North Carolina Woodworker
Discounts on 2010 NCWW Calendar through Nov 30th!!
Javascript DHTML Drop Down Menu Powered by dhtml-menu-builder.com
Go Back   North Carolina Woodworker > Woodworking > General Woodworking
» Upcoming Events
Fall 2009 Raffle drawing this Friday (11/20): See This Thread For Details
Closed Thread
Old 07-29-2009, 07:21 PM   #1
Sniper Sled
Bas's Avatar
City: Raleigh
State: NC
County: Wake
Threads: 211
Show Printable Version Email this Page   Quote this post in a PM to Bas
Bas Bas is offline 07-29-2009, 07:21 PM
Senior Administrator
A couple of people asked me about this jig during my shop move, so I figured I'd do a quick writeup. Can't do any woodworking for a while anyway.
My lunchbox planer snipes. It’s very slight, and usually I can just sand it out. Or, if I have enough material, I’ll just cut my stock long and then simply trim the sniped end. But when I’m making something like an end-grain cutting board, snipe is an absolute no-no. To compensate for the snipe, I created a sled that provides a leading edge for the board. The edge consists of a piece of plywood with a thin sacrificial strip of hardwood that will be planed along with the work piece. This means the edge receives the snipe instead. Most people know about this technique, but I've never seen a jig that makes this easy to set up.
The sled is made out of ¾” melamine, 12” x 36”. Plywood would also be a good choice. The width should match your planer. You can make the sled any length, but 36” can handle reasonably large pieces without becoming unwieldy.
First, route ¼” holes along both sides, 1” in from the edge and 1” apart. Each hole should be ½” deep. These holes will receive the "stops".
Next, create “stops’ using ½”, ¾’ and 1 ½” plywood (the latter is made simply by laminating two pieces of ¾” plywood). Each stop should be 3” wide and about ½” narrower than the sled, in this case 11 ½”. Drill two ¼” holes into each stop, ½” deep. Glue ¼” x 1” dowels into these holes. The distance between the dowels should match the distance between the routed holes in the sled. Use dowel points to ensure the stops fit snugly in the sled.
Note: For the ½” stops, you will have to trim the dowels since the ½” plywood is only 15/32” thick.
If your planer only snipes at the beginning or the end, you only need one stop for each thickness. If you have both snipe at the beginning and end, you’ll need two stops (as shown in the last picture).
When planing a board, determine the right stop to use. If the final thickness is to be ¾”, use the ¾” plywood stop (which is actually 23/32” thick). Next, use hot melt glue to attach two thin strips of hardwood to the stop. The combined height of the stop and strip should be about 1/16” over ¾”. Secure the board with a couple of drops of hot melt glue as well. Double sided tape can also be used. (In the picture, I put a bit of oil on the strips to make them easier to distinguish).
Now run the sled with the board through the planer. The stop with the sacrificial strips of hardwood will engage the rollers before the work piece, and receive the snipe instead. If your planer has trailing snipe as well, attach the second stop at the end of the board. Note that this does reduce the capacity of the sled by another 3”.
Once the board is planed, you can easily pop off the strips and replace them with new ones. My shop never seems to have a shortage of thin strips of hardwood, there’s always a leftover piece that’s useless for anything else.
Tips:
-To make it easier to remove the strips, seal the stops with polyurethane or apply some clear packing tape. Wax is not a good idea since it will interfere with the hot melt glue.
-With some extra holes in the stops, you can make them stackable if you offset the dowel holes. This allows you to stack the ½” stop on top of the ¾” stop, in case you need to plane a board down to 1 ¼”.
-This sled doubles as a simple planing sled when a board is too wide to face joint in the jointer.
__________________
Bas.
I don't need it. I just want it.
Old 07-29-2009, 07:27 PM   #2
Dragon's Avatar
City: Lincolnton
State: NC
County: Lincoln
Threads: 61
Avg Visit Freq/Week
= 3.77 over 180 days
Re: Sniper Sled
Neato, nifty, peachy-keen! I like that set up. I'm still mulling over ideas and mental planning for my router sled/planer device. Thanks for posting this.
Show Printable Version Email this Page   Quote this post in a PM to Dragon
Old 07-29-2009, 09:26 PM   #3
Senior Moderator
Events Director
ScottM's Avatar
City: Cary
State: NC
County: Wake
Threads: 257
Avg Visit Freq/Week
= 6.49 over 180 days
Re: Sniper Sled
So when you making me one?
__________________
Making Saw Dust With a Scroll Saw
Show Printable Version Email this Page   Quote this post in a PM to ScottM
Old 07-29-2009, 09:40 PM   #4
Bas is offline Bas
Bas's Avatar
City: Raleigh
State: NC
County: Wake
Threads: 211
Avg Visit Freq/Week
= 6.96 over 180 days
Re: Sniper Sled
After you pick up my lumber at Scott Smith's
After you help me pack up for my shop
After you help me move
After you drop off my lumber
eh...when I have a shop again?
(running out of excuses here )
__________________
Bas.
Old 07-30-2009, 07:46 AM   #5
timf67's Avatar
City: Charlotte
State: NC
County: Mecklenburg
Threads: 55
Avg Visit Freq/Week
= 5.79 over 180 days
Re: Sniper Sled
okay, so I have to ask why you used a router to "drill" the 1/4" holes? Is it quicker? Is it the convenient depth stop? do you have a jig to automatically space the holes? Inquiring minds want to know!
Show Printable Version Email this Page   Quote this post in a PM to timf67
Old 07-30-2009, 10:02 AM   #6
NCPete's Avatar
City: Hope Mills
State: NC
County: Cumberland
Threads: 213
Avg Visit Freq/Week
= 5.99 over 180 days
Re: Sniper Sled
with the straight edge on the sled, the router keeps the holes all lined up. Bas probably just marked out the spacing, tho, as exact 1" spaces are not critical to this, as long as the holes are in the same line across the board -widthwise?
__________________
Failure is the opportunity to begin again more intelligently. – Henry Ford
However your life is, meet it and live it.
Henry David Thoreau
They that can give up essential liberty to obtain a little temporary safety, deserve neither liberty, nor safety. Benjamin Franklin
Show Printable Version Email this Page   Quote this post in a PM to NCPete
Old 07-30-2009, 10:20 AM   #7
Bas is offline Bas
Bas's Avatar
City: Raleigh
State: NC
County: Wake
Threads: 211
Avg Visit Freq/Week
Re: Sniper Sled
Well, you can't see it, but I have a super simple shelf pin jig. I made a custom router plate out of some 1/4" hardboard. An 1" from the center, I drilled a 1/4" hole that accepts a bolt and fastened it with a nut. That's the indexing pin.
Clamp the straightedge across the work piece, route the first hole, and then insert the bolt into the hole you just routed. Plunge down to route the second hole, shift the router over etc.
Some pics using my old router:
__________________
Bas.
Old 07-30-2009, 08:21 PM   #8
Trent Mason's Avatar
City: Wrightsville Beach
State: NC
County: New Hanover
Threads: 81
Avg Visit Freq/Week
= 6.77 over 180 days
Re: Sniper Sled
That's a very cool jig Bas. Thanks so much for posting all of this.
__________________
Trent
"By the waterside I will lay my head......"
"We should never separate the lives we live
from the words we speak."
— Paul Wellstone
Show Printable Version Email this Page   Quote this post in a PM to Trent Mason
Closed Thread
sled , sniper , snipesled
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Order your 2010 Calendar!
Carolina Lumber Sourcing
» Stats
Members: 3,663
Threads: 25,104
Top Poster: DaveO (14,701)
Welcome to our newest member, Keith Senderak
» Today's Birthdays
Dick Barnes (74)
Powered by vBadvanced CMPS v3.2.0
Powered by vBulletin® Version 3.8.2
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.3.0
Template-Modifications by TMS
Content Copyright © 2005 - 2009 North Carolina Woodworker, Inc.
