North Carolina Woodworker
Discounts on 2010 NCWW Calendar through Nov 30th!!
Javascript DHTML Drop Down Menu Powered by dhtml-menu-builder.com
Go Back   North Carolina Woodworker > Woodworking > General Woodworking
» Upcoming Events
Fall 2009 Raffle drawing this Friday (11/20): See This Thread For Details
Closed Thread
Old 08-15-2008, 12:28 AM   #1
From slab to fab
Bas's Avatar
City: Raleigh
State: NC
County: Wake
Threads: 211
Show Printable Version Email this Page   Quote this post in a PM to Bas
Bas Bas is offline 08-15-2008, 12:28 AM
Senior Administrator
Chris, a friend of mine is redoing his stairs. After installing a few Oak treads from Lowe's, he decided he didn't like them very much, especially not at that price. So he asked if I could help him fabricate some. First "external" project, whoohoo!
Jeff was going to get me some 5/4 lumber a couple of wood runs ago, but he accidentally brought 4/4. Which turned out to be a blessing in disguise! After learning I wanted to make treads, he offered up some BIG, MASSIVE Oak slabs. I had planned to just glue up boards to get the right width, but I couldn't pass this one up.
These boards were 10' long, 2' wide, with a thickness varying from 5/4 to 6/4. Big boys. Good thing Scott (NCScroller) was around with his truck. Here are a couple of pictures of the rough material:
The first thing I did was trim them down by cutting some of the sapwood and bark off the sides. Anything to get them more manageable. I also figured it would help with acclimating. Hot and dusty work!
After a few weeks of acclimating in the shop, it was time to turn lumber into stair treads. Now, my shop is pretty small. With all the stuff I have in there, handling a 4x4 sheet of plywood is a challenge, let alone 10' slabs. Even after I cut the boards to rough length using a circular saw, it was still tight.
First step was ripping the sides parallel. Cutting the bark and sapwood had left the boards extremely wavy, so jointing was not an option. I attached each board to a piece of MDF (letting the crooked edge hang over the MDF edge a bit) with some hot melt glue, and ripped one edge straight. Then popped off the board and ripped the other side. With boards this size, a helper is handy (still gotta build that outfeed table...).
(BTW, my little saw ripped through the 6/4 oak like it was hot butter! It's all about the blade... )
Since my jointer can't handle anything wider than 6", I used a planer sled. It's nothing more than a bunch of laminated sheets of MDF, and a stop. I shimmed each board with playing cards to make sure it wouldn't rock, then attached it with more hot melt glue. A few passes through the planer and one side was flat. Well, quite a few passes actually. You can only take off a VERY small amount with 12" wide boards! After that, pop off the board, and plane the other side parallel. Again, a helper is invaluable, that planer sled is HEAVY. And with an oak slab on top, it's HEAVIER.
After getting everything straight and flat, I let the boards acclimate further, and brought it down to 1" in stages. I did not want any warping at this point!
The next step was putting a bullnose on the boards. I set up my little router table, even added an auxiliary fence, but it wasn't working. The board was simply too wide for such a small table, it kept shifting. So instead I set up a jig on my workbench. The extra rail provided solid support for the router.
And yes, occasionally, I do have sawdust on the floor! Actually, this was after the first board, the place looked like a disaster area after the last one, dust EVERYWHERE. A router table would have done a better job managing the dust...yet another reason to build one. But the finished treads look great, a little sanding and they'll be ready for installation. I plan to do the final trimming on-site.
Working with slabs is not easy. You waste a lot of wood getting it flat and straight, but the result is very pretty. And you don't have to worry about matching the grain
The whole ripping and planing process took an entire afternoon. With larger equipment, it probably would have taken an hour. But, this is a hobby...no rush. The same goes for the routing, with a decent table I could have put the bullnoses on in no time. But it was cool figuring out how to build a jig for this. Certainly very satisfying, tackling large projects with small tools. I feel sorry for Travis, he'll never be able to appreciate this.
Woodworking is typically a lonely business, it was a lot of fun working on this together with my buddy Chris. Also a lot safer.
__________________
Bas.
I don't need it. I just want it.
Old 08-15-2008, 12:32 AM   #2
Treasurer
City: Wake Forest
State: NC
County: Wake
Threads: 184
Avg Visit Freq/Week
= 6.53 over 180 days
Re: From slab to fab
This reads like a documentary. What's gotten into you?
Show Printable Version Email this Page   Quote this post in a PM to Travis Porter
Old 08-15-2008, 12:49 AM   #3
Name: Chris Kalai Allen
City: Kurtistown
State: HI
County: Hawaii
Threads: 22
Avg Visit Freq/Week
= 2.33 over 180 days
Hay Bas, nice slabs,,, nice shop,,, even nicer story!! I don't think my shop is big enough to have slabs like that in there, I am planning on rebuilding by shop so I will have more room, maybe then I can use my tablesaw for things other than cutting out pen blanks Aloha.
Kalai
Show Printable Version Email this Page   Quote this post in a PM to Kalai
Old 08-15-2008, 07:26 AM   #4
LeftyTom's Avatar
City: Yadkinville
State: NC
County: Yadkin
Threads: 209
Avg Visit Freq/Week
= 5.95 over 180 days
Gee, Bas, you looked taller over the interwebz!
__________________
The thing that holds up all my woodworking is simply getting started.
Show Printable Version Email this Page   Quote this post in a PM to LeftyTom
Old 08-15-2008, 07:26 AM   #5
JackLeg's Avatar
City: Albemarle
State: NC
County: Stanly
Threads: 228
Avg Visit Freq/Week
= 6.03 over 180 days
Nice job on the slabs, and an even nicer narrative! I KNEW you are multi-talented! Next thing we know, Nahm will be looking for a new home, and it'll be the "Dutch Boy" show. (And I don't mean paint!)
Seriously, great job of bringing them from raw to ready.
__________________
Democracy is two wolves and a lamb voting on what to have for lunch. Liberty is a well-armed lamb contesting the vote. – UNKNOWN!
Show Printable Version Email this Page   Quote this post in a PM to JackLeg
Old 08-15-2008, 07:44 AM   #6
skysharks's Avatar
Name: John Macmaster
City: Eastover
State: NC
County: Cumberland
Threads: 83
Avg Visit Freq/Week
= 6.61 over 180 days
Good job Bas-man.
It was a good read.
I can relate to the time spent on planing and jointing. About 75% of what I make in my shop goes thru that process.
It is very, very rarely that I buy any finished lumber.
But man does it give you a nice satisfaction that you did it.
But sometimes when you try to explain it to some folks it gets lost on them.
Once again great job
__________________
Long ago when men cursed and beat the ground with sticks, it was called witchcraft. Today it's called golf.
Show Printable Version Email this Page   Quote this post in a PM to skysharks
Old 08-15-2008, 07:54 AM   #7
City: Davidson
State: NC
County: Cabarrus
Threads: 17
Avg Visit Freq/Week
= 2.92 over 180 days
Very nice Bas!
__________________
If it isn't broke then I haven't tried to fix it....
Putting the 'fun' back in dysfunctional!
Show Printable Version Email this Page   Quote this post in a PM to BarryC
Old 08-15-2008, 08:26 AM   #8
Senior Moderator
Events Director
ScottM's Avatar
City: Cary
State: NC
County: Wake
Threads: 257
Avg Visit Freq/Week
= 6.49 over 180 days
U-DA-MAN...... Love the write up.
__________________
Making Saw Dust With a Scroll Saw
Show Printable Version Email this Page   Quote this post in a PM to ScottM
Old 08-15-2008, 08:27 AM   #9
Webmaster
Administrator
Senior Moderator
TracyP's Avatar
City: Salisbury
State: NC
County: Rowan
Threads: 332
Avg Visit Freq/Week
= 7.00 over 180 days
Great looking stair treads and awesome narrative with pics. Is this recent run of long narratives becoming your internet resume'?
__________________
Tracy
Making Friends One Post At A Time
The task is always worthwhile if you learn something in the process.
Show Printable Version Email this Page   Quote this post in a PM to TracyP
Old 08-15-2008, 09:33 AM   #10
RandyJ's Avatar
City: Macon
State: NC
County: Warren
Threads: 34
Avg Visit Freq/Week
= 5.44 over 180 days
Nice job, Bas! Looks like you know what you're doing. How did you get ol' Darth to help out in the shop?
__________________
Randy
Any compromise between the truth and a lie can ONLY be something less than the truth.
Show Printable Version Email this Page   Quote this post in a PM to RandyJ
Old 08-15-2008, 09:38 AM   #11
CaptnA's Avatar
City: Mills River
State: NC
County: Henderson
Threads: 33
Avg Visit Freq/Week
= 3.46 over 180 days
well done!
And well explained. Anything is possible if enough planning and patience goes into it.
I've heard too often people won't do something because they don't have equipment large enough. Looks like you managed just fine without "industrial" equipment!
Show Printable Version Email this Page   Quote this post in a PM to CaptnA
Old 08-15-2008, 09:39 AM   #12
Mike Callihan's Avatar
City: Burnsville
State: NC
County: Yancey
Threads: 9
Avg Visit Freq/Week
= 0.00 over 180 days
Way to go, "where there is a will there is a way". Thanks for sharing.
__________________
"We has seen the enemy and they is us" Pogo
Show Printable Version Email this Page   Quote this post in a PM to Mike Callihan
Old 08-15-2008, 09:50 AM   #13
Glennbear's Avatar
City: Baskerville
State: VA
County: Mecklenburg
Threads: 166
Avg Visit Freq/Week
= 6.30 over 180 days
Nicely done Bas, " The whole ripping and planing process took an entire afternoon" . Only an afternoon ! That looks like days of work for me. With all of jigs and setups I think you can add millwright to your talent listing or at least Joe Scharle has competition for title of resident jigmeister
__________________
" I get knocked down but I get up again" - Chumbawamba
Show Printable Version Email this Page   Quote this post in a PM to Glennbear
Old 08-15-2008, 10:04 AM   #14
Sanders Woodworking's Avatar
City: Mount Ulla
State: NC
County: Rowan
Threads: 23
Avg Visit Freq/Week
= 2.22 over 180 days
Very nice work Bas. I build everything from rough cut lumber. My neighbor helped me with the cradle we built for his daughter's baby. He was amazed that we spent the entire first day preparing the lumber. He especially liked emptying the dust collector several times. I just added a trash can seperator that will make it easier to get from rough to finished lumber.
I love the smell of planer dust. Oak, walnut, cherry - mmmm. If you start with finished lumber you miss the smell and the excitement of the first pass on the planer when you can actually see the face grain.
My favorite part of building my house was the open, floating stair project to the 2nd story. Our stair treads are finished 1 1/8" thick QS white oak.
Show Printable Version Email this Page   Quote this post in a PM to Sanders Woodworking
Old 08-15-2008, 10:12 AM   #15
WoodWrangler's Avatar
City: Charlotte
State: NC
County: Mecklenburg
Threads: 520
Avg Visit Freq/Week
= 6.92 over 180 days
Is that Darth helping you?
Show Printable Version Email this Page   Quote this post in a PM to WoodWrangler
Closed Thread
fab , oak , planer , slab , sled , stair , treads
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
ERC Slab TV Where Can I Find, Buy or Sell 11 05-28-2008 12:41 PM
Granite slab scraps chris99z71 Found for Sale/Hot Deals 0 03-04-2007 06:18 PM
How would you resaw 22+ inch wide slab? dave_the_woodworker General Woodworking 5 09-19-2006 03:16 PM
Slab tables jeff... General Woodworking 9 07-05-2006 02:27 PM
Walnut Slab for a Lathe Kyle Where Can I Find, Buy or Sell 2 05-02-2006 09:46 AM
Order your 2010 Calendar!
Carolina Lumber Sourcing
» Stats
Members: 3,666
Threads: 25,110
Top Poster: DaveO (14,702)
Welcome to our newest member, dirty b
» Today's Birthdays
Dick Barnes (74)
Powered by vBadvanced CMPS v3.2.0
Powered by vBulletin® Version 3.8.2
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.3.0
Template-Modifications by TMS
Content Copyright © 2005 - 2009 North Carolina Woodworker, Inc.
