399 photos
10034 comments
by Alan in Little Washington
24399 photos
10034 comments
by TracyP
24399 photos
10034 comments
by BiggE98
24399 photos
10034 comments
» Online Users: 59
24 members and 35 guests
ashley_phil , DaveO , Douglas Robinson , enm , erasmussen , FredP , Gofor , JackLeg , JRD , junquecol , Ken Massingale , Mike Davis , mjmlbp , Partman , Ralrick , rcflyer23 , redhawknc1 , rsitzejr , sapwood , Shayne , Sweetgum , toolman , TopKnot , WoodWrangler
Most users ever online was 180, 04-22-2008 at 12:18 AM.
Closed Thread
Old 12-08-2006, 09:34 AM   #1
This Space for rent
golfdad's Avatar
City: Clayton
State: NC
County: Johnston
Threads: 19
Avg Visit Freq/Week
= 1.57 over 125 days
Air Compressor?
Guys im trying to find some info on how big a compressor to buy I have a ancke style now and its to small Want to do some spray painting (low pressure) and use some small air tools. Thanks
Show Printable Version Email this Page   Quote this post in a PM to golfdad
Old 12-08-2006, 09:40 AM   #2
This Space for rent
chris99z71's Avatar
City: Garner
State: NC
County: Wake
Threads: 162
Avg Visit Freq/Week
= 2.63 over 125 days
Re: Air Compressor?
First step is to decide exactly what equipment you wish to use. Then look at the CFM requirements of that equipment and at what pressure. When you say low pressure, I'm assuming you're talking HVLP (something like this kit). This takes a pretty good sized compressor - 7-8CFM @ 40 PSI. Ignore horsepower ratings. When it comes to compressors, they're 100% meaningless.
Also, check out these two threads:
http://www.ncwoodworker.net/forums/s...ead.php?t=5696
http://www.ncwoodworker.net/forums/s...ead.php?t=5710
__________________
"If you can't learn to do something well, learn to enjoy doing it poorly."
----9-11-01----343----Never Forget----
Show Printable Version Email this Page   Quote this post in a PM to chris99z71
Old 12-09-2006, 12:32 AM   #3
This Space for rent
City: Wake Forest
State: NC
County: Wake
Threads: 129
Avg Visit Freq/Week
= 5.26 over 125 days
Re: Air Compressor?
Depending on how large a tank you are looking at and how much you are wanting to spend, take a look at dual stage versus single stage. That way, if you decide to use pneumatic tools like sanders, impact wrenches, drills, etc the compressor builds pressure back up much quicker.
Personal opinion is the bigger the tank the better and the higher amperage the motor the better. If you go 220 volt, go two stage.
Show Printable Version Email this Page   Quote this post in a PM to Travis Porter
Old 12-09-2006, 09:40 AM   #4
Advisory Panel
toolferone's Avatar
City: Raleigh
State: NC
County: Wake
Threads: 146
Avg Visit Freq/Week
= 6.89 over 125 days
Re: Air Compressor?
At the size you are thinking about they should all be oil-lube which is a must, also look at the duty cycle. You should get 100%.
__________________
Tom
www.dreamshopwoodworks.com
TWA
Triangle Woodworking Association Member
Membership chairperson.
Show Printable Version Email this Page   Quote this post in a PM to toolferone
Old 12-10-2006, 09:21 PM   #5
This Space for rent
Gofor's Avatar
City: Goldsboro
State: NC
County: Wayne
Threads: 47
Avg Visit Freq/Week
= 5.94 over 125 days
Re: Air Compressor?
Small may not mean low air requirements. An air Dual Action (DA) sander (Comparable to a Random Orbital Sander on the electrical side with the caveat that you ALWAYS start the air sander On the piece and stop it On the piece to prevent gouge and swirl marks) will consume up to 12 CFM at 100 psi. Not a big tool but uses a lot of air.
However, one air tool often overlooked by woodworkers is the air drill. Infinite variable speed control and plenty of power. Does not use a lot of air unless using it with a sanding disc, etc (i.e continuously). Things like air ratchets, impact guns, nail guns,etc, don't use a lot of air unless it is continuous for an extended period.
As already mentioned, 7 to 8 cfm @ 40 - 50 psi will be a minimum for spraying continuously, but in reality, 6.5 will work for most furniture work if it has a 20 gal+ tank. That will also be plenty for most intermittent use air tools. Sanders, grinders (except pencil grinders that are comparable to a dremel) and roto-peeners will take a larger compressor. An abrasive blaster can consume an enormous amount of air.
If noise is a concern, cast iron (full cast iron, not aluminum with a cast iron liner) is much quieter, but the trade-off is weight. Oil lube will last longer than oil-less - again, a weight trade-off.
For spraying, save enough when you buy the compressor for a good oil/water separator, preferably with a draincock at the bottom of the bowl for humid days. Use dedicated hoses downstream of the separator for painting to prevent oil contamination (fisheyes) in the finish. If using a lot of rotary air tools (and nail guns) an in-line oiler on a T-fitting opposite the oil/water separator will ensure the tools are lubed without the first spray of oil when you lube them by putting drops of oil in the tool inlet fitting.
Just my $.02 worth
__________________
My only regret in life is that I did not listen more and talk less
Show Printable Version Email this Page   Quote this post in a PM to Gofor
Old 12-12-2006, 10:25 AM   #6
This Space for rent
fivestring's Avatar
City: Mount Holly
State: NC
County: Gaston
Threads: 10
Avg Visit Freq/Week
= 0.17 over 125 days
Re: Air Compressor?
Harbor Freight Tools - Quality Tools at the Lowest Prices
3.5 cfm @ 90, 8.8 cfm @ 40
Works for everything I've used it for.
__________________
Bluegrass:THE original country music!
Show Printable Version Email this Page   Quote this post in a PM to fivestring
Closed Thread
air , compressor
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Similar Threads
Sizable air compressor $139 chris99z71 Found for Sale/Hot Deals 5 12-06-2006 11:33 AM
Split again - air compressor psi/cfm chris99z71 Finishing 14 11-16-2006 10:29 AM
Advice for Air Compressor for Shop Travis Power Tools and Their Use 8 08-02-2006 11:29 PM
COMPRESSOR, nailer Joe Scharle Member Announcements 5 07-19-2006 08:11 AM
Air Compressor info sapwood Power Tools and Their Use 15 03-14-2006 06:24 PM
» Log in
You last visited: at
Log Out
User Name:
Password:
Not a member yet?
Register Now!
Search Rockler.com's Extensive Woodworking Catalog
Search from over
9000 products!
Highland Woodworking Link
» Stats
Members: 2,063
Threads: 16,065
2nd Top Poster: jeff... (6,231)
Welcome to our newest member, Rustic Rambler
» Today's Birthdays
robertcody (52)
Powered by vBulletin® Version 3.7.0
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Content Copyright © 2005 - 2008 North Carolina Woodworker, Inc.
