» Upcoming Events | | Fall 2009 Raffle drawing this Friday (11/20): See This Thread For Details |  | |
01-21-2007, 03:19 PM
#1 | | 30 amp extension cords? Name: Pete Davio City: Hope Mills State: NC County: Cumberland Join Date: Dec 2005  01-21-2007, 03:19 PM
Moderator waiting for permission to wire my garage to power the new equipment may be a while. Can anyone tell me if this cord will work for my new 5 hp planer?? I understand i may have to change the ends, so I may not go for the glowing end type, but it is just about 25 feet from my dryer (in laundry room) to where my new planer and jointer will reside. It seems that this resolution would be cheaper than buying ends and wiring them together. Does anyone see anything wrong with this???
__________________ Failure is the opportunity to begin again more intelligently. – Henry Ford
However your life is, meet it and live it. Henry David Thoreau They that can give up essential liberty to obtain a little temporary safety, deserve neither liberty, nor safety. Benjamin Franklin
| | Views: 460 |
01-21-2007, 03:43 PM
#2 |
Name: Fred City: franklinton State: nc County: franklin Join Date: Jun 2006 Age: 52 Avg Visit Freq/Week = 6.84 over 180 days | Re: 30 amp extension cords? I'm no expert but it looks reasonable to me. if you will only be using it on the one tool why not cut the female end off the cord and wire it direct to the switch. instant cord with no breaks to come undone.  that is how i did my shaper. the cord that came with it was only 3 or 4 feet long.
fred |
01-21-2007, 03:54 PM
#3 | | Moderator
Name: Pete Davio City: Hope Mills State: NC County: Cumberland Join Date: Dec 2005 Avg Visit Freq/Week = 5.99 over 180 days | Re: 30 amp extension cords? I may actually be using it with my jointer, planer, and a bandsaw, too, if I can get them all on the same plug. If I am really feeling squirley, I may conver the tablesaw to 220 also, and use that one source for the short term.
01-21-2007, 04:53 PM
#4 |
Name: Fern HollowMan City: Franklinton State: NC County: Granville Join Date: Nov 2006 Age: 59 Avg Visit Freq/Week = 3.27 over 180 days | Re: 30 amp extension cords? AWG 10-3 is OK for 30 amps at 220v. However, check the owners manual for your 5HP plane. My PM66 is only 3HP and the manual called for a 30 amp breaker. IIRC, for the 5HP model, they called for AWG 8. |
01-21-2007, 05:07 PM
#5 | | Moderator
Name: Pete Davio City: Hope Mills State: NC County: Cumberland Join Date: Dec 2005 Avg Visit Freq/Week = 5.99 over 180 days | Re: 30 amp extension cords? Originally Posted by fernhollowman AWG 10-3 is OK for 30 amps at 220v. However, check the owners manual for your 5HP plane. My PM66 is only 3HP and the manual called for a 30 amp breaker. IIRC, for the 5HP model, they called for AWG 8.
good to think about...
01-21-2007, 06:18 PM
#6 |
Name: Fern HollowMan City: Franklinton State: NC County: Granville Join Date: Nov 2006 Age: 59 Avg Visit Freq/Week = 3.27 over 180 days | Re: 30 amp extension cords? I endured the freezing rain and went to the shop and check the manual. For the 5HP, it specs a 10GA feed but calls for a 40amp breaker instead of 30amp (which my 3HP uses). Probably something about start-up surges. You should be fine. Also, shop carefully for plugs and receptacles. The price of some of that 220V stuff will capture your attention rapidly. |
01-21-2007, 07:47 PM
#7 | | Executive Vice-President Libraries Administrator
Name: Rob City: Hendersonville State: NC County: Henderson Join Date: Nov 2005 Age: 67 Avg Visit Freq/Week = 6.88 over 180 days | Re: 30 amp extension cords? You can purchase 10 Ga. 3-wire cord (for a 3-prong dryer outlet) or 4-wire and appropriate receptacle and plugs at Lowe's. I'd recommend NEMA L6-30R / L6-30P twistlocks for the outer end that you connect to machines ("R" is for Receptacle = female; "P" is for Plug = Male end).
__________________
Rob Payne  Truths: There is no such thing as a 25 hour day, so why do I keep trying to cram so much into every day so it seems that way! |
01-21-2007, 11:52 PM
#8 |
Name: Bruce City: Apex State: NC County: Wake Join Date: Nov 2005 Avg Visit Freq/Week = 6.30 over 180 days | Re: 30 amp extension cords? Looks like you will be paying about $1.25 a foot for some SJO wire, as you will be cutting off ends. Is your dryer outlet a three or four prong outlet. Check HF and see if they have any heavy duty cords in stock. Also Northern tools would be a possible source. |
01-22-2007, 12:28 AM
#9 | | Moderator
Name: Pete Davio City: Hope Mills State: NC County: Cumberland Join Date: Dec 2005 Avg Visit Freq/Week = 5.99 over 180 days | Re: 30 amp extension cords? three prong, built before NEC required a ground, so I get to save some, I guess ?
01-22-2007, 08:37 AM
#10 |
Name: Chris City: Garner State: NC County: Wake Join Date: Oct 2005 Age: 33 Avg Visit Freq/Week = 0.27 over 180 days | Re: 30 amp extension cords? FWIW, I have my 5 hp unisaw (Labeled wired on a 220V, 30A circuit with #10 and I've yet to trip the breaker. YMMV
__________________ "If you can't learn to do something well, learn to enjoy doing it poorly."
----9-11-01----343----Never Forget----
01-22-2007, 08:39 AM
#11 |
Name: Michael City: APO State: AE County: ARMY Join Date: Dec 2005 Age: 32 Avg Visit Freq/Week = 4.82 over 180 days | Re: 30 amp extension cords? Pete,
I should slap you in the head,,I have a lot of left over wire and plugs from my shop wiring saga. I will round them up and you can take what you want.
__________________ "As iron sharpens iron, so one man sharpens another." (Proverbs 27:17) “Our doubts are traitors; they make us loose the good we oft might win by fearing to attempt” “If I had my life to live over again, I'd be a plumber.” Albert Einstein |
01-22-2007, 10:55 PM
#12 |
Name: Bruce City: Apex State: NC County: Wake Join Date: Nov 2005 Avg Visit Freq/Week = 6.30 over 180 days | Re: 30 amp extension cords? Originally Posted by NCPete three prong, built before NEC required a ground, so I get to save some, I guess ? I thinks you mean before the NEC required a neutral. They have always required a ground on a dryer. They allowed the ground to be used as a neutral if it was run in SE cable, but not romex. Romex had to be four wire, including a ground. Mobile homes were the first to require four wire. The frame of the home could become hot if the grounding conductor got broken. Standing outside,with wet shoes and reach up and touch the metal door handle could cause quite a bit of excitement. "Depends" would be the order of the day. |
01-22-2007, 11:37 PM
#13 | | Moderator
Name: Pete Davio City: Hope Mills State: NC County: Cumberland Join Date: Dec 2005 Avg Visit Freq/Week = 5.99 over 180 days | Re: 30 amp extension cords? yeah, that is what I meant
I should borrow that book, "how to wire your house yourself, without it burning down."
01-23-2007, 10:19 PM
#14 |
Name: Bruce City: Apex State: NC County: Wake Join Date: Nov 2005 Avg Visit Freq/Week = 6.30 over 180 days | Re: 30 amp extension cords? Was over at the Lowes in Garner today. They stock 10-3 and 10-4 SJO cable. It is the regular stuff that drop cords are made from. The 3 wire was $1.59 a foot and the 4 wire was $1.89 a foot. It is in the big wire rack. Cut you any length that you need. Maybe your wife needs to get you a copy of "Wiring For Dummies" for you. |
01-24-2007, 03:34 PM
#15 | | Treasurer
Name: Travis City: Wake Forest State: NC County: Wake Join Date: Dec 2005 Avg Visit Freq/Week = 6.53 over 180 days | Re: 30 amp extension cords? Copper has gone out of this world. I need to buy stock in anyone mining the stuff. |
| |  | | | Thread Tools | | | | Display Modes | Linear Mode |
Posting Rules
Members: 3,664
Threads: 25,110
Top Poster: DaveO (14,702) | | Welcome to our newest member, Jose San Vicente | |
