North Carolina Woodworker
Changes to DQ as of 12/1/2008 Very important that you read
Go Back   North Carolina Woodworker > Woodworking > General Woodworking
Notices
» Announcements
Everyone Log on at 9:00PM Thursday December 4th to set a members online record.
Featured Photos
by walnutjerry
446 photos
5 comments
by TracyP
24861 photos
9957 comments
by Touchwood
24861 photos
9957 comments
by cranbrook2
24861 photos
9957 comments
» Online Users: 69
18 members and 51 guests
Bas , ChrisMathes , clowman , davejones , Douglas Robinson , enm , FredP , GeorgeL , JackLeg , Kyle , Larry Rose , manirban73 , Mike Davis , NCTurner , Sandy Rose , tmerrill , TopKnot , woodArtz
Most users ever online was 180, 04-22-2008 at 12:18 AM.
Closed Thread
Old 04-26-2007, 11:59 PM   #1
pslamp32's Avatar
City: Asheville
State: NC
County: Buncombe
Threads: 74
Avg Visit Freq/Week
= 0.23 over 30 days
Question
First, how do you guys mount inset drawer faces. I've got the drawer boxes mounted on sliders in my sideboard and just want to know the easiest way to accurately mount the hardwood faces.
Second, I screwed up my table top a bit. I was using a power hand sander with a low grit to level things up a bit and now I can't seem to get the sandpaper marks out of the table. Do I use fine grit by hand, medium grit with ROS ? Help! Thanks.
__________________
'More than any other time in history, mankind faces a crossroads. One path leads to despair and utter hopelessness. The other to total extinction.Let us pray we have the wisdom to choose correctly.' -Woody Allen
Show Printable Version Email this Page   Quote this post in a PM to pslamp32
Old 04-27-2007, 12:11 AM   #2
NCPete's Avatar
City: Hope Mills
State: NC
County: Cumberland
Threads: 206
Avg Visit Freq/Week
= 7.00 over 30 days
those sander marks are now 'an intended design feature'. Those arent sander marks, those are 'distressing'. (I know, distressing in more than one way)
drawers - double sided tape! That will hold em in place until you get them where you want, and then drive the screws. of course, they will invariably move while driving the screws.... so maybe someone else with some actually measurable level of competence will chime in.
__________________
Failure is the opportunity to begin again more intelligently. – Henry Ford
However your life is, meet it and live it.
Henry David Thoreau
They that can give up essential liberty to obtain a little temporary safety, deserve neither liberty, nor safety. Benjamin Franklin
Show Printable Version Email this Page   Quote this post in a PM to NCPete
Old 04-27-2007, 12:34 AM   #3
pslamp32's Avatar
City: Asheville
State: NC
County: Buncombe
Threads: 74
Avg Visit Freq/Week
= 0.23 over 30 days
Totally! That's why I asked. LOL.
__________________
Old 04-27-2007, 12:34 AM   #4
Webmaster
Director
DaveO's Avatar
City: Clayton
State: NC
County: Johnston
Threads: 568
Avg Visit Freq/Week
= 7.00 over 30 days
Peter, the best way I have found to mount inset drawer fronts is to use some double stick tape. I like to use dimes or 1/16-1/32th" pieces of wood as spacer to center the front in the opening and then stick the drawer box to the back of the front with the DST. It helps to have access to the drawer boxes from the top or back. The DST should hold it in place as you remove the drawer and bore for the screws.\
Throw a clamp or two on it to make sure it doesn't move as you drill the pilot holes
For the sanding issue, the only thing that will remove the sanding marks caused by a low grit paper is the next grit up, and on and on. Use it with your ROS, and then sand with the grain afterward by hand. Make sure that you clean off the surface between each grit change to remove any stray particles that may have come off the sandpaper and will continue to scratch the surface.
Dave
__________________
Nothing left to do but smile, smile, smile
--Dr. Seuss
Show Printable Version Email this Page   Quote this post in a PM to DaveO
Old 04-27-2007, 12:35 AM   #5
pslamp32's Avatar
City: Asheville
State: NC
County: Buncombe
Threads: 74
Avg Visit Freq/Week
= 0.23 over 30 days
Crap, that's what I was afraid of.
__________________
Old 04-27-2007, 12:37 AM   #6
pslamp32's Avatar
City: Asheville
State: NC
County: Buncombe
Threads: 74
Avg Visit Freq/Week
= 0.23 over 30 days
Dave
Thanks Dave, I'll try this.
__________________
Old 04-27-2007, 01:21 AM   #7
Vice-President
Libraries Administrator
McRabbet's Avatar
City: Hendersonville
State: NC
County: Henderson
Threads: 117
Avg Visit Freq/Week
= 7.00 over 30 days
Peter,
What grit did you use to cause the sander marks? After I've planed wood, I usually start sanding at 120 grit with my ROS hooked to my ShopVac. If I'm dealing with a sawn edge that shows saw blade marks, I try to pass the edge in line with the grain on my 6x48 stationary belt sander with 120 grit. I wipe off the residual dust with a clean rag and then a tack cloth and progress thru 150 and 180 up to 220 grit. Then I'll apply my sealer coat and re-sand at 220.
__________________
Truths: There is no such thing as a 25 hour day, so why do I keep trying to cram so much into every day so it seems that way!
Show Printable Version Email this Page   Quote this post in a PM to McRabbet
Old 04-27-2007, 11:27 AM   #8
Nativespec's Avatar
City: Raleigh
State: NC
County: Wake
Threads: 74
Avg Visit Freq/Week
= 2.33 over 30 days
You can also use a cabinet scraper-this will help with the leveling. You may also want to use a smoothing planer first. I am building a dresser with flush fitting drawers and have been using planers, scrapers and sanding to plane out my drawer fronts. Before I apply finish, I wipe down the wood with thinner and use a mechanics light at a low angel to reveal sanding marks. I usually finish my sanding, prior to the clear poly coats, with 320 grit on a PC finishing sander.
Show Printable Version Email this Page   Quote this post in a PM to Nativespec
Old 04-27-2007, 11:38 AM   #9
DavidF's Avatar
City: Pittsboro
State: NC
County: Chatham
Threads: 157
Avg Visit Freq/Week
= 3.73 over 30 days
http://www.rockler.com/product.cfm?p...&filter=drawer
The large dia is eccentric to the screw hole so you can tweak the fit before finally doing up the screw tightly.
__________________
"There is no trouble so great or grave that cannot be much diminished by a nice cup of tea" Bernard-Paul Heroux
Show Printable Version Email this Page   Quote this post in a PM to DavidF
Old 04-27-2007, 01:29 PM   #10
Littlejon's Avatar
City: Reidsville
State: NC
County: Rockingham
Threads: 11
Avg Visit Freq/Week
= 2.57 over 30 days
Nativespec beat me to it. I was going to suggest a scraper as well. Will put a nice smooth surface on your top.
Show Printable Version Email this Page   Quote this post in a PM to Littlejon
Old 04-27-2007, 04:29 PM   #11
pslamp32's Avatar
City: Asheville
State: NC
County: Buncombe
Threads: 74
Avg Visit Freq/Week
= 0.23 over 30 days
Looks like exactly what I was looking for. Thanks!
__________________
Old 04-30-2007, 01:18 PM   #12
photog's Avatar
City: North Highlands
State: CA
County: Sacramento
Threads: 6
Avg Visit Freq/Week
= 0.00 over 30 days
As for the inset drawer faces, I use some specialty screws specific to the purpose. They have a good size washer built into the head that conceals a larger than screw shank diameter hole in the false front of the drawer box. This slop allows for fine-tuning the drawer front to get consistent gaps on all sides of the face frame opening.
I’ve tried using double sided tape for the temporary positioning but didn’t like how it only gave you one shot at pressing the board into place in the exact position. Now I pre-drill the before mentioned holes in the drawer box and use small wedges between the face frame and drawer front to get exact position. I then reach around the face frame rail and quick clamp the drawer front on. A center punch or scribe is then inserted through the hole to mark the pilot hole-drilling dimple in the back of the drawer front. Once the two are screwed together lightly, you again have adjustability before tightening the screws home.
__________________
photog
Show Printable Version Email this Page   Quote this post in a PM to photog
Old 04-30-2007, 07:58 PM   #13
dtomasch's Avatar
City: Candler
State: NC
County: Buncombe
Threads: 31
Avg Visit Freq/Week
= 3.03 over 30 days
For your scratch patterns I will definately recommend a card/cabinet scraper. I have grown to love this simple tool for figured wood and table tops. Good luck!
Show Printable Version Email this Page   Quote this post in a PM to dtomasch
Old 05-01-2007, 12:01 AM   #14
Name: Alan Schaffter
City: Washington
State: NC
County: Beaufort
Threads: 202
Avg Visit Freq/Week
= 7.00 over 30 days
Sanding- Go back and start over with a grit one grade finer than the coarsest grit used. Sand until the scratches are only from that grit being used. Then use increasingly finer grits, sanding with each until the scratches are only from the grit you are using.
Attaching false drawer fronts- similar to Photog's method- I drill holes for the pulls in the false fronts the exact size of the pull machine screws. I temporarily shim or just hold the false front in place and insert the drill bit through the holes in the false front and drill the drawer box front. Then I enlarge the the drawer box holes about 1 1/2 X or 2X - this allows the false front to move slightly. I install the false fronts using the pulls and screws and tighten them until just snug. Then I tap on the sides and top/bottom edges of the false front until it is perfectly centered in the opening- sometimes I'll put some weight in the drawer during this process. I either install additional wood screws or brads from inside the box to lock the false front to the box. Works better for me than double-sided tape. With this method you can wait until the cabinet is finished and installed to attach and align the drawer fronts.
Show Printable Version Email this Page   Quote this post in a PM to Alan in Little Washington
Closed Thread
questions
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Similar Threads
Gun Cabinet Questions cpowell General Woodworking 12 01-05-2007 09:23 AM
Scrollsaw questions TominZebulon Scrollsaw Work 4 11-12-2006 07:08 AM
Questions about how to buy wood Canuck General Woodworking 22 03-09-2006 10:55 PM
A few questions ???? DaveO Power Tools and Their Use 19 01-25-2006 12:20 AM
» Log in
User Name:
Password:
Not a member yet?
Register Now!
Search Rockler.com's Extensive Woodworking Catalog
Search from over
9000 products!
Highland Woodworking Link
» Stats
Members: 2,135
Threads: 16,380
2nd Top Poster: jeff... (6,357)
Welcome to our newest member, rsellers
» Today's Birthdays
Red Sonja (39)
Powered by vBulletin® Version 3.7.0
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Content Copyright © 2005 - 2008 North Carolina Woodworker, Inc.
