North Carolina Woodworker
Discounts on 2010 NCWW Calendar through Nov 30th!!
Javascript DHTML Drop Down Menu Powered by dhtml-menu-builder.com
Go Back   North Carolina Woodworker > Woodworking > General Woodworking
» Upcoming Events
Fall 2009 Raffle drawing this Friday (11/20): See This Thread For Details
Closed Thread
Old 05-09-2006, 09:34 PM   #1
Unisaw upgrade underway w/*PICS*
Name: Alan Schaffter
City: Washington
State: NC
County: Beaufort
Threads: 263
Show Printable Version Email this Page   Quote this post in a PM to Alan in Little Washington
Alan in Little Washington Alan in Little Washington is offline 05-09-2006, 09:34 PM
In addition to working on the assembly table I started the rework of my Unisaw mobile base and tables. After removing the Unifence rail, the extension table, and stock mobile base, I fabricated wheels and feet for my new mobile base. Here is the saw stripped of its extension tables, fence rail, and mobile and original Delta mobile base:
Here is the saw showing the new cabinet wheels and leveler foot that have been attached directly to the cabinet subbase:
The wheel assembly is comprised of a Hartville Tool ball bearing wheel (great wheels at a great price) that has been removed from the stock mounting bracket and remounted in a 4" section of 2" X 4" rectangular steel tubing which is bolted to the saw sub-base with two bolts, one is the axle (same size as original axle). The steel tube protects the wheels and also supports the end of axle bolt. I have used this type of mobile base (along with a Delta style step caster from Rockler) on all my other tools also.
Here is the Hartville Tool wheel and the unpainted rectangular steel tube.
The leveling foot is made from a short section of 2" X 2" steel angle also bolted to the sub-base. I used a tap to thread the bracket for the leveler bolt.
I used hardware store elevator bolt for the leveler and used a plastic caster cup to keep the steel from sitting directly on the floor and possibly making rust rings. The plastic cup is held in place with some double stick tape.
Next up- fabricate the extension table steel rails, legs, and add a step caster. Then make a new extension table and remount the aluminum fence rail. And finally, build an outfeed table (never had one)- Link.
Old 05-09-2006, 10:03 PM   #2
mshel's Avatar
City: Wilson
State: NC
County: Wilson
Threads: 164
Avg Visit Freq/Week
= 6.77 over 180 days
Re: Unisaw upgrade underway w/*PICS*
Alan,
Nice and stout. You mentioned a step castor, I assume this is for lifting the front of the saw base. My Yorkcraft planer has one on the front and it works great. Where did you get the elevator bolts? I have a drum / flap sander and want to put some levelers on it so it doesn't creep when I use it. How long can you get those bolts?
__________________
Whatever the mind can conceive and believe, the mind can achieve.
~ Dr. Napoleon Hill
http://carolina-heirlooms.ncwoodworker.net/
Show Printable Version Email this Page   Quote this post in a PM to mshel
Old 05-09-2006, 11:57 PM   #3
City: Washington
State: NC
County: Beaufort
Threads: 263
Avg Visit Freq/Week
= 6.69 over 180 days
Originally Posted by mshel
Alan,
The step caster will actually lift the right side of the saw base, like the Delta mobile base. Unlike the Delta, however, which has the step caster midway between the saw base and the right side of the extension table (making this space unusable for a rolling cabinet), I am going to mount the step caster to new, reinforced, extension table legs at the right end. The legs will be attached to heavy duty table rails.
I got the "elevator bolts" at Lowes, in the nuts and bolts cabinets. They come in various sizes but the ones I bought had 2" X 3/8"- 16 bolt and a 1 1/4" round bottom.
Old 05-10-2006, 12:15 PM   #4
wapitiscat's Avatar
Name: Todd Earnhardt
City: Raleigh
State: NC
County: Wake
Threads: 12
Avg Visit Freq/Week
= 0.04 over 180 days
Looks great! How much of the wheel protrudes from the housing?
Todd
Show Printable Version Email this Page   Quote this post in a PM to wapitiscat
Old 05-10-2006, 12:58 PM   #5
City: Washington
State: NC
County: Beaufort
Threads: 263
Avg Visit Freq/Week
Todd
I mounted the wheel so it would extend down below the housing and the subbase by 1/2"- it could have been less. On my DJ-20 I mounted the wheel so it would extend down 3/4"- I needed to elevate the base a little for operation of the step caster which was also mounted under the edge of the subbase. I am using 3" wheels. Depending on whether you use a 3" or 4" wheel you can have it extend just a smidge or as much as 2 1/2 - 3 1/2"- on the Delta, the subbase turns under creating a lip on the inside - you need to leave room for a washer and nut.
Old 09-26-2007, 01:26 PM   #6
KC7CN's Avatar
City: Yakima
State: WA
County: Yakima
Threads: 38
Avg Visit Freq/Week
= 4.59 over 180 days
Looks good Alan! I like the modified caster too! Good solution for a low-profile stand.
-Don
Show Printable Version Email this Page   Quote this post in a PM to KC7CN
Closed Thread
underway , unisaw , upgrade , w or pics
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dust collector pipe upgrade Travis Porter Power Tools and Their Use 7 03-24-2006 09:12 AM
Delta Bandsaw upgrade Travis Porter Power Tools and Their Use 22 01-22-2006 09:28 PM
Order your 2010 Calendar!
Carolina Lumber Sourcing
» Stats
Members: 3,663
Threads: 25,105
Top Poster: DaveO (14,701)
Welcome to our newest member, Keith Senderak
» Today's Birthdays
Dick Barnes (74)
Powered by vBadvanced CMPS v3.2.0
Powered by vBulletin® Version 3.8.2
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.3.0
Template-Modifications by TMS
Content Copyright © 2005 - 2009 North Carolina Woodworker, Inc.
