» Upcoming Events | | Fall 2009 Raffle drawing this Friday (11/20): See This Thread For Details |  | |
11-18-2005, 10:20 PM
#1 | | Small drawer box jointery?? Name: DaveO City: Clayton State: NC County: Johnston Join Date: Aug 2005 Age: 39  11-18-2005, 10:20 PM
Administrator I am in the planning stages of my wife's long over due birthday present, a jewelry box. The book that I am stealing the basis for my design from calls for drawer sides and front/backs to be 5/16" thick, 1.5-2.5" tall and 8" wide x 7" deep drawer boxes with butt dadoed joints. What would be better, a full thickness butt joint in a dado or a half thickness butt joint with shoulder. DTs are out of the question due to the small size and number of joints needed. The drawer box's secondary wood will be either Poplar or soft Maple and the fronts will be highly figured curly Maple with 1/8" BB ply bottoms and dividers. I know they are small but I want them to last, and not take me to her next B-day to make. Thanks for ya'lls thoughts. Dave
__________________   Nothing left to do but smile, smile, smile
--Dr. Seuss
| | Views: 570 |
11-18-2005, 10:35 PM
#2 | | Member
Name: Steve DeWeese City: Horse Shoe State: NC County: Henderson Join Date: Oct 2005 Age: 45 Avg Visit Freq/Week = 0.00 over 180 days | Re: Small drawer box jointery?? I don't know what would be best, that comes down to preference for appearance. You might also want to consider a box joint. You could do that easily in that thickness, it would be strong and look nice IMHO. |
11-18-2005, 10:46 PM
#3 |
Name: Monty City: Hickory State: NC County: Catawba Join Date: Jul 2005 Avg Visit Freq/Week = 2.02 over 180 days | Re: Small drawer box jointery?? I think half butt/shoulder -- to maximize room in the small drawers. If you're concerned about strength, you could pin the joints with pieces of brass rod ... maybe? |
11-18-2005, 10:48 PM
#4 | | Administrator
Name: DaveO City: Clayton State: NC County: Johnston Join Date: Aug 2005 Age: 39 Avg Visit Freq/Week = 7.00 over 180 days | Re: Small drawer box jointery?? Steve thanks, for the thoughts. I had considered a box joint as I have the plans for Insom's sweet jig, but I would rather not interupt the flow of the curly maple drawer fronts with anything. I am planning on sequence cutting the fronts so the figure flows across them. Either joint I mentioned will be done blind so you won't see it at the top intersection of the face and sides. If that adds anything to the thought process. Thanks, Dave
--Dr. Seuss
11-18-2005, 10:52 PM
#5 |
Name: Mike City: State: County: Join Date: Aug 2005 Avg Visit Freq/Week = 0.00 over 180 days | Re: Small drawer box jointery?? Dave, there are several good choices for small drawer joinery. I have used a variety of methods. I have used regular miters reinforced with splines that also serve as decorations. I used a tongue and groove dado joint where a tongue is cut on the front and back on both ends and fits into a corresponding dado in the sides. And I have used plain old butt joints reinforced with dowels both contrasting and plain. I have also used box joints as Steve suggested but you should design your drawer depth to accommodate the fingers properly. For a drawer of that size being used by a lady for storing precious items my choice would be the tongue and groove dado joint. It is simple and strong as it quadruples the glue area. Another alternative is to use a drawer lock bit in the router table but I do not know if they are small enough to accommodate wood of that thickness (5/16"). |
11-18-2005, 11:12 PM
#6 | | Administrator
Name: DaveO City: Clayton State: NC County: Johnston Join Date: Aug 2005 Age: 39 Avg Visit Freq/Week = 7.00 over 180 days | Re: Small drawer box jointery?? Mike, I am leaning towards the tongue and groove dado joint for the additional glue surface. But I am thinking of doing the tongue in the sides and the groove in the front. The front of the drawers must remain as consistent surface so it has to sit in front of the sides. Do you think that will work and will it be strong enough for a small drawer, that won't see much abuse...my wife has little in the way of jewelry, and doesn't wear what she has very often. Dave
--Dr. Seuss
11-19-2005, 08:14 AM
#7 |
Name: Mike City: State: County: Join Date: Aug 2005 Avg Visit Freq/Week = 0.00 over 180 days | Re: Small drawer box jointery?? Dave, I would guess that it would work that way but obviously that would be the joint's weakest orientation.
Another choice would be a locking box joint, I think that is what it is called. To make this joint you basically divide the end of your piece of wood into thirds. It works best if your saw blade is one-third the thickness of your stock. Carefully, making test cuts set your rip fence so that it one blade thickness away from the blade and projecting 2/3 the thickness of your stock above the table. This setting will be used to cut dados in the side pieces. Run all side pieces through and you will now have a dado that is 2/3 the thickness of your stock one blade width from the end on both ends of your drawer side pieces. This will form a little hook.
Now comes the tricky part. Raise the projection of your blade above the table until it exactly equals the thickness of your stock. Do not change the distance from your fence. Once satisfied with the height, stand your front and back pieces on end and pass them through the blade to cut a centered groove/dado on the end grain of your pieces. Once this is done we have to adjust the blade height once again.
So now we have dados in the side pieces one blade width from the end and 2/3 the thickness of our stock deep. We have dados on the ends of our front and back pieces one blade width from the front and back as deep as our stock is thick.
The next and last step is to trim the inside face of the front and back pieces so the hook formed by the dado in the sides can lock into the front and back pieces and be flush with the end of the front and back. To do this you must lower your blade so that it just projects above the table enough to cut slightly more than 1/3 the thickness of your stock. Then your have to set up a stop block on your fence so that you can remove exactly 1/3 of the inside face on the side of the dado you cut vertically. If this is done properly you will have the face of your drawer untouched and locking hook on the sides that fits over a small tenon on the inside face of your drawer pieces.
I am sure that this description is as clear as mud but this joint is by far the best as it provides the most glue surface as well as mechanical strength and preserves the integrity of your drawer fronts. I hope you understand this. I wrote it and now that the ink is dry I am confused.....
11-19-2005, 08:47 AM
#8 |
Name: Joe City: Holly Springs State: NC County: Wake Join Date: Sep 2005 Age: 66 Avg Visit Freq/Week = 7.00 over 180 days | Re: Small drawer box jointery?? |
11-19-2005, 09:42 AM
#9 |
Name: Mike City: State: County: Join Date: Aug 2005 Avg Visit Freq/Week = 0.00 over 180 days | Re: Small drawer box jointery?? Bladeburner, you are correct, that is the router bit method I so poorly referred to. My concern there is that it may not be possible to get a bit small enough for the stock Dave is using. I have used that bit and it works just fine.
Dave here is a link with pictures and text to the drawer lock joint cut on a table saw I so ineptly described. I could show you in half the time it took to write that poorly worded description. http://www.diynetwork.com/diy/hi_too...219278,00.html
I believe that this is the best choice for your application although set up is somewhat tedious. If you were to use 3/8" stock and a 1/8" blade it is pretty simple. That is what I have done when I have used it in the past.
11-19-2005, 10:45 AM
#10 | | Administrator
Name: DaveO City: Clayton State: NC County: Johnston Join Date: Aug 2005 Age: 39 Avg Visit Freq/Week = 7.00 over 180 days | Re: Small drawer box jointery?? Actually, Mike your narrative was excellent, I was able to draw an example so I could visualize it even before I scrolled down and saw the DIY link. Thanks for taking the time to type all that out for me. That is definitely the best joint for my application, and really doesn't look that hard to do. I have a nice 1/8" flat topped rip blade that should result in a nice clean joint. Thanks, Dave
--Dr. Seuss
11-19-2005, 12:34 PM
#11 |
Name: John Skipper City: Forest City State: NC County: Rutherford Join Date: Oct 2005 Age: 62 Avg Visit Freq/Week = 0.04 over 180 days | Re: Small drawer box jointery?? Dave if you have a router table or just a hand held you might want consider a reverse joint router bit. The joint is very strong and you will not see the joints.
__________________
John Skipper
"Don't worry about the mule going blind, load the wagon."
11-19-2005, 09:24 PM
#12 | | Administrator
Name: DaveO City: Clayton State: NC County: Johnston Join Date: Aug 2005 Age: 39 Avg Visit Freq/Week = 7.00 over 180 days | Re: Small drawer box jointery?? John, sorry for my ignorance what is a "reverse joint" router bit. I have both a table (crappy, but functional) and a few handheld routers, so I would be very interested in that concept. Thanks, Dave
--Dr. Seuss
11-19-2005, 09:29 PM
#13 |
Name: John Skipper City: Forest City State: NC County: Rutherford Join Date: Oct 2005 Age: 62 Avg Visit Freq/Week = 0.04 over 180 days | Re: Small drawer box jointery?? Sorry about the bit names. It's the same princible as a drawer lock bit.
__________________
John Skipper
11-19-2005, 09:46 PM
#14 | | Administrator
Name: DaveO City: Clayton State: NC County: Johnston Join Date: Aug 2005 Age: 39 Avg Visit Freq/Week = 7.00 over 180 days | Re: Small drawer box jointery?? Gotcha, so basically it will cut the same joint as Big Mike is suggesting doing on the tablesaw. Thanks for the clarification. Dave
--Dr. Seuss
11-19-2005, 10:06 PM
#15 |
Name: D L Ames City: Fayetteville State: NC County: Cumberland Join Date: Oct 2005 Age: 51 Avg Visit Freq/Week = 0.00 over 180 days | Re: Small drawer box jointery?? Thanks for posting that link Big Mike. I have used a lock miter bit before but I am going to try this technique from the DIY link for making a lock joint with the tablesaw. |
| |  | | | Thread Tools | | | | Display Modes | Linear Mode |
Posting Rules
Members: 3,663
Threads: 25,105
Top Poster: DaveO (14,701) | | Welcome to our newest member, Keith Senderak | |
