North Carolina Woodworker
Discounts on 2010 NCWW Calendar through Nov 30th!!
Javascript DHTML Drop Down Menu Powered by dhtml-menu-builder.com
Go Back   North Carolina Woodworker > Woodworking > General Woodworking
» Upcoming Events
Fall 2009 Raffle drawing this Friday (11/20): See This Thread For Details
Reply
Old 10-19-2009, 10:58 AM   #1
Suggestions and Ideas Appreciated
Mt. Gomer's Avatar
City: Durham
State: NC
County: Durham
Threads: 7
Show Printable Version Email this Page   Quote this post in a PM to Mt. Gomer
Mt. Gomer Mt. Gomer is offline 10-19-2009, 10:58 AM
I wasn't sure where to put this as it's probably not technically a woodworking question but it's certainly the type of thing we all deal with in our homes (and fix in our shops).
I have a love/hate relationship with one of the "features" in my house: The built-in gas fireplace w/electronics cubby above. Here's a picture.
I hate it because: 1) Does anyone REALLY like gas fire place inserts? 2) Who puts expensive electronics OVER a fire? 3) It's fairly cheesy looking
I love it because: 1) Just flip the switch? Sweet! 2) Ice Storm, no power, no heat? No problem! 3) It's a family room not a formal reception area, with two little kids running around functionality trumps aesthetics, I can pretty it up later. 4) It is a space saver. Since the fireplace and TV extend outside the house I get a few extra feet of usable room width.
So, the challenge of the day is to deal with issue #2, cooking electronics. The problem isn't actually as big as I thought at first. The heat doesn't rise directly out of the firebox. The build meets all of the safety guidelines in the fireplace manual and the floor of the cubby stays quite cool. The problem is that the heat from the fireplace goes up the front face then hits the first shelf and goes into the lower compartments. The equipment there and the bottom of the first shelf can get quite warm. The TV area doesn't seem to be a problem. I can push the TV back a few inches so the heat rises past it and it is a large enough space that it dissipates.
So far I've come up with three options. 1) Buy a larger, metal hood to go above the fireplace which would (hopefully) direct the heat out away from the cubby (basically a larger, uglier version of the gold deflector in the picture) 2) Build some sort of shield (perhaps temporary, something you slide in when you light the fire, or something more permanent in the form of a small mantel or shelf) 3) Prevent the heat from entering the lower compartments by adding a door.
I'm open to brainstorming on all three (or others if you have ideas) but I've lately been spending most brain cycles on #3. I was thinking that a sheet of transparent material (lexan, plexi, glass) that is cut to fit cover the lower compartments (there is a small recess, about 1/4 of an inch, that it could fit into) and hinged for access might be the cleanest solution for the near future. It would allow the heat to travel right on past and shouldn't heat up much itself as it would be a recessed vertical plane. The one additional caveat about this material would be that it would need to not interfere with remote controls....
Anyway, the topic is now open for discussion! All thoughts, ideas, and comments welcome. Much thanks in advance.
Old 10-19-2009, 11:17 AM   #2
Ozzie-x's Avatar
City: Clyde
State: NC
County: Haywood
Threads: 18
Avg Visit Freq/Week
= 6.65 over 180 days
Re: Suggestions and Ideas Appreciated
I would try the plexiglas first, seems cheap, quick and easy. I don't see why it wouldn't work. What temperature of heat would the plexiglas be exposed to? May want to look at the ambient temperature characteristics/melting point of lexan vs plexiglas vs the actual temperature above the fire place. May not be a concern, just thinking out loud..... Glass would be a PIA and more of a challenge to mount, not to mention safety, but would sustain under higher temps.
__________________
Rust Never Sleeps
Show Printable Version Email this Page   Quote this post in a PM to Ozzie-x     Reply With Quote
Old 10-19-2009, 11:25 AM   #3
Development Director
Tar Heel's Avatar
City: Chapel Hill
State: NC
County: Orange
Threads: 187
Avg Visit Freq/Week
= 6.84 over 180 days
You might consider installing a very small fan behind the electronics. Back in my ham radio days they were called muffin fans.
Show Printable Version Email this Page   Quote this post in a PM to Tar Heel     Reply With Quote
Old 10-19-2009, 11:31 AM   #4
MrAudio815's Avatar
City: Goldsboro
State: NC
County: Wayne
Threads: 77
Avg Visit Freq/Week
= 3.38 over 180 days
I am thinking a little differnetly,
How about a small fan behind your electronics that will blow air past your electronics and blow the rising heated air from your fireplace hopefully far enough away from all your electronics?
To me that would seem to be the easiest fix and would keep your electronics cool in the summer time when you don't need the fireplace.
Ahhh You beat me to it Stuart...Great minds think alike~!
__________________
-----Matthew-----
Custom Home Audio
If you want to veiw paradise simply look around and veiw it!
Show Printable Version Email this Page   Quote this post in a PM to MrAudio815     Reply With Quote
Old 10-19-2009, 11:43 AM   #5
timf67's Avatar
City: Charlotte
State: NC
County: Mecklenburg
Threads: 55
Avg Visit Freq/Week
= 5.79 over 180 days
At first I too thought of the fan behind the electronics, but all it will do is circulate the hot air from the fireplace if there is no source of cooler air to pull from. I would also be worried about the plexiglass/lexan doors trapping heat in. Do you have a ceiling fan in the room? If so, you can circulate the air in the room to help even out the temperature. Just a thought, though some folks might find it odd to be running a ceiling fan and fireplace at the same time...
__________________
_________________________________________________
- Tim
A busy man is a happy man.
- Herb Tuttle
Show Printable Version Email this Page   Quote this post in a PM to timf67     Reply With Quote
Old 10-19-2009, 12:04 PM   #6
Mt. Gomer's Avatar
City: Durham
State: NC
County: Durham
Threads: 7
Avg Visit Freq/Week
= 1.36 over 180 days
I've actually tried the ceiling fan. I reverse the blades so (theoretically) there is a downdraft along the wall. It does help a little, we can leave the fire running a bit longer before I get worried about heat, but it's certainly not a fix.
I thought about a fan too but I think, except for when the fire is on, it would be overkill as we don't have anything too fancy and there is a lot of air volume so heat usually dissipates pretty well. I don't think the doors would be too much of an issue trapping in heat (caused by the electronics) for this reason. There are also quite a few holes in the TV shelf which allows for some air movement.
Show Printable Version Email this Page   Quote this post in a PM to Mt. Gomer     Reply With Quote
Old 10-19-2009, 12:10 PM   #7
skysharks's Avatar
Name: John Macmaster
City: Eastover
State: NC
County: Cumberland
Threads: 83
Avg Visit Freq/Week
= 6.61 over 180 days
I too, would suggest a fan installed behind the electronics blowing forward. In addition I also agree that having the ceiling fan on, even on low would really aid.
I use my gas logs quite a bit. In using them I always have the ceiling fans on in the house on low to aid in circulating this warm air out of and into other rooms.
Clear doors on the lower areas would be an option, but in doing so, I would wonder about heat buildup from the electronics them selves. I know that they do need air circulation as they themselves generate heat. If the area was not air-tight and could allow a bit of air to move, mmmmmm.
I did install a brass deflector on the top of mine as the mantale was getting hot. Prior to installing the deflector if there were candles (x-mas decorations), they would de-shape from the heat. Now no problems the mantle stays cool-warm and the paint on the mantle doesn't change color over time from the heat.
__________________
Long ago when men cursed and beat the ground with sticks, it was called witchcraft. Today it's called golf.
Show Printable Version Email this Page   Quote this post in a PM to skysharks     Reply With Quote
Old 10-19-2009, 12:19 PM   #8
algustaf's Avatar
City: Durham
State: NC
County: Durham
Threads: 7
Avg Visit Freq/Week
= 5.64 over 113 days
Rip off the basic 445 casing that surrounds the whole TV/electronics unit. Then build a small mantle/shelf extension about 6"-9" from the lower shelf unit. Build up some decent looking legs from floor up to the mantle for visual stability, then re-trim the TV/electronics area with either the same basic casing or duplicate the legs from floor at about 50% scale going up towards ceiling and trim out with some sort of ornamental header type thing.
The legs from floor should sit upon the granite and the mantle should protrude an inch at least from the width of the legs, depending on how you would trim out the mantle with some sort of profile. Check out the catalog of profiles available through Moulding and Millwork, these should be available at a builders supply (like Talbert's in Durham) and are pretty standard profiles to work with. It is all paint grade, so good quality finger joint 1X material would work well (not that knotty stuff they call finger joint and sell at the big box stores), you can get it in 16' lengths upto 16" wide. It is pretty stable if painted.
Well at least that's what I would do (or think about doing)
__________________
Fare thee well now
Let your life proceed by its own design
Show Printable Version Email this Page   Quote this post in a PM to algustaf     Reply With Quote
Old 10-19-2009, 12:32 PM   #9
Mike Davis's Avatar
City: Westfield
State: NC
County: Stokes
Threads: 139
Avg Visit Freq/Week
= 7.00 over 180 days
I always try to work from a point of informed planning.
Thinking the electronics may get hot is just assumption.
Get a couple thermometers or a small electronic recording thermometer to place on the shelf near the electronic equipment. If you record temperatures above 100°F then you need to take action to reduce the temperatures.
A fan may work, a deflector or shield of some sort may be needed or just move the equipment to another location and put something less sensitive on that shelf.
But, until you know if there really is a problem you can't know what (if anything) should be done.
__________________
I meant to tell you, Mors Kochanski said "thats a spoon made by an expert" -BR-
Show Printable Version Email this Page   Quote this post in a PM to Mike Davis     Reply With Quote
Old 10-19-2009, 12:37 PM   #10
Mt. Gomer's Avatar
City: Durham
State: NC
County: Durham
Threads: 7
Avg Visit Freq/Week
Originally Posted by Mike Davis View Post
Get a couple thermometers or a small electronic recording thermometer to place on the shelf near the electronic equipment. If you record temperatures above 100°F then you need to take action to reduce the temperatures. .
Where do you find such a device that is both functional and affordable?
Thanks!
Old 10-19-2009, 12:53 PM   #11
Mike Davis's Avatar
City: Westfield
State: NC
County: Stokes
Threads: 139
Avg Visit Freq/Week
I have a LaCross indoor/outdoor thermometer that records the high and low temp and I think it was around thirty dollars. Do an online search for recording thermometer or various related words.
Here's one for $22
http://www.testequipmentdepot.com/ge...3054?ref=gbase
__________________
Old 10-19-2009, 05:11 PM   #12
Mt. Gomer's Avatar
City: Durham
State: NC
County: Durham
Threads: 7
Avg Visit Freq/Week
When in doubt, google. Why didn't I think of that!?
Thanks!
Old 10-19-2009, 10:43 PM   #13
City: Durham
State: NC
County: Durham
Threads: 11
Avg Visit Freq/Week
= 6.18 over 180 days
If and when you find that the electronics are getting too warm, you could install a false back in the area where the electronics are if space permits and put a muffin fan behind there with a grill. Then see if you can get air into that area from somewhere else that is not as hot, maybe from the side or all the way to the ceiling. Another room would be ideal but that might be sorta hard with the location of the electronics. Aluminum dryer vent hose would work if you could find a way to get it there and be hidden.
__________________
Be Careful what you ask for, because you might get it.
Show Printable Version Email this Page   Quote this post in a PM to Dudelive     Reply With Quote
Old 10-19-2009, 11:18 PM   #14
City: Randleman
State: NC
County: Randolph
Threads: 5
Avg Visit Freq/Week
= 6.69 over 45 days
^ what he said. Blowing the hot air out from behind the electronics just pushes it through them again. It should be sucked out and new cooler air flowing in. That is the design with most in wall equipment racks.
Althought a fan behind would probably get the job done. Also a flat screen and moving the electronics up a shelf is another idea.
Show Printable Version Email this Page   Quote this post in a PM to rahimlee54     Reply With Quote
Old 10-20-2009, 09:49 AM   #15
Mt. Gomer's Avatar
City: Durham
State: NC
County: Durham
Threads: 7
Avg Visit Freq/Week
Thanks for the great suggestions everyone. It looks like more research and planning is required.
Al - I'm right there with you but before I go that far I need to plan out the rest of the room. Wife wants new book cases, end tables, and a coffee table, eventually. The kids are still in the "see what happens throw hard objects accross the room, write on things with permanent markers, and dig a fork into the kitchen table stage" (you know, the scientific method stage) so I think it's going to be a few years before I do too many serious upgrades in this room.
The fan idea might work but I'd have to do some experimentation. The only other place to get "cool" air into the back of the cabinent would be outside. That entire recessed area is ouside the house (where an chimney would normally be). The only electronics in the lower compartments are a Tivo and a DVD player, neither of which generate too much heat on their own so I think my primary concernt is keeping heat from the fireplace out, not getting heat from the equipment out.
Mike - I'll be ordering a recording thermometer. Even though I'm reasonably certain I've got a problem that needs to be solved (when the fire is on it gets quite hot in there) it will be good to know exactly what I'm dealing with and how much my various experiments help.
In the meantime I think I'll throw together a temporary shield we can put up when we use the fire.
Thanks again.
Reply
appreciated , ideas , suggestions
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Design ideas, anyone? dpsnyder General Woodworking 8 01-13-2009 12:50 PM
Any ideas... PChristy Finishing 3 10-19-2008 02:33 PM
Need some ideas 02ranger General Woodworking 12 05-19-2008 08:27 PM
Gift Ideas ... WoodWrangler General Woodworking 4 09-13-2006 09:31 AM
Ideas Arcrist General Woodworking 9 03-29-2006 08:23 PM
Order your 2010 Calendar!
Carolina Lumber Sourcing
» Stats
Members: 3,667
Threads: 25,111
Top Poster: DaveO (14,702)
Welcome to our newest member, Brockmania
» Today's Birthdays
Dick Barnes (74)
Powered by vBadvanced CMPS v3.2.0
Powered by vBulletin® Version 3.8.2
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.3.0
Template-Modifications by TMS
Content Copyright © 2005 - 2009 North Carolina Woodworker, Inc.
