North Carolina Woodworker
Discounts on 2010 NCWW Calendar through Nov 30th!!
Javascript DHTML Drop Down Menu Powered by dhtml-menu-builder.com
Go Back   North Carolina Woodworker > Tools, Equipment, and Techniques > Hand Tools and their Use
» Upcoming Events
Fall 2009 Raffle drawing this Friday (11/20): See This Thread For Details
Closed Thread
Old 09-11-2009, 07:34 AM   #1
Card scrapers...... again.
froglips's Avatar
City: Hillsborough
State: NC
County: Orange
Threads: 430
Show Printable Version Email this Page   Quote this post in a PM to froglips
froglips froglips is offline 09-11-2009, 07:34 AM
Site Programmer
Ah, but this one is a little different!
This one is a video. BTW, has a great soundtrack and the fellow is quite witty. Stick around for the closing credits.
I've not heard of the "file edge only" method of scraper prep. Anyone use this or have any thoughts?
__________________
"Why is it that I loathe washing dishes, but I absolutely love sitting out here in the shop washing parts with kerosene?"
Roger Welsch, Busted Tractors and Rusty Knuckles
Old 09-11-2009, 09:31 AM   #2
CarvedTones's Avatar
City: Cary
State: NC
County: Wake
Threads: 189
Avg Visit Freq/Week
= 6.53 over 180 days
Re: Card scrapers...... again.
I read this article by Christopher Schwarz a while back:
http://www.popularwoodworking.com/ar...rpen_Scrapers/
I compiled a list of 14 different techniques for sharpening this rectangle of steel that have been published since 1875. All of the 14 techniques basically agree that there are three steps to sharpening a scraper: Filing the edge of the tool, removing the file marks with a sharpening stone and then creating the hook (sometimes called the burr) with a hardened rod of steel, usually called a burnisher.
My take is that the guy in the video is using the file as a burnisher. There has to be a hooked burr.
EDIT - I don't mean to imply that there is anything wrong with that. It looks like it is easy to get a consistent short burr that way.
__________________
-Andy
Wag more - bark less.
http://www.CarvedTones.com
Show Printable Version Email this Page   Quote this post in a PM to CarvedTones
Old 09-11-2009, 09:51 AM   #3
Mike Davis's Avatar
City: Westfield
State: NC
County: Stokes
Threads: 139
Avg Visit Freq/Week
= 7.00 over 180 days
I have done a lot of scraping the last two weeks. I now just use a flat diamond plate and burnisher. No file. I found that I was wasting time and material with the file.
My procedure:
Clamp card in vise
Flatten top and sides with 600 grit diamond plate
Burnish to make hook
Flip to do other side
I have been making 6 inch long curls over an inch wide and thin enough to see through.
Probably should mic one to see exactly how thick, but i haven't had time to mess around.
__________________
I meant to tell you, Mors Kochanski said "thats a spoon made by an expert" -BR-
Show Printable Version Email this Page   Quote this post in a PM to Mike Davis
Old 09-11-2009, 09:55 AM   #4
City: Dobson
State: NC
County: Surry
Threads: 51
Avg Visit Freq/Week
= 4.67 over 180 days
In my experience removing finish with a card scraper the burr tends to gum up with the finish making it hard to scrape. Having a small burr or no burr at all might be an advantage in this situation. I'll have to give it a try.
Rick Doby
Show Printable Version Email this Page   Quote this post in a PM to rbdoby
Old 09-11-2009, 10:13 AM   #5
Tarhead's Avatar
City: Concord
State: NC
County: Cabarrus
Threads: 217
Avg Visit Freq/Week
Is this not the same concept as the Stanley #12, 12 1/2, etc scrapers? They don't have a hook and you just use the 90 or 45 degree edge to do the work.
__________________
"It'll last a lifetime if you die when you're supposed to." Arval Woody, Spruce Pine, NC
Show Printable Version Email this Page   Quote this post in a PM to Tarhead
Old 09-11-2009, 10:35 AM   #6
woodguy1975's Avatar
City: Hickory
State: NC
County: Burke
Threads: 133
Avg Visit Freq/Week
= 4.39 over 180 days
I've found the best way to pull a burr on a scraper is to use a strip sander with the plate pulled back. If you get sparks you get a burr. I haven't burnished or used a diamond plate in years since I learned this method. I get the same quality of burr in less than 5 seconds.
I show all my chair guys this trick because it is the only good way to sharpen a gooseneck scraper.
Good Luck,
__________________
Keeping the Hokie Spirit Alive!! Remember 4/16/2007
First known case of the dreaded "Woodguy Disease" and is highly contagious. Stay away.... stay away! Warning! Not liable for excessive tool buying, drooling, or the sudden urge to spend large amounts of money.
www.jsrwoodworking.com
Show Printable Version Email this Page   Quote this post in a PM to woodguy1975
Old 09-11-2009, 11:34 AM   #7
Mike Davis's Avatar
City: Westfield
State: NC
County: Stokes
Threads: 139
Avg Visit Freq/Week
Can you explain that a little more John, I'm not following you there?
__________________
Old 09-11-2009, 06:14 PM   #8
City: Raleigh
State: NC
County: Wake
Threads: 1
Avg Visit Freq/Week
= 0.39 over 180 days
the wood whisperer does a nice little card scraper vid were he says to rip a dado into a block of hardwood just wide enough for your file and then stick it in. once you've done this you can use the hardwood edge as a guide and your scraper comes out perfectly square every time.
i use this little trick now and it works well. i keep the block and file with my scraper set to keep it handy when i need the card sharpened.
www.thewoodwhisperer.com then check out his videos.
Show Printable Version Email this Page   Quote this post in a PM to bench dog
Old 09-11-2009, 11:21 PM   #9
Gofor's Avatar
City: Goldsboro
State: NC
County: Wayne
Threads: 56
Avg Visit Freq/Week
= 4.59 over 180 days
I usually just use the file for glue scraping, but for leveling and finishing, a nice hook that shaves as Mike describes will last longer and do a nicer job. The squared file edge is all that is needed for scraping glue and finishes off, but for surfacing the wood, all it does is burnish it.
I use a Nichols 6" slim taper mill file (one with the parallel diagonal teeth, not the cross hatched) and stoke it lightly across the edge, eye-balling flat. A 10" will work, but produces a rougher surface. I hold the file at about a 30 degree angle to the card which gives a little better angle for the teeth to cut smoothly. If you are a degree or so off, it will not make much difference. This is fine for glue and coating.
For wood, I then hold it vertical on 1000 grit for about 5 pushes back and forth, and then roll the edge (two strokes flat drawing it toward the edge, and then three to four strokes for each side angling over for the hook) lubed with WD-40 or rub it alongside my nose or in back of my ear. Although it takes maybe a minute more to roll a hook, I will last a lot longer on raw wood and take less effort/stokes to get it flat/smooth.
I actually made one of the file holders mentioned above, and found that running the file straight in-line along the edge was more difficult, as the teeth are at a more perpendicular angle, and produced a rougher edge due to the chips causing their own gouges (the metal was torn more than shaved). I also found that getting anal about removing all the previous hook all the way to the corner was just added work for most applications. The center third is where all the work is getting done.
JMTCW
__________________
"The three hardest things to make in your shop are time, space, and money" - Buz Buskirk (quoted in Woodworking Magazine, Spring 2009)
Show Printable Version Email this Page   Quote this post in a PM to Gofor
Old 09-11-2009, 11:49 PM   #10
Name: Alan Schaffter
City: Washington
State: NC
County: Beaufort
Threads: 262
Avg Visit Freq/Week
= 6.69 over 180 days
I think there is flexibility in card scraper sharpening technique and it depends on the application. When I was cleaning some finish off the sides of my bench slab and also knocking down the aprons, I used a scraper often. To sharpen the scraper quickly, I held it in my left hand and grabbed half the file in the other and made a couple passes with the flat of the file along the card's edge. I would then run the file's tang along the scraper's edge to make the hook/burr. The tang which is really hard worked fine as a burnisher. It was quick and it worked.
Show Printable Version Email this Page   Quote this post in a PM to Alan in Little Washington
Old 09-12-2009, 05:54 AM   #11
Site Programmer
froglips's Avatar
City: Hillsborough
State: NC
County: Orange
Threads: 430
Avg Visit Freq/Week
Interesting. Seems that there are a bazillion methods when it comes to sharpening these things.
But, I think I get it. The "file only" sounds more like a coarse application, while burnishing (whole 9 yards) is better for surface prep and dare I say "fine" work or wild grain smoothing.
This is helpful to know, as I found it annoying to do so much work on a good hook to then strip paint.
Now I'm gonna go play some more of that Perez Prado Mambo No. 8 .
__________________
Old 10-03-2009, 12:31 AM   #12
02blues's Avatar
City: Chapel Hill
State: NC
County: Orange
Threads: 31
Avg Visit Freq/Week
= 1.24 over 180 days
Must learn to sharpen mine too. Must add I love this old stanely I recently found in an antique store in Wisconsin! Go Packers.
Using a veritas toothed bevel up jack plane and this scraper on the wild area of my mahogany bed posts, though this is the to be head board...
__________________
"As iron sharpens iron, so one man sharpens another"
Proverbs 27:17
Show Printable Version Email this Page   Quote this post in a PM to 02blues
Old 10-04-2009, 08:47 PM   #13
Gotcha6's Avatar
City: Ivan's Corner (Monroe)
State: NC
County: Union
Threads: 87
Avg Visit Freq/Week
Could you not do the same thing using a woodworker's wooden clamp?
__________________
WHAT BOX?
Show Printable Version Email this Page   Quote this post in a PM to Gotcha6
Closed Thread
card , scrapers
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Wood scrapers? Charlottend Hand Tools and their Use 15 07-18-2009 06:14 PM
If I bring my cabinet scrapers.... b4man Hand Tools and their Use 5 05-17-2008 09:10 PM
I love scrapers! Vanilla Gorilla General Woodworking 9 02-23-2008 09:46 PM
Care, feeding and use of Stanley 81 Scrapers Steve W Hand Tools and their Use 3 01-03-2008 10:39 PM
Order your 2010 Calendar!
Carolina Lumber Sourcing
» Stats
Members: 3,663
Threads: 25,103
Top Poster: DaveO (14,701)
Welcome to our newest member, Keith Senderak
» Today's Birthdays
Dick Barnes (74)
Powered by vBadvanced CMPS v3.2.0
Powered by vBulletin® Version 3.8.2
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.3.0
Template-Modifications by TMS
Content Copyright © 2005 - 2009 North Carolina Woodworker, Inc.
